For the latest stable version, please use spring-cloud-stream 4.2.0! |
The Binder Abstraction
Spring Cloud Stream provides Binder implementations for Kafka and Rabbit MQ. The framework also includes a test binder for integration testing of your applications as spring-cloud-stream application. See [Testing] section for more details.
Binder abstraction is also one of the extension points of the framework, which means you can implement your own binder on top of Spring Cloud Stream.
In the How to create a Spring Cloud Stream Binder from scratch post a community member documents
in details, with an example, a set of steps necessary to implement a custom binder.
The steps are also highlighted in the Implementing Custom Binders
section.
Spring Cloud Stream uses Spring Boot for configuration, and the Binder abstraction makes it possible for a Spring Cloud Stream application to be flexible in how it connects to middleware.
For example, deployers can dynamically choose, at runtime, the mapping between the external destinations (such as the Kafka topics or RabbitMQ exchanges) and inputs
and outputs of the message handler (such as input parameter of the function and its return argument).
Such configuration can be provided through external configuration properties and in any form supported by Spring Boot (including application arguments, environment variables, and application.yml
or application.properties
files).
In the sink example from the Introducing Spring Cloud Stream section, setting the spring.cloud.stream.bindings.input.destination
application property to raw-sensor-data
causes it to read from the raw-sensor-data
Kafka topic or from a queue bound to the raw-sensor-data
RabbitMQ exchange.
Spring Cloud Stream automatically detects and uses a binder found on the classpath. You can use different types of middleware with the same code. To do so, include a different binder at build time. For more complex use cases, you can also package multiple binders with your application and have it choose the binder( and even whether to use different binders for different bindings) at runtime.
