对于最新的稳定版本,请使用 Spring Boot 3.4.0! |
线程转储 (threaddump
这threaddump
endpoint 提供来自应用程序 JVM 的线程转储。
以 JSON 格式检索线程转储
要将线程转储检索为 JSON,请创建一个GET
request 添加到/actuator/threaddump
替换为适当的Accept
header,如以下基于 curl 的示例所示:
$ curl 'http://localhost:8080/actuator/threaddump' -i -X GET \
-H 'Accept: application/json'
生成的响应类似于以下内容:
HTTP/1.1 200 OK
Content-Type: application/json
Content-Length: 38658
"threads" : [ {
"threadName" : "Test worker",
"threadId" : 1,
"blockedTime" : -1,
"blockedCount" : 33,
"waitedTime" : -1,
"waitedCount" : 38,
"lockOwnerId" : -1,
"daemon" : false,
"inNative" : false,
"suspended" : false,
"threadState" : "RUNNABLE",
"priority" : 5,
"stackTrace" : [ {
"moduleName" : "java.management",
"moduleVersion" : "17.0.13",
"methodName" : "dumpThreads0",
"fileName" : "ThreadImpl.java",
"lineNumber" : -2,
"nativeMethod" : true,
"className" : "sun.management.ThreadImpl"
"methodName" : "dumpAllThreads",
"lineNumber" : 528,
"nativeMethod" : false,
"lineNumber" : 516,
"classLoaderName" : "app",
"methodName" : "getFormattedThreadDump",
"fileName" : "ThreadDumpEndpoint.java",
"lineNumber" : 52,
"className" : "org.springframework.boot.actuate.management.ThreadDumpEndpoint"
"methodName" : "threadDump",
"lineNumber" : 43,
"moduleName" : "java.base",
"methodName" : "invoke0",
"fileName" : "NativeMethodAccessorImpl.java",
"lineNumber" : -2,
"className" : "jdk.internal.reflect.NativeMethodAccessorImpl"
"methodName" : "invoke",
"lineNumber" : 77,
"fileName" : "DelegatingMethodAccessorImpl.java",
"lineNumber" : 43,
"className" : "jdk.internal.reflect.DelegatingMethodAccessorImpl"
"fileName" : "Method.java",
"lineNumber" : 569,
"className" : "java.lang.reflect.Method"
"methodName" : "invokeMethod",
"fileName" : "ReflectionUtils.java",
"lineNumber" : 281,
"className" : "org.springframework.util.ReflectionUtils"
"fileName" : "ReflectiveOperationInvoker.java",
"lineNumber" : 74,
"className" : "org.springframework.boot.actuate.endpoint.invoke.reflect.ReflectiveOperationInvoker"
"fileName" : "AbstractDiscoveredOperation.java",
"lineNumber" : 60,
"className" : "org.springframework.boot.actuate.endpoint.annotation.AbstractDiscoveredOperation"
"methodName" : "handle",
"fileName" : "AbstractWebMvcEndpointHandlerMapping.java",
"lineNumber" : 327,
"className" : "org.springframework.boot.actuate.endpoint.web.servlet.AbstractWebMvcEndpointHandlerMapping$ServletWebOperationAdapter"
"lineNumber" : 434,
"className" : "org.springframework.boot.actuate.endpoint.web.servlet.AbstractWebMvcEndpointHandlerMapping$OperationHandler"
"lineNumber" : -1,
"className" : "jdk.internal.reflect.GeneratedMethodAccessor64"
"lineNumber" : 43,
"lineNumber" : 569,
"methodName" : "doInvoke",
"fileName" : "InvocableHandlerMethod.java",
"lineNumber" : 255,
"className" : "org.springframework.web.method.support.InvocableHandlerMethod"
"methodName" : "invokeForRequest",
"lineNumber" : 188,
"methodName" : "invokeAndHandle",
"fileName" : "ServletInvocableHandlerMethod.java",
"lineNumber" : 118,
"className" : "org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod"
"methodName" : "invokeHandlerMethod",
"fileName" : "RequestMappingHandlerAdapter.java",
"lineNumber" : 926,
"className" : "org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter"
"methodName" : "handleInternal",
"lineNumber" : 831,
"fileName" : "AbstractHandlerMethodAdapter.java",
"lineNumber" : 87,
"className" : "org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter"
"methodName" : "doDispatch",
"fileName" : "DispatcherServlet.java",
"lineNumber" : 1089,
"className" : "org.springframework.web.servlet.DispatcherServlet"
"methodName" : "doService",
"lineNumber" : 979,
"methodName" : "processRequest",
"fileName" : "FrameworkServlet.java",
"lineNumber" : 1014,
"className" : "org.springframework.web.servlet.FrameworkServlet"
"methodName" : "doGet",
"lineNumber" : 903,
"methodName" : "service",
"fileName" : "HttpServlet.java",
"lineNumber" : 527,
"className" : "jakarta.servlet.http.HttpServlet"
"lineNumber" : 885,
"fileName" : "TestDispatcherServlet.java",
"lineNumber" : 72,
"className" : "org.springframework.test.web.servlet.TestDispatcherServlet"
"lineNumber" : 614,
"methodName" : "doFilter",
"fileName" : "MockFilterChain.java",
"lineNumber" : 165,
"className" : "org.springframework.mock.web.MockFilterChain$ServletFilterProxy"
"lineNumber" : 132,
"className" : "org.springframework.mock.web.MockFilterChain"
"methodName" : "perform",
"fileName" : "MockMvc.java",
