过滤器
您可以通过 注册客户端过滤器 () 以拦截和修改请求,如下例所示:ExchangeFilterFunction
WebClient.Builder
Java
Kotlin
WebClient client = WebClient.builder()
.filter((request, next) -> {
ClientRequest filtered = ClientRequest.from(request)
.header("foo", "bar")
return next.exchange(filtered);
val client = WebClient.builder()
.filter { request, next ->
val filtered = ClientRequest.from(request)
.build()
.build()
这可用于横切关注点,例如身份验证。以下示例使用 通过静态工厂方法进行基本身份验证的过滤器:
Java
Kotlin
import static org.springframework.web.reactive.function.client.ExchangeFilterFunctions.basicAuthentication;
.filter(basicAuthentication("user", "password"))
import org.springframework.web.reactive.function.client.ExchangeFilterFunctions.basicAuthentication
.build()
可以通过更改现有实例来添加或删除过滤器,从而
在不影响原始实例的新实例中。例如:WebClient
WebClient
Java
Kotlin
WebClient client = webClient.mutate()
.filters(filterList -> {
filterList.add(0, basicAuthentication("user", "password"));
val client = webClient.mutate()
.filters { it.add(0, basicAuthentication("user", "password")) }
.build()
WebClient
是围绕过滤器链的薄立面,后跟 .它提供了一个工作流来发出请求、编码到更高级别或从更高级别编码
level 对象,它有助于确保始终使用响应内容。
当 filter 以某种方式处理响应时,必须格外小心地始终使用
其内容或以其他方式将其传播到下游,这将确保
一样。下面是一个处理状态代码的筛选器,但确保
任何响应内容(无论是否预期)都会被释放:ExchangeFunction
WebClient
UNAUTHORIZED
Java
Kotlin
public ExchangeFilterFunction renewTokenFilter() {
return (request, next) -> next.exchange(request).flatMap(response -> {
if (response.statusCode().value() == HttpStatus.UNAUTHORIZED.value()) {
return response.releaseBody()
.then(renewToken())
.flatMap(token -> {
ClientRequest newRequest = ClientRequest.from(request).build();
return next.exchange(newRequest);
} else {
return Mono.just(response);
fun renewTokenFilter(): ExchangeFilterFunction? {
return ExchangeFilterFunction { request: ClientRequest?, next: ExchangeFunction ->
next.exchange(request!!).flatMap { response: ClientResponse ->
return@flatMap response.releaseBody()
.then(renewToken())
.flatMap { token: String? ->
val newRequest = ClientRequest.from(request).build()
} else {
return@flatMap Mono.just(response)
下面的示例演示了如何使用接口创建
一个自定义 Filter 类,可帮助使用缓冲计算 AND 请求的标头。ExchangeFilterFunction
Content-Length
PUT
POST
multipart/form-data
Java
Kotlin
public class MultipartExchangeFilterFunction implements ExchangeFilterFunction {
public Mono<ClientResponse> filter(ClientRequest request, ExchangeFunction next) {
if (MediaType.MULTIPART_FORM_DATA.includes(request.headers().getContentType())
&& (request.method() == HttpMethod.PUT || request.method() == HttpMethod.POST)) {
return next.exchange(ClientRequest.from(request).body((outputMessage, context) ->
request.body().insert(new BufferingDecorator(outputMessage), context)).build()
} else {
return next.exchange(request);
private static final class BufferingDecorator extends ClientHttpRequestDecorator {
private BufferingDecorator(ClientHttpRequest delegate) {
super(delegate);
public Mono<Void> writeWith(Publisher<? extends DataBuffer> body) {
return DataBufferUtils.join(body).flatMap(buffer -> {
getHeaders().setContentLength(buffer.readableByteCount());
return super.writeWith(Mono.just(buffer));
class MultipartExchangeFilterFunction : ExchangeFilterFunction {
override fun filter(request: ClientRequest, next: ExchangeFunction): Mono<ClientResponse> {
return if (MediaType.MULTIPART_FORM_DATA.includes(request.headers().getContentType())
.body { message, context -> request.body().insert(BufferingDecorator(message), context) }
.build())
else {
private class BufferingDecorator(delegate: ClientHttpRequest) : ClientHttpRequestDecorator(delegate) {
override fun writeWith(body: Publisher<out DataBuffer>): Mono<Void> {
.flatMap {
headers.contentLength = it.readableByteCount().toLong()
super.writeWith(Mono.just(it))
