启用 STOMP
STOMP over WebSocket 支持在spring-messagingspring-websocket模块。拥有这些依赖项后,就可以公开 STOMP endpoint,如下例所示:spring-doc.cadn.net.cn
@EnableWebSocketMessageBroker
public class WebSocketConfiguration implements WebSocketMessageBrokerConfigurer {
	public void registerStompEndpoints(StompEndpointRegistry registry) {
		// /portfolio is the HTTP URL for the endpoint to which a WebSocket (or SockJS)
		// client needs to connect for the WebSocket handshake
		registry.addEndpoint("/portfolio");
	public void configureMessageBroker(MessageBrokerRegistry config) {
		// STOMP messages whose destination header begins with /app are routed to
		// @MessageMapping methods in @Controller classes
		config.setApplicationDestinationPrefixes("/app");
		// Use the built-in message broker for subscriptions and broadcasting and
		// route messages whose destination header begins with /topic or /queue to the broker
		config.enableSimpleBroker("/topic", "/queue");
class WebSocketConfiguration : WebSocketMessageBrokerConfigurer {
	override fun registerStompEndpoints(registry: StompEndpointRegistry) {
	override fun configureMessageBroker(config: MessageBrokerRegistry) {
	   xmlns:websocket="http://www.springframework.org/schema/websocket"
	   xsi:schemaLocation="
			https://www.springframework.org/schema/websocket/spring-websocket.xsd">
	<websocket:message-broker application-destination-prefix="/app">
		<websocket:stomp-endpoint path="/portfolio" />
		<websocket:simple-broker prefix="/topic, /queue"/>
	</websocket:message-broker>
</beans>
对于内置的 simple broker,/topic/queue前缀没有任何特殊的 意义。它们只是区分 pub-sub 和 point-to-point 的约定 消息收发(即,多个订阅者与 1 个使用者)。当您使用外部代理时, 检查代理的 STOMP 页面以了解哪种类型的 STOMP 目标和 它支持的前缀。
要从浏览器进行连接,对于 STOMP,您可以使用stomp-js/stompjs哪个是最 积极维护的 JavaScript 库。spring-doc.cadn.net.cn
以下示例代码基于它:spring-doc.cadn.net.cn
const stompClient = new StompJs.Client({
       brokerURL: 'ws://domain.com/portfolio',
       onConnect: () => {
或者,如果你通过 Sockjs 连接,你可以在服务器端启用 Sockjs 回退registry.addEndpoint("/portfolio").withSockJS()在 JavaScript 方面, 按照这些说明进行作。spring-doc.cadn.net.cn
请注意,stompClient在前面的示例中不需要指定loginpasscode头。即使这样做了,他们也会被忽略(或者更确切地说, overridden) 的有关身份验证的更多信息,请参见Connecting to a Broker and Authenticationspring-doc.cadn.net.cn
有关更多示例代码,请参阅:spring-doc.cadn.net.cn
