For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Usage
For using the Kafka Streams binder, you just need to add it to your Spring Cloud Stream application, using the following maven coordinates:spring-doc.cn
<dependency>
  <artifactId>spring-cloud-stream-binder-kafka-streams</artifactId>
</dependency>
A quick way to bootstrap a new project for Kafka Streams binder is to use Spring Initializr and then select "Cloud Streams" and "Spring for Kafka Streams" as shown belowspring-doc.cn