"lineNumber" : 201,
"className" : "org.springframework.test.web.servlet.MockMvc"
"methodName" : "jsonThreadDump",
"fileName" : "ThreadDumpEndpointDocumentationTests.java",
"lineNumber" : 66,
"className" : "org.springframework.boot.actuate.autoconfigure.endpoint.web.documentation.ThreadDumpEndpointDocumentationTests"
"lineNumber" : -2,
"lineNumber" : 77,
"lineNumber" : 43,
"lineNumber" : 569,
"lineNumber" : 728,
"className" : "org.junit.platform.commons.util.ReflectionUtils"
"methodName" : "proceed",
"fileName" : "MethodInvocation.java",
"lineNumber" : 60,
"className" : "org.junit.jupiter.engine.execution.MethodInvocation"
"fileName" : "InvocationInterceptorChain.java",
"lineNumber" : 131,
"className" : "org.junit.jupiter.engine.execution.InvocationInterceptorChain$ValidatingInvocation"
"methodName" : "intercept",
"fileName" : "TimeoutExtension.java",
"lineNumber" : 156,
"className" : "org.junit.jupiter.engine.extension.TimeoutExtension"
"methodName" : "interceptTestableMethod",
"lineNumber" : 147,
"methodName" : "interceptTestMethod",
"lineNumber" : 86,
"methodName" : "apply",
"lineNumber" : -1,
"className" : "org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor$$Lambda$202/0x00007effa013d808"
"methodName" : "lambda$ofVoidMethod$0",
"fileName" : "InterceptingExecutableInvoker.java",
"lineNumber" : 103,
"className" : "org.junit.jupiter.engine.execution.InterceptingExecutableInvoker$ReflectiveInterceptorCall"
"lineNumber" : -1,
"className" : "org.junit.jupiter.engine.execution.InterceptingExecutableInvoker$ReflectiveInterceptorCall$$Lambda$203/0x00007effa013dc28"
"methodName" : "lambda$invoke$0",
"lineNumber" : 93,
"className" : "org.junit.jupiter.engine.execution.InterceptingExecutableInvoker"
"lineNumber" : -1,
"className" : "org.junit.jupiter.engine.execution.InterceptingExecutableInvoker$$Lambda$487/0x00007effa01ed5a0"
"lineNumber" : 106,
"className" : "org.junit.jupiter.engine.execution.InvocationInterceptorChain$InterceptedInvocation"
"lineNumber" : 64,
"className" : "org.junit.jupiter.engine.execution.InvocationInterceptorChain"
"methodName" : "chainAndInvoke",
"lineNumber" : 45,
"lineNumber" : 37,
"lineNumber" : 92,
"lineNumber" : 86,
"methodName" : "lambda$invokeTestMethod$7",
"fileName" : "TestMethodTestDescriptor.java",
"lineNumber" : 218,
"className" : "org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor"
"methodName" : "execute",
"lineNumber" : -1,
"className" : "org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor$$Lambda$1032/0x00007effa062c878"
"fileName" : "ThrowableCollector.java",
"lineNumber" : 73,
"className" : "org.junit.platform.engine.support.hierarchical.ThrowableCollector"
"methodName" : "invokeTestMethod",
"lineNumber" : 214,
"lineNumber" : 139,
"lineNumber" : 69,
"methodName" : "lambda$executeRecursively$6",
"fileName" : "NodeTestTask.java",
"lineNumber" : 156,
"className" : "org.junit.platform.engine.support.hierarchical.NodeTestTask"
"lineNumber" : -1,
"className" : "org.junit.platform.engine.support.hierarchical.NodeTestTask$$Lambda$304/0x00007effa0159e50"
"lineNumber" : 73,
"methodName" : "lambda$executeRecursively$8",
"lineNumber" : 146,
"lineNumber" : -1,
"className" : "org.junit.platform.engine.support.hierarchical.NodeTestTask$$Lambda$303/0x00007effa0159c28"
"methodName" : "around",
"fileName" : "Node.java",
"lineNumber" : 137,
"className" : "org.junit.platform.engine.support.hierarchical.Node"
"methodName" : "lambda$executeRecursively$9",
"lineNumber" : 144,
"lineNumber" : -1,
"className" : "org.junit.platform.engine.support.hierarchical.NodeTestTask$$Lambda$302/0x00007effa0159800"
"lineNumber" : 73,
"methodName" : "executeRecursively",
"lineNumber" : 143,
"lineNumber" : 100,
"methodName" : "accept",
"lineNumber" : -1,
"className" : "org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService$$Lambda$308/0x00007effa015a968"
"methodName" : "forEach",
"fileName" : "ArrayList.java",
"lineNumber" : 1511,
"className" : "java.util.ArrayList"
"methodName" : "invokeAll",
"fileName" : "SameThreadHierarchicalTestExecutorService.java",
"lineNumber" : 41,
"className" : "org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService"
"lineNumber" : 160,
"lineNumber" : -1,
"lineNumber" : 73,
"lineNumber" : 146,
"lineNumber" : -1,
"lineNumber" : 137,
"lineNumber" : 144,
"lineNumber" : -1,
"lineNumber" : 73,
"lineNumber" : 143,
"lineNumber" : 100,
"lineNumber" : -1,
"lineNumber" : 41,
"lineNumber" : 160,
"lineNumber" : -1,
"lineNumber" : 73,
