三元运算符 (If-Then-Else)
您可以使用三元运算符在 表达式。下面的清单显示了一个最小示例:
Java
Kotlin
String falseString = parser.parseExpression(
"false ? 'trueExp' : 'falseExp'").getValue(String.class);
val falseString = parser.parseExpression(
"false ? 'trueExp' : 'falseExp'").getValue(String::class.java)
在这种情况下,布尔值false
返回 String 值'falseExp'
.一个 更多
实际示例如下:
Java
Kotlin
parser.parseExpression("name").setValue(societyContext, "IEEE");
societyContext.setVariable("queryName", "Nikola Tesla");
expression = "isMember(#queryName)? #queryName + ' is a member of the ' " +
"+ Name + ' Society' : #queryName + ' is not a member of the ' + Name + ' Society'";
String queryResultString = parser.parseExpression(expression)
.getValue(societyContext, String.class);
// queryResultString = "Nikola Tesla is a member of the IEEE Society"
expression = "isMember(#queryName)? #queryName + ' is a member of the ' " + "+ Name + ' Society' : #queryName + ' is not a member of the ' + Name + ' Society'"
val queryResultString = parser.parseExpression(expression)
.getValue(societyContext, String::class.java)
请参阅 Elvis 运算符的下一节,了解 三元运算符。
