For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
RabbitMQ Binder Properties
By default, the RabbitMQ binder uses Spring Boot’s ConnectionFactory. Conseuqently, it supports all Spring Boot configuration options for RabbitMQ. (For reference, see the Spring Boot documentation). RabbitMQ configuration options use the spring.rabbitmq prefix.spring-doc.cn
In addition to Spring Boot options, the RabbitMQ binder supports the following properties:spring-doc.cn
spring.cloud.stream.rabbit.binder.adminAddresses
A comma-separated list of RabbitMQ management plugin URLs. Only used when nodes contains more than one entry. Each entry in this list must have a corresponding entry in spring.rabbitmq.addresses. Only needed if you use a RabbitMQ cluster and wish to consume from the node that hosts the queue. See Queue Affinity and the LocalizedQueueConnectionFactory for more information.spring-doc.cn
Default: empty.spring-doc.cn
spring.cloud.stream.rabbit.binder.nodes
A comma-separated list of RabbitMQ node names. When more than one entry, used to locate the server address where a queue is located. Each entry in this list must have a corresponding entry in spring.rabbitmq.addresses. Only needed if you use a RabbitMQ cluster and wish to consume from the node that hosts the queue. See Queue Affinity and the LocalizedQueueConnectionFactory for more information.spring-doc.cn
spring.cloud.stream.rabbit.binder.compressionLevel
The compression level for compressed bindings. See java.util.zip.Deflater.spring-doc.cn
Default: 1 (BEST_LEVEL).spring-doc.cn
spring.cloud.stream.binder.connection-name-prefix
A connection name prefix used to name the connection(s) created by this binder. The name is this prefix followed by #n, where n increments each time a new connection is opened.spring-doc.cn
Default: none (Spring AMQP default).spring-doc.cn
