For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Receiving Batched Messages
With the RabbitMQ binder, there are two types of batches handled by consumer bindings:spring-doc.cn
Batches Created by Producers
Normally, if a producer binding has batch-enabled=true (see Rabbit Producer Properties), or a message is created by a BatchingRabbitTemplate, elements of the batch are returned as individual calls to the listener method. Starting with version 3.0, any such batch can be presented as a List<?> to the listener method if spring.cloud.stream.bindings.<name>.consumer.batch-mode is set to true.spring-doc.cn
Consumer-side Batching
Starting with version 3.1, the consumer can be configured to assemble multiple inbound messages into a batch which is presented to the application as a List<?> of converted payloads. The following simple application demonstrates how to use this technique:spring-doc.cn
spring.cloud.stream.bindings.input-in-0.group=someGroup
spring.cloud.stream.bindings.input-in-0.consumer.batch-mode=true
spring.cloud.stream.rabbit.bindings.input-in-0.consumer.enable-batching=true
spring.cloud.stream.rabbit.bindings.input-in-0.consumer.batch-size=10
spring.cloud.stream.rabbit.bindings.input-in-0.consumer.receive-timeout=200
@SpringBootApplication
public class Application {
		SpringApplication.run(Application.class, args);
	Consumer<List<Thing>> input() {
		return list -> {
			System.out.println("Received " + list.size());
			list.forEach(thing -> {
				System.out.println(thing);
	public ApplicationRunner runner(RabbitTemplate template) {
		return args -> {
			template.convertAndSend("input-in-0.someGroup", "{\"field\":\"value1\"}");
			template.convertAndSend("input-in-0.someGroup", "{\"field\":\"value2\"}");
	public static class Thing {
		private String field;
		public Thing() {
		public Thing(String field) {
			this.field = field;
		public String getField() {
			return this.field;
		public void setField(String field) {
			this.field = field;
		public String toString() {
			return "Thing [field=" + this.field + "]";
Received 2
Thing [field=value1]
Thing [field=value2]
The number of messages in a batch is specified by the batch-size and receive-timeout properties; if the receive-timeout elapses with no new messages, a "short" batch is delivered.spring-doc.cn
Consumer-side batching is only supported with container-type=simple (the default).
If you wish to examine headers of consumer-side batched messages, you should consume Message<List<?>>; the headers are a List<Map<String, Object>> in a header AmqpInboundChannelAdapter.CONSOLIDATED_HEADERS, with the headers for each payload element in the corresponding index. Again, here is a simple example:spring-doc.cn
	Consumer<Message<List<Thing>>> input() {
		return msg -> {
			List<Thing> things = msg.getPayload();
			System.out.println("Received " + things.size());
			List<Map<String, Object>> headers =
					(List<Map<String, Object>>) msg.getHeaders().get(AmqpInboundChannelAdapter.CONSOLIDATED_HEADERS);
			for (int i = 0; i < things.size(); i++) {
				System.out.println(things.get(i) + " myHeader=" + headers.get(i).get("myHeader"));
		return args -> {
			template.convertAndSend("input-in-0.someGroup", "{\"field\":\"value1\"}", msg -> {
				msg.getMessageProperties().setHeader("myHeader", "headerValue1");
				return msg;
			template.convertAndSend("input-in-0.someGroup", "{\"field\":\"value2\"}", msg -> {
				msg.getMessageProperties().setHeader("myHeader", "headerValue2");
				return msg;
		public Thing() {
			this.field = field;
		public String getfield() {
			return this.field;
		public void setfield(String field) {
			this.field = field;
Received 2
Thing [field=value1] myHeader=headerValue1
Thing [field=value2] myHeader=headerValue2