"lineNumber" : 146,
"lineNumber" : -1,
"lineNumber" : 137,
"lineNumber" : 144,
"lineNumber" : -1,
"lineNumber" : 73,
"lineNumber" : 143,
"lineNumber" : 100,
"methodName" : "submit",
"lineNumber" : 35,
"fileName" : "HierarchicalTestExecutor.java",
"lineNumber" : 57,
"className" : "org.junit.platform.engine.support.hierarchical.HierarchicalTestExecutor"
"fileName" : "HierarchicalTestEngine.java",
"lineNumber" : 54,
"className" : "org.junit.platform.engine.support.hierarchical.HierarchicalTestEngine"
"fileName" : "EngineExecutionOrchestrator.java",
"lineNumber" : 198,
"className" : "org.junit.platform.launcher.core.EngineExecutionOrchestrator"
"lineNumber" : 169,
"lineNumber" : 93,
"methodName" : "lambda$execute$0",
"lineNumber" : 58,
"lineNumber" : -1,
"className" : "org.junit.platform.launcher.core.EngineExecutionOrchestrator$$Lambda$257/0x00007effa0141240"
"methodName" : "withInterceptedStreams",
"lineNumber" : 141,
"lineNumber" : 57,
"fileName" : "DefaultLauncher.java",
"lineNumber" : 103,
"className" : "org.junit.platform.launcher.core.DefaultLauncher"
"lineNumber" : 85,
"fileName" : "DelegatingLauncher.java",
"lineNumber" : 47,
"className" : "org.junit.platform.launcher.core.DelegatingLauncher"
"methodName" : "processAllTestClasses",
"fileName" : "JUnitPlatformTestClassProcessor.java",
"lineNumber" : 124,
"className" : "org.gradle.api.internal.tasks.testing.junitplatform.JUnitPlatformTestClassProcessor$CollectAllTestClassesExecutor"
"methodName" : "access$000",
"lineNumber" : 99,
"methodName" : "stop",
"lineNumber" : 94,
"className" : "org.gradle.api.internal.tasks.testing.junitplatform.JUnitPlatformTestClassProcessor"
"fileName" : "SuiteTestClassProcessor.java",
"lineNumber" : 63,
"className" : "org.gradle.api.internal.tasks.testing.SuiteTestClassProcessor"
"lineNumber" : -2,
"lineNumber" : 77,
"lineNumber" : 43,
"lineNumber" : 569,
"methodName" : "dispatch",
"fileName" : "ReflectionDispatch.java",
"lineNumber" : 36,
"className" : "org.gradle.internal.dispatch.ReflectionDispatch"
"lineNumber" : 24,
"fileName" : "ContextClassLoaderDispatch.java",
"lineNumber" : 33,
"className" : "org.gradle.internal.dispatch.ContextClassLoaderDispatch"
"fileName" : "ProxyDispatchAdapter.java",
"lineNumber" : 92,
"className" : "org.gradle.internal.dispatch.ProxyDispatchAdapter$DispatchingInvocationHandler"
"moduleName" : "jdk.proxy1",
"lineNumber" : -1,
"className" : "jdk.proxy1.$Proxy4"
"methodName" : "run",
"fileName" : "TestWorker.java",
"lineNumber" : 200,
"className" : "org.gradle.api.internal.tasks.testing.worker.TestWorker$3"
"methodName" : "executeAndMaintainThreadName",
"lineNumber" : 132,
"className" : "org.gradle.api.internal.tasks.testing.worker.TestWorker"
"lineNumber" : 103,
"lineNumber" : 63,
"fileName" : "ActionExecutionWorker.java",
"lineNumber" : 56,
"className" : "org.gradle.process.internal.worker.child.ActionExecutionWorker"
"methodName" : "call",
"fileName" : "SystemApplicationClassLoaderWorker.java",
"lineNumber" : 121,
"className" : "org.gradle.process.internal.worker.child.SystemApplicationClassLoaderWorker"
"lineNumber" : 71,
"fileName" : "GradleWorkerMain.java",
"lineNumber" : 69,
"className" : "worker.org.gradle.process.internal.worker.GradleWorkerMain"
"methodName" : "main",
"lineNumber" : 74,
"lockedMonitors" : [ ],
"lockedSynchronizers" : [ ]
"threadName" : "Reference Handler",
"threadId" : 2,
"blockedTime" : -1,
"blockedCount" : 2,
"waitedTime" : -1,
"waitedCount" : 0,
"lockOwnerId" : -1,
"daemon" : true,
"inNative" : false,
"priority" : 10,
"stackTrace" : [ {
"methodName" : "waitForReferencePendingList",
"fileName" : "Reference.java",
"lineNumber" : -2,
"className" : "java.lang.ref.Reference"
"methodName" : "processPendingReferences",
"lineNumber" : 253,
"lineNumber" : 215,
"className" : "java.lang.ref.Reference$ReferenceHandler"
"threadName" : "Finalizer",
"threadId" : 3,
"blockedTime" : -1,
"blockedCount" : 0,
"waitedTime" : -1,
"waitedCount" : 1,
"lockName" : "java.lang.ref.ReferenceQueue$Lock@5b2a690f",
"lockOwnerId" : -1,
"daemon" : true,
"inNative" : false,
"threadState" : "WAITING",
"priority" : 8,
"stackTrace" : [ {
"methodName" : "wait",
"lineNumber" : -2,
"className" : "java.lang.Object"
"methodName" : "remove",
"fileName" : "ReferenceQueue.java",
"lineNumber" : 155,
"className" : "java.lang.ref.ReferenceQueue"
"lineNumber" : 176,
"fileName" : "Finalizer.java",
"lineNumber" : 172,
"className" : "java.lang.ref.Finalizer$FinalizerThread"
