For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Partitioning with the RabbitMQ Binder
RabbitMQ does not support partitioning natively.spring-doc.cn
Sometimes, it is advantageous to send data to specific partitions — for example, when you want to strictly order message processing, all messages for a particular customer should go to the same partition.spring-doc.cn
The RabbitMessageChannelBinder provides partitioning by binding a queue for each partition to the destination exchange.spring-doc.cn
The following Java and YAML examples show how to configure the producer:spring-doc.cn
Producer
@SpringBootApplication
public class RabbitPartitionProducerApplication {
    private static final Random RANDOM = new Random(System.currentTimeMillis());
    private static final String[] data = new String[] {
            "abc1", "def1", "qux1",
            "abc2", "def2", "qux2",
            "abc3", "def3", "qux3",
            "abc4", "def4", "qux4",
        new SpringApplicationBuilder(RabbitPartitionProducerApplication.class)
            .web(false)
            .run(args);
    public Supplier<Message<?>> generate() {
        return () -> {
            String value = data[RANDOM.nextInt(data.length)];
            System.out.println("Sending: " + value);
            return MessageBuilder.withPayload(value)
                    .setHeader("partitionKey", value)
application.yml
    spring:
      cloud:
        stream:
          bindings:
            generate-out-0:
              destination: partitioned.destination
              producer:
                partitioned: true
                partition-key-expression: headers['partitionKey']
                partition-count: 2
                required-groups:
                - myGroup
The configuration in the prececing example uses the default partitioning (key.hashCode() % partitionCount). This may or may not provide a suitably balanced algorithm, depending on the key values. You can override this default by using the partitionSelectorExpression or partitionSelectorClass properties.spring-doc.cn
The required-groups property is required only if you need the consumer queues to be provisioned when the producer is deployed. Otherwise, any messages sent to a partition are lost until the corresponding consumer is deployed.spring-doc.cn
The following configuration provisions a topic exchange:spring-doc.cn
part exchange
The following queues are bound to that exchange:spring-doc.cn
part queues
The following bindings associate the queues to the exchange:spring-doc.cn
part bindings
The following Java and YAML examples continue the previous examples and show how to configure the consumer:spring-doc.cn
Consumer
public class RabbitPartitionConsumerApplication {
        new SpringApplicationBuilder(RabbitPartitionConsumerApplication.class)
            .web(false)
            .run(args);
    public Consumer<Message<String>> listen() {
        return message -> {
            String queue =- message.getHeaders().get(AmqpHeaders.CONSUMER_QUEUE);
            System.out.println(in + " received from queue " + queue);
application.yml
    spring:
      cloud:
        stream:
          bindings:
            listen-in-0:
              group: myGroup
              consumer:
                partitioned: true
                instance-index: 0
The RabbitMessageChannelBinder does not support dynamic scaling. There must be at least one consumer per partition. The consumer’s instanceIndex is used to indicate which partition is consumed. Platforms such as Cloud Foundry can have only one instance with an instanceIndex.
