For the latest stable version, please use spring-cloud-stream 4.2.0! |
Interactive Queries
Kafka Streams binder API exposes a class called InteractiveQueryService
to interactively query the state stores.
You can access this as a Spring bean in your application. An easy way to get access to this bean from your application is to autowire
the bean.
@Autowired
private InteractiveQueryService interactiveQueryService;
Once you gain access to this bean, then you can query for the particular state-store that you are interested. See below.
ReadOnlyKeyValueStore<Object, Object> keyValueStore =
interactiveQueryService.getQueryableStoreType("my-store", QueryableStoreTypes.keyValueStore());
During the startup, the above method call to retrieve the store might fail. For example, it might still be in the middle of initializing the state store. In such cases, it will be useful to retry this operation. Kafka Streams binder provides a simple retry mechanism to accommodate this.
Following are the two properties that you can use to control this retrying.
spring.cloud.stream.kafka.streams.binder.stateStoreRetry.maxAttempts - Default is
1
spring.cloud.stream.kafka.streams.binder.stateStoreRetry.backOffInterval - Default is
1000
milliseconds.
If there are multiple instances of the kafka streams application running, then before you can query them interactively, you need to identify which application instance hosts the particular key that you are querying.
API provides methods for identifying the host information.
In order for this to work, you must configure the property application.server
as below:
spring.cloud.stream.kafka.streams.binder.configuration.application.server: <server>:<port>
Here are some code snippets:
org.apache.kafka.streams.state.HostInfo hostInfo = interactiveQueryService.getHostInfo("store-name",
key, keySerializer);
if (interactiveQueryService.getCurrentHostInfo().equals(hostInfo)) {
//query from the store that is locally available
else {
//query from the remote host
For more information on these host finding methods, please see the Javadoc on the methods. For these methods also, during startup, if the underlying KafkaStreams objects are not ready, they might throw exceptions. The aforementioned retry properties are applicable for these methods as well.
Other API methods available through the InteractiveQueryService
Use the following API method to retrieve the KeyQueryMetadata
object associated with the combination of given store and key.
public <K> KeyQueryMetadata getKeyQueryMetadata(String store, K key, Serializer<K> serializer)
Use the following API method to retrieve the KakfaStreams
public <K> KafkaStreams getKafkaStreams(String store, K key, Serializer<K> serializer)
Customizing Store Query Parameters
Sometimes it is necessary that you need to fine tune the store query parameters before querying the store through InteractiveQueryService
For this purpose, starting with the 4.0.1
version of the binder, you can provide a bean for StoreQueryParametersCustomizer
which is a functional interface with a customize
method that takes a StoreQueryParameter
as the argument.
Here is its method signature.
StoreQueryParameters<T> customize(StoreQueryParameters<T> storeQueryParameters);
Using this approach, applications can further customize the StoreQueryParameters
such as enabling stale stores.
When this bean is present in this application, InteractiveQueryService
will call its customize
method before querying the state store.
Keep in mind that, there must be a unique bean for StoreQueryParametersCustomizer available in the application.