"lockedSynchronizers" : [ ],
"lockInfo" : {
"className" : "java.lang.ref.ReferenceQueue$Lock",
"identityHashCode" : 1529506063
响应结构
响应包含 JVM 线程的详细信息。 下表描述了响应的结构:
路径 | 类型 | 描述 |
JVM 的线程。 |
线程被阻塞的总次数。 |
线程已阻塞的时间(以毫秒为单位)。如果禁用了线程争用监视,则为 -1。 |
线程是否为守护程序线程。仅在 Java 9 或更高版本上可用。 |
线程是否正在执行本机代码。 |
线程被阻塞的对象的说明(如果有)。 |
线程被阻塞等待的对象。 |
lock 对象的完全限定类名。 |
lock 对象的标识哈希码。 |
此线程锁定的监视器(如果有) |
lock 对象的类名。 |
lock 对象的标识哈希码。 |
显示器被锁定的堆栈深度。 |
锁定显示器的堆栈帧。 |
此线程锁定的同步器。 |
锁定同步器的类名。 |
锁定同步器的身份哈希码。 |
拥有线程被阻塞的对象的线程的 ID。 |
拥有阻塞线程的对象(如果有)的线程的名称。 |
线程的优先级。仅在 Java 9 或更高版本上可用。 |
线程的堆栈跟踪。 |
包含此条目标识的执行点(如果有)的类的类加载器的名称。仅在 Java 9 或更高版本上可用。 |
包含此条目标识的执行点的类的名称。 |
包含此条目标识的执行点的源文件的名称(如果有)。 |
此条目标识的执行点的行号。如果未知,则为阴性。 |
方法的名称。 |
包含此条目标识的执行点的模块的名称(如果有)。仅在 Java 9 或更高版本上可用。 |
包含此条目标识的执行点的模块版本(如果有)。仅在 Java 9 或更高版本上可用。 |
执行点是否为本机方法。 |
线程是否处于暂停状态。 |
线程的 ID。 |
线程的名称。 |
线程的状态 ( |
线程等待通知的总次数。 |
线程等待所花费的时间(以毫秒为单位)。如果禁用了线程争用监控,则为 -1 |
将线程转储作为文本检索
要将线程转储作为文本检索,请创建一个GET
那
接受text/plain
,如以下基于 curl 的示例所示:
-H 'Accept: text/plain'
生成的响应类似于以下内容:
HTTP/1.1 200 OK
Content-Type: text/plain;charset=UTF-8
Content-Length: 52819
2024-11-21 10:52:18
Full thread dump OpenJDK 64-Bit Server VM (17.0.13+12-LTS mixed mode, sharing):
"Test worker" - Thread t@1
java.lang.Thread.State: RUNNABLE
at [email protected]/sun.management.ThreadImpl.dumpThreads0(Native Method)
at [email protected]/sun.management.ThreadImpl.dumpAllThreads(ThreadImpl.java:528)
at [email protected]/sun.management.ThreadImpl.dumpAllThreads(ThreadImpl.java:516)
at app//org.springframework.boot.actuate.management.ThreadDumpEndpoint.getFormattedThreadDump(ThreadDumpEndpoint.java:52)
at app//org.springframework.boot.actuate.management.ThreadDumpEndpoint.textThreadDump(ThreadDumpEndpoint.java:48)
at [email protected]/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at [email protected]/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at [email protected]/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at [email protected]/java.lang.reflect.Method.invoke(Method.java:569)
at app//org.springframework.util.ReflectionUtils.invokeMethod(ReflectionUtils.java:281)
at app//org.springframework.boot.actuate.endpoint.invoke.reflect.ReflectiveOperationInvoker.invoke(ReflectiveOperationInvoker.java:74)
at app//org.springframework.boot.actuate.endpoint.annotation.AbstractDiscoveredOperation.invoke(AbstractDiscoveredOperation.java:60)
at app//org.springframework.boot.actuate.endpoint.web.servlet.AbstractWebMvcEndpointHandlerMapping$ServletWebOperationAdapter.handle(AbstractWebMvcEndpointHandlerMapping.java:327)
at app//org.springframework.boot.actuate.endpoint.web.servlet.AbstractWebMvcEndpointHandlerMapping$OperationHandler.handle(AbstractWebMvcEndpointHandlerMapping.java:434)
at jdk.internal.reflect.GeneratedMethodAccessor64.invoke(Unknown Source)
at app//org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:255)
at app//org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:188)
at app//org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:118)
at app//org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:926)
at app//org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:831)
at app//org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at app//org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1089)
at app//org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:979)
at app//org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1014)
at app//org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:903)
at app//jakarta.servlet.http.HttpServlet.service(HttpServlet.java:527)
at app//org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:885)
at app//org.springframework.test.web.servlet.TestDispatcherServlet.service(TestDispatcherServlet.java:72)
at app//jakarta.servlet.http.HttpServlet.service(HttpServlet.java:614)
at app//org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:165)
at app//org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:132)
at app//org.springframework.test.web.servlet.MockMvc.perform(MockMvc.java:201)
at app//org.springframework.boot.actuate.autoconfigure.endpoint.web.documentation.ThreadDumpEndpointDocumentationTests.textThreadDump(ThreadDumpEndpointDocumentationTests.java:182)
at app//org.junit.platform.commons.util.ReflectionUtils.invokeMethod(ReflectionUtils.java:728)
at app//org.junit.jupiter.engine.execution.MethodInvocation.proceed(MethodInvocation.java:60)
at app//org.junit.jupiter.engine.execution.InvocationInterceptorChain$ValidatingInvocation.proceed(InvocationInterceptorChain.java:131)
