For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Reactor Kafka Binder Health Indicator
Reactor Kafka binder provides a HealthIndicator implementation that will be used when invoking the Spring Boot Actuator health endpoint. When Spring Boot actuator dependency is on the classpath, the Reactor Kafka binder can be enabled with a binder health indicator. This health indicator provides information about the status of the binder based application, i.e. if it is currently UP or DOWN, the topics in usage by the application, and the various details about the message producer components that the binder uses internally.spring-doc.cn
The Reactor Kafka Binder Health Indicator is registered with the key reactorKafka internally by the framework. Therefore, it can be queried programmatically as shown below.spring-doc.cn
CompositeHealthContributor compositeHealthContributor = context
			.getBean("bindersHealthContributor", CompositeHealthContributor.class);
ReactorKafkaBinderHealthIndicator healthIndicator = (ReactorKafkaBinderHealthIndicator) compositeHealthContributor.getContributor("reactorKafka");
Health health = healthIndicator.health();
