For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Advanced Listener Container Configuration
To set listener container properties that are not exposed as binder or binding properties, add a single bean of type ListenerContainerCustomizer to the application context. The binder and binding properties will be set and then the customizer will be called. The customizer (configure() method) is provided with the queue name as well as the consumer group as arguments.spring-doc.cn