at app//org.junit.jupiter.engine.extension.TimeoutExtension.intercept(TimeoutExtension.java:156)
at app//org.junit.jupiter.engine.extension.TimeoutExtension.interceptTestableMethod(TimeoutExtension.java:147)
at app//org.junit.jupiter.engine.extension.TimeoutExtension.interceptTestMethod(TimeoutExtension.java:86)
at app//org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor$$Lambda$202/0x00007effa013d808.apply(Unknown Source)
at app//org.junit.jupiter.engine.execution.InterceptingExecutableInvoker$ReflectiveInterceptorCall.lambda$ofVoidMethod$0(InterceptingExecutableInvoker.java:103)
at app//org.junit.jupiter.engine.execution.InterceptingExecutableInvoker$ReflectiveInterceptorCall$$Lambda$203/0x00007effa013dc28.apply(Unknown Source)
at app//org.junit.jupiter.engine.execution.InterceptingExecutableInvoker.lambda$invoke$0(InterceptingExecutableInvoker.java:93)
at app//org.junit.jupiter.engine.execution.InterceptingExecutableInvoker$$Lambda$487/0x00007effa01ed5a0.apply(Unknown Source)
at app//org.junit.jupiter.engine.execution.InvocationInterceptorChain$InterceptedInvocation.proceed(InvocationInterceptorChain.java:106)
at app//org.junit.jupiter.engine.execution.InvocationInterceptorChain.proceed(InvocationInterceptorChain.java:64)
at app//org.junit.jupiter.engine.execution.InvocationInterceptorChain.chainAndInvoke(InvocationInterceptorChain.java:45)
at app//org.junit.jupiter.engine.execution.InvocationInterceptorChain.invoke(InvocationInterceptorChain.java:37)
at app//org.junit.jupiter.engine.execution.InterceptingExecutableInvoker.invoke(InterceptingExecutableInvoker.java:92)
at app//org.junit.jupiter.engine.execution.InterceptingExecutableInvoker.invoke(InterceptingExecutableInvoker.java:86)
at app//org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor.lambda$invokeTestMethod$7(TestMethodTestDescriptor.java:218)
at app//org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor$$Lambda$1032/0x00007effa062c878.execute(Unknown Source)
at app//org.junit.platform.engine.support.hierarchical.ThrowableCollector.execute(ThrowableCollector.java:73)
at app//org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor.invokeTestMethod(TestMethodTestDescriptor.java:214)
at app//org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor.execute(TestMethodTestDescriptor.java:139)
at app//org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor.execute(TestMethodTestDescriptor.java:69)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$6(NodeTestTask.java:156)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask$$Lambda$304/0x00007effa0159e50.execute(Unknown Source)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$8(NodeTestTask.java:146)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask$$Lambda$303/0x00007effa0159c28.invoke(Unknown Source)
at app//org.junit.platform.engine.support.hierarchical.Node.around(Node.java:137)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$9(NodeTestTask.java:144)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask$$Lambda$302/0x00007effa0159800.execute(Unknown Source)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask.executeRecursively(NodeTestTask.java:143)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask.execute(NodeTestTask.java:100)
at app//org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService$$Lambda$308/0x00007effa015a968.accept(Unknown Source)
at [email protected]/java.util.ArrayList.forEach(ArrayList.java:1511)
at app//org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService.invokeAll(SameThreadHierarchicalTestExecutorService.java:41)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$6(NodeTestTask.java:160)
at app//org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService.submit(SameThreadHierarchicalTestExecutorService.java:35)
at app//org.junit.platform.engine.support.hierarchical.HierarchicalTestExecutor.execute(HierarchicalTestExecutor.java:57)
at app//org.junit.platform.engine.support.hierarchical.HierarchicalTestEngine.execute(HierarchicalTestEngine.java:54)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator.execute(EngineExecutionOrchestrator.java:198)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator.execute(EngineExecutionOrchestrator.java:169)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator.execute(EngineExecutionOrchestrator.java:93)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator.lambda$execute$0(EngineExecutionOrchestrator.java:58)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator$$Lambda$257/0x00007effa0141240.accept(Unknown Source)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator.withInterceptedStreams(EngineExecutionOrchestrator.java:141)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator.execute(EngineExecutionOrchestrator.java:57)
