For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Testing
Spring Cloud Stream provides support for testing your microservice applications without connecting to a messaging system.spring-doc.cn
Spring Integration Test Binder
Spring Cloud Stream comes with a test binder which you can use for testing the various application components without requiring an actual real-world binder implementation or a message broker.spring-doc.cn
This test binder acts as a bridge between unit and integration testing and is based on Spring Integration framework as an in-JVM message broker essentially giving you the best of both worlds - a real binder without the networking.spring-doc.cn
Test Binder configuration
To enable Spring Integration test binder, you need to add it as a dependency and annotate your class with @EnableTestBinder.spring-doc.cn
Add required dependenciesspring-doc.cn
Below is the example of the required Maven POM entries.spring-doc.cn
<dependency>
	<artifactId>spring-cloud-stream-test-binder</artifactId>
	<scope>test</scope>
</dependency>
Or for build.gradle.ktsspring-doc.cn
testImplementation("org.springframework.cloud:spring-cloud-stream-test-binder")
Test Binder usage
Now you can test your microservice as a simple unit test. To enable the Test Binder, annotate your class with @EnableTestBinder.spring-doc.cn
@SpringBootTest
public class SampleStreamTests {
	@Autowired
	private InputDestination input;
	@Autowired
	private OutputDestination output;
	@Test
	public void testEmptyConfiguration() {
		this.input.send(new GenericMessage<byte[]>("hello".getBytes()));
		assertThat(output.receive().getPayload()).isEqualTo("HELLO".getBytes());
	@SpringBootApplication
	@EnableTestBinder
	public static class SampleConfiguration {
		public Function<String, String> uppercase() {
			return v -> v.toUpperCase();
And if you need more control or want to test several configurations in the same test suite you can also do the following:spring-doc.cn
@EnableAutoConfiguration
public static class MyTestConfiguration {
@Test
public void sampleTest() {
	try (ConfigurableApplicationContext context = new SpringApplicationBuilder(
				TestChannelBinderConfiguration.getCompleteConfiguration(
						MyTestConfiguration.class))
				.run("--spring.cloud.function.definition=uppercase")) {
		InputDestination source = context.getBean(InputDestination.class);
		OutputDestination target = context.getBean(OutputDestination.class);
		source.send(new GenericMessage<byte[]>("hello".getBytes()));
		assertThat(target.receive().getPayload()).isEqualTo("HELLO".getBytes());
For cases where you have multiple bindings and/or multiple inputs and outputs, or simply want to be explicit about names of the destination you are sending to or receiving from, the send() and receive() methods of InputDestination and OutputDestination are overridden to allow you to provide the name of the input and output destination.spring-doc.cn
Consider the following sample:spring-doc.cn
public static class SampleFunctionConfiguration {
		return value -> value.toUpperCase();
	public Function<String, String> reverse() {
		return value -> new StringBuilder(value).reverse().toString();
and the actual testspring-doc.cn
@Test
public void testMultipleFunctions() {
					SampleFunctionConfiguration.class))
							.run("--spring.cloud.function.definition=uppercase;reverse")) {
		InputDestination inputDestination = context.getBean(InputDestination.class);
		OutputDestination outputDestination = context.getBean(OutputDestination.class);
		Message<byte[]> inputMessage = MessageBuilder.withPayload("Hello".getBytes()).build();
		inputDestination.send(inputMessage, "uppercase-in-0");
		inputDestination.send(inputMessage, "reverse-in-0");
		Message<byte[]> outputMessage = outputDestination.receive(0, "uppercase-out-0");
		assertThat(outputMessage.getPayload()).isEqualTo("HELLO".getBytes());
		outputMessage = outputDestination.receive(0, "reverse-out-0");
		assertThat(outputMessage.getPayload()).isEqualTo("olleH".getBytes());
For cases where you have additional mapping properties such as destination you should use those names. For example, consider a different version of the preceding test where we explicitly map inputs and outputs of the uppercase function to myInput and myOutput binding names:spring-doc.cn
@Test
							.run(
							"--spring.cloud.function.definition=uppercase;reverse",
							"--spring.cloud.stream.bindings.uppercase-in-0.destination=myInput",
							"--spring.cloud.stream.bindings.uppercase-out-0.destination=myOutput"
		inputDestination.send(inputMessage, "myInput");
		Message<byte[]> outputMessage = outputDestination.receive(0, "myOutput");
Test Binder and PollableMessageSource
Spring Integration Test Binder also allows you to write tests when working with PollableMessageSource (see [Using Polled Consumers] for more details).spring-doc.cn
The important thing that needs to be understood though is that polling is not event-driven, and that PollableMessageSource is a strategy which exposes operation to produce (poll for) a Message (singular). How often you poll or how many threads you use or where you’re polling from (message queue or file system) is entirely up to you; In other words it is your responsibility to configure Poller or Threads or the actual source of Message. Luckily Spring has plenty of abstractions to configure exactly that.spring-doc.cn
Let’s look at the example:spring-doc.cn
@Test
public void samplePollingTest() {
	ApplicationContext context = new SpringApplicationBuilder(SamplePolledConfiguration.class)
				.web(WebApplicationType.NONE)
				.run("--spring.jmx.enabled=false", "--spring.cloud.stream.pollable-source=myDestination");
	OutputDestination destination = context.getBean(OutputDestination.class);
	System.out.println("Message 1: " + new String(destination.receive().getPayload()));
	System.out.println("Message 2: " + new String(destination.receive().getPayload()));
	System.out.println("Message 3: " + new String(destination.receive().getPayload()));
@EnableTestBinder
public static class SamplePolledConfiguration {
	public ApplicationRunner poller(PollableMessageSource polledMessageSource, StreamBridge output, TaskExecutor taskScheduler) {
		return args -> {
			taskScheduler.execute(() -> {
				for (int i = 0; i < 3; i++) {
					try {
						if (!polledMessageSource.poll(m -> {
							String newPayload = ((String) m.getPayload()).toUpperCase();
							output.send("myOutput", newPayload);
							Thread.sleep(2000);
					catch (Exception e) {
						// handle failure
The above (very rudimentary) example will produce 3 messages in 2 second intervals sending them to the output destination of Source which this binder sends to OutputDestination where we retrieve them (for any assertions). Currently, it prints the following:spring-doc.cn
Message 1: POLLED DATA
Message 2: POLLED DATA
Message 3: POLLED DATA
As you can see the data is the same. That is because this binder defines a default implementation of the actual MessageSource - the source from which the Messages are polled using poll() operation. While sufficient for most testing scenarios, there are cases where you may want to define your own MessageSource. To do so simply configure a bean of type MessageSource in your test configuration providing your own implementation of Message sourcing.spring-doc.cn
Here is the example:spring-doc.cn
public MessageSource<?> source() {
	return () -> new GenericMessage<>("My Own Data " + UUID.randomUUID());
rendering the following output;spring-doc.cn
Message 1: MY OWN DATA 1C180A91-E79F-494F-ABF4-BA3F993710DA
Message 2: MY OWN DATA D8F3A477-5547-41B4-9434-E69DA7616FEE
Message 3: MY OWN DATA 20BF2E64-7FF4-4CB6-A823-4053D30B5C74
DO NOT name this bean messageSource as it is going to be in conflict with the bean of the same name (different type) provided by Spring Boot for unrelated reasons.
