作 Advised 对象
无论您如何创建 AOP 代理,您都可以通过使用org.springframework.aop.framework.Advised接口。任何 AOP 代理都可以强制转换为此 接口,无论它实现哪些其他接口。此接口包括 方法如下:spring-doc.cadn.net.cn
Advisor[] getAdvisors();
void addAdvice(Advice advice) throws AopConfigException;
void addAdvice(int pos, Advice advice) throws AopConfigException;
void addAdvisor(Advisor advisor) throws AopConfigException;
void addAdvisor(int pos, Advisor advisor) throws AopConfigException;
int indexOf(Advisor advisor);
boolean removeAdvisor(Advisor advisor) throws AopConfigException;
void removeAdvisor(int index) throws AopConfigException;
boolean replaceAdvisor(Advisor a, Advisor b) throws AopConfigException;
boolean isFrozen();
fun getAdvisors(): Array<Advisor>
@Throws(AopConfigException::class)
fun addAdvice(advice: Advice)
fun addAdvice(pos: Int, advice: Advice)
fun addAdvisor(advisor: Advisor)
fun addAdvisor(pos: Int, advisor: Advisor)
fun indexOf(advisor: Advisor): Int
fun removeAdvisor(advisor: Advisor): Boolean
fun removeAdvisor(index: Int)
fun replaceAdvisor(a: Advisor, b: Advisor): Boolean
fun isFrozen(): Boolean
getAdvisors()method 返回一个Advisor对于每个 advisor、interceptor 或 其他已添加到 Factory 的通知类型。如果您添加了Advisor这 在此索引返回的 advisor 是您添加的对象。如果您添加了 interceptor 或其他 advice 类型,Spring 将其包装在 advisor 中,并带有 始终返回的切入点true.因此,如果您添加了MethodInterceptor、顾问 为此索引返回的是一个DefaultPointcutAdvisor这会返回您的MethodInterceptor以及匹配所有类和方法的切入点。spring-doc.cadn.net.cn
addAdvisor()methods 可用于添加任何Advisor.通常,顾问持有 切入点和建议是通用的DefaultPointcutAdvisor,您可以将其与 任何建议或切入点(但不包括介绍)。spring-doc.cadn.net.cn
默认情况下,可以添加或删除 advisor 或拦截器,即使一个 proxy 已创建。唯一的限制是无法添加或删除 Introduction Advisor,因为工厂的现有代理不显示界面 改变。(您可以从工厂获取新的 proxy 以避免此问题。spring-doc.cadn.net.cn
以下示例显示了将 AOP 代理转换为Advised接口和 examine 以及 纵其建议:spring-doc.cadn.net.cn
Advised advised = (Advised) myObject;
Advisor[] advisors = advised.getAdvisors();
int oldAdvisorCount = advisors.length;
System.out.println(oldAdvisorCount + " advisors");
// Add an advice like an interceptor without a pointcut
// Will match all proxied methods
// Can use for interceptors, before, after returning or throws advice
advised.addAdvice(new DebugInterceptor());
// Add selective advice using a pointcut
advised.addAdvisor(new DefaultPointcutAdvisor(mySpecialPointcut, myAdvice));
assertEquals("Added two advisors", oldAdvisorCount + 2, advised.getAdvisors().length);
val advised = myObject as Advised
val advisors = advised.advisors
val oldAdvisorCount = advisors.size
println("$oldAdvisorCount advisors")
advised.addAdvice(DebugInterceptor())
advised.addAdvisor(DefaultPointcutAdvisor(mySpecialPointcut, myAdvice))
assertEquals("Added two advisors", oldAdvisorCount + 2, advised.advisors.size)
修改 business 对象,尽管毫无疑问存在合法的用例。 但是,它在开发中可能非常有用(例如,在测试中)。我们有时 发现能够以拦截器或其他 建议,进入我们想要测试的方法调用。(例如,建议可以 进入为该方法创建的事务中,也许是为了运行 SQL 来检查它 在将事务标记为回滚之前,已正确更新了数据库。
根据您创建代理的方式,您通常可以将frozen旗。在那个 case 中,使用Advised isFrozen()method 返回true以及任何修改 建议AopConfigException.能力 冻结被通知对象的 state 在某些情况下很有用(例如,冻结 防止调用代码删除安全拦截器)。spring-doc.cadn.net.cn