at app//org.junit.platform.launcher.core.DefaultLauncher.execute(DefaultLauncher.java:103)
at app//org.junit.platform.launcher.core.DefaultLauncher.execute(DefaultLauncher.java:85)
at app//org.junit.platform.launcher.core.DelegatingLauncher.execute(DelegatingLauncher.java:47)
at org.gradle.api.internal.tasks.testing.junitplatform.JUnitPlatformTestClassProcessor$CollectAllTestClassesExecutor.processAllTestClasses(JUnitPlatformTestClassProcessor.java:124)
at org.gradle.api.internal.tasks.testing.junitplatform.JUnitPlatformTestClassProcessor$CollectAllTestClassesExecutor.access$000(JUnitPlatformTestClassProcessor.java:99)
at org.gradle.api.internal.tasks.testing.junitplatform.JUnitPlatformTestClassProcessor.stop(JUnitPlatformTestClassProcessor.java:94)
at org.gradle.api.internal.tasks.testing.SuiteTestClassProcessor.stop(SuiteTestClassProcessor.java:63)
at org.gradle.internal.dispatch.ReflectionDispatch.dispatch(ReflectionDispatch.java:36)
at org.gradle.internal.dispatch.ReflectionDispatch.dispatch(ReflectionDispatch.java:24)
at org.gradle.internal.dispatch.ContextClassLoaderDispatch.dispatch(ContextClassLoaderDispatch.java:33)
at org.gradle.internal.dispatch.ProxyDispatchAdapter$DispatchingInvocationHandler.invoke(ProxyDispatchAdapter.java:92)
at jdk.proxy1/jdk.proxy1.$Proxy4.stop(Unknown Source)
at org.gradle.api.internal.tasks.testing.worker.TestWorker$3.run(TestWorker.java:200)
at org.gradle.api.internal.tasks.testing.worker.TestWorker.executeAndMaintainThreadName(TestWorker.java:132)
at org.gradle.api.internal.tasks.testing.worker.TestWorker.execute(TestWorker.java:103)
at org.gradle.api.internal.tasks.testing.worker.TestWorker.execute(TestWorker.java:63)
at org.gradle.process.internal.worker.child.ActionExecutionWorker.execute(ActionExecutionWorker.java:56)
at org.gradle.process.internal.worker.child.SystemApplicationClassLoaderWorker.call(SystemApplicationClassLoaderWorker.java:121)
at org.gradle.process.internal.worker.child.SystemApplicationClassLoaderWorker.call(SystemApplicationClassLoaderWorker.java:71)
at app//worker.org.gradle.process.internal.worker.GradleWorkerMain.run(GradleWorkerMain.java:69)
at app//worker.org.gradle.process.internal.worker.GradleWorkerMain.main(GradleWorkerMain.java:74)
Locked ownable synchronizers:
- None
"Reference Handler" - Thread t@2
at [email protected]/java.lang.ref.Reference.waitForReferencePendingList(Native Method)
at [email protected]/java.lang.ref.Reference.processPendingReferences(Reference.java:253)
at [email protected]/java.lang.ref.Reference$ReferenceHandler.run(Reference.java:215)
- None
"Finalizer" - Thread t@3
java.lang.Thread.State: WAITING
at [email protected]/java.lang.Object.wait(Native Method)
- waiting on <5b2a690f> (a java.lang.ref.ReferenceQueue$Lock)
at [email protected]/java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:155)
at [email protected]/java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:176)
at [email protected]/java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:172)
- None
"Signal Dispatcher" - Thread t@4
- None
"Common-Cleaner" - Thread t@11
java.lang.Thread.State: TIMED_WAITING
- waiting on <380191d7> (a java.lang.ref.ReferenceQueue$Lock)
at [email protected]/jdk.internal.ref.CleanerImpl.run(CleanerImpl.java:140)
at [email protected]/java.lang.Thread.run(Thread.java:840)
at [email protected]/jdk.internal.misc.InnocuousThread.run(InnocuousThread.java:162)
- None
"Notification Thread" - Thread t@12
- None
"/127.0.0.1:42948 to /127.0.0.1:43053 workers" - Thread t@14
at [email protected]/jdk.internal.misc.Unsafe.park(Native Method)
- parking to wait for <537839b0> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at [email protected]/java.util.concurrent.locks.LockSupport.park(LockSupport.java:341)
at [email protected]/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionNode.block(AbstractQueuedSynchronizer.java:506)
at [email protected]/java.util.concurrent.ForkJoinPool.unmanagedBlock(ForkJoinPool.java:3465)
at [email protected]/java.util.concurrent.ForkJoinPool.managedBlock(ForkJoinPool.java:3436)
at [email protected]/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:1630)
at org.gradle.internal.remote.internal.hub.queue.EndPointQueue.take(EndPointQueue.java:49)
at org.gradle.internal.remote.internal.hub.MessageHub$Handler.run(MessageHub.java:403)
at org.gradle.internal.concurrent.ExecutorPolicy$CatchAndRecordFailures.onExecute(ExecutorPolicy.java:64)
at org.gradle.internal.concurrent.AbstractManagedExecutor$1.run(AbstractManagedExecutor.java:48)
at [email protected]/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at [email protected]/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
- Locked <193f604a> (a java.util.concurrent.ThreadPoolExecutor$Worker)
"/127.0.0.1:42948 to /127.0.0.1:43053 workers Thread 2" - Thread t@15
- parking to wait for <786332de> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at org.gradle.internal.remote.internal.hub.MessageHub$ConnectionDispatch.run(MessageHub.java:322)
- Locked <6fd83fc1> (a java.util.concurrent.ThreadPoolExecutor$Worker)
"/127.0.0.1:42948 to /127.0.0.1:43053 workers Thread 3" - Thread t@16
at [email protected]/sun.nio.ch.EPoll.wait(Native Method)
at [email protected]/sun.nio.ch.EPollSelectorImpl.doSelect(EPollSelectorImpl.java:118)
at [email protected]/sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:129)
- locked <70895ecc> (a sun.nio.ch.Util$2)
- locked <5615f2ac> (a sun.nio.ch.EPollSelectorImpl)
at [email protected]/sun.nio.ch.SelectorImpl.select(SelectorImpl.java:146)
at org.gradle.internal.remote.internal.inet.SocketConnection$SocketInputStream.read(SocketConnection.java:190)
at com.esotericsoftware.kryo.io.Input.fill(Input.java:146)
at com.esotericsoftware.kryo.io.Input.require(Input.java:178)
at com.esotericsoftware.kryo.io.Input.readByte(Input.java:295)
at org.gradle.internal.serialize.kryo.KryoBackedDecoder.readByte(KryoBackedDecoder.java:88)
at org.gradle.internal.remote.internal.hub.InterHubMessageSerializer$MessageReader.read(InterHubMessageSerializer.java:64)
at org.gradle.internal.remote.internal.hub.InterHubMessageSerializer$MessageReader.read(InterHubMessageSerializer.java:52)
at org.gradle.internal.remote.internal.inet.SocketConnection.receive(SocketConnection.java:86)
at org.gradle.internal.remote.internal.hub.MessageHub$ConnectionReceive.run(MessageHub.java:270)
- Locked <e15b7e8> (a java.util.concurrent.ThreadPoolExecutor$Worker)
"process reaper" - Thread t@20
- parking to wait for <3701df72> (a java.util.concurrent.SynchronousQueue$TransferStack)
at [email protected]/java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:252)
at [email protected]/java.util.concurrent.SynchronousQueue$TransferStack.transfer(SynchronousQueue.java:401)
at [email protected]/java.util.concurrent.SynchronousQueue.poll(SynchronousQueue.java:903)
at [email protected]/java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1061)
at [email protected]/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1122)
- None
"Attach Listener" - Thread t@21
- None
"HikariPool-1 housekeeper" - Thread t@29
- parking to wait for <d449860> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at [email protected]/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:1679)
at [email protected]/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1182)
at [email protected]/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:899)
at [email protected]/java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1062)
- None
"boundedElastic-evictor-1" - Thread t@40
- parking to wait for <5e14f405> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
- None
"reactor-http-epoll-1" - Thread t@41
at app//io.netty.channel.epoll.Native.epollWait(Native Method)
at app//io.netty.channel.epoll.Native.epollWait(Native.java:220)
at app//io.netty.channel.epoll.Native.epollWait(Native.java:213)
at app//io.netty.channel.epoll.EpollEventLoop.epollWaitNoTimerChange(EpollEventLoop.java:308)
at app//io.netty.channel.epoll.EpollEventLoop.run(EpollEventLoop.java:365)
at app//io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:997)
at app//io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74)
at app//io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30)
- None
"server" - Thread t@42
- parking to wait for <27edfdf9> (a java.util.concurrent.CountDownLatch$Sync)
at [email protected]/java.util.concurrent.locks.LockSupport.park(LockSupport.java:211)
at [email protected]/java.util.concurrent.locks.AbstractQueuedSynchronizer.acquire(AbstractQueuedSynchronizer.java:715)
at [email protected]/java.util.concurrent.locks.AbstractQueuedSynchronizer.acquireSharedInterruptibly(AbstractQueuedSynchronizer.java:1047)
at [email protected]/java.util.concurrent.CountDownLatch.await(CountDownLatch.java:230)
at app//reactor.core.publisher.BlockingSingleSubscriber.blockingGet(BlockingSingleSubscriber.java:91)
at app//reactor.core.publisher.Mono.block(Mono.java:1779)
at app//org.springframework.boot.web.embedded.netty.NettyWebServer$1.run(NettyWebServer.java:229)
- None
"reactor-http-epoll-2" - Thread t@43
- None
"reactor-http-epoll-3" - Thread t@44
- None
"reactor-http-epoll-4" - Thread t@45
- None
"boundedElastic-1" - Thread t@46
- parking to wait for <1e2e5c39> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at [email protected]/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1170)
- None
"Catalina-utility-1" - Thread t@48
- parking to wait for <37805004> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at app//org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:63)
- None
"container-0" - Thread t@49
at [email protected]/java.lang.Thread.sleep(Native Method)
at app//org.apache.catalina.core.StandardServer.await(StandardServer.java:520)
at app//org.springframework.boot.web.embedded.tomcat.TomcatWebServer$1.run(TomcatWebServer.java:219)
- None
"Catalina-utility-2" - Thread t@50
at [email protected]/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1177)
- None
"http-nio-auto-1-exec-1" - Thread t@51
- parking to wait for <4e4d2e2d> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at [email protected]/java.util.concurrent.LinkedBlockingQueue.take(LinkedBlockingQueue.java:435)
at app//org.apache.tomcat.util.threads.TaskQueue.take(TaskQueue.java:117)
at app//org.apache.tomcat.util.threads.TaskQueue.take(TaskQueue.java:33)
at app//org.apache.tomcat.util.threads.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1114)
at app//org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1175)
at app//org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
- None
"http-nio-auto-1-exec-2" - Thread t@52
- None
"http-nio-auto-1-exec-3" - Thread t@53
- None
"http-nio-auto-1-exec-4" - Thread t@54
- None
"http-nio-auto-1-exec-5" - Thread t@55
- None
"http-nio-auto-1-exec-6" - Thread t@56
- None
"http-nio-auto-1-exec-7" - Thread t@57
- None
"http-nio-auto-1-exec-8" - Thread t@58
- None
"http-nio-auto-1-exec-9" - Thread t@59
- None
"http-nio-auto-1-exec-10" - Thread t@60
- None
"http-nio-auto-1-Poller" - Thread t@61
- locked <6870028> (a sun.nio.ch.Util$2)
- locked <6aa45b55> (a sun.nio.ch.EPollSelectorImpl)
at [email protected]/sun.nio.ch.SelectorImpl.select(SelectorImpl.java:141)
at app//org.apache.tomcat.util.net.NioEndpoint$Poller.run(NioEndpoint.java:755)
- None
"http-nio-auto-1-Acceptor" - Thread t@62
at [email protected]/sun.nio.ch.Net.accept(Native Method)
at [email protected]/sun.nio.ch.ServerSocketChannelImpl.implAccept(ServerSocketChannelImpl.java:425)
at [email protected]/sun.nio.ch.ServerSocketChannelImpl.accept(ServerSocketChannelImpl.java:391)
at app//org.apache.tomcat.util.net.NioEndpoint.serverSocketAccept(NioEndpoint.java:518)
at app//org.apache.tomcat.util.net.NioEndpoint.serverSocketAccept(NioEndpoint.java:71)
at app//org.apache.tomcat.util.net.Acceptor.run(Acceptor.java:128)
- Locked <5f113675> (a java.util.concurrent.locks.ReentrantLock$NonfairSync)
"pool-4-thread-1" - Thread t@69
at [email protected]/java.time.Instant.create(Instant.java:415)
at [email protected]/java.time.Instant.ofEpochSecond(Instant.java:332)
at [email protected]/java.time.Clock.currentInstant(Clock.java:527)
at [email protected]/java.time.Instant.now(Instant.java:275)
at app//org.springframework.boot.actuate.autoconfigure.endpoint.web.documentation.ScheduledTasksEndpointDocumentationTests$TestConfiguration$CustomTrigger.nextExecution(ScheduledTasksEndpointDocumentationTests.java:120)
at app//org.springframework.scheduling.concurrent.ReschedulingRunnable.schedule(ReschedulingRunnable.java:78)
- locked <788a47fc> (a java.lang.Object)
at app//org.springframework.scheduling.concurrent.ReschedulingRunnable.run(ReschedulingRunnable.java:102)
at [email protected]/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
at [email protected]/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at [email protected]/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
- Locked <20003af7> (a java.util.concurrent.ThreadPoolExecutor$Worker)
