For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Connecting to Multiple Systems
By default, binders share the application’s Spring Boot auto-configuration, so that one instance of each binder found on the classpath is created. If your application should connect to more than one broker of the same type, you can specify multiple binder configurations, each with different environment settings.spring-doc.cn
Turning on explicit binder configuration disables the default binder configuration process altogether. If you do so, all binders in use must be included in the configuration. Frameworks that intend to use Spring Cloud Stream transparently may create binder configurations that can be referenced by name, but they do not affect the default binder configuration. In order to do so, a binder configuration may have its defaultCandidate flag set to false (for example, spring.cloud.stream.binders.<configurationName>.defaultCandidate=false). This denotes a configuration that exists independently of the default binder configuration process.
The following example shows a typical configuration for a processor application that connects to two RabbitMQ broker instances:spring-doc.cn
spring:
  cloud:
    stream:
      bindings:
        input:
          destination: thing1
          binder: rabbit1
        output:
          destination: thing2
          binder: rabbit2
      binders:
        rabbit1:
          type: rabbit
          environment:
            spring:
              rabbitmq:
                host: <host1>
        rabbit2:
          type: rabbit
          environment:
            spring:
              rabbitmq:
                host: <host2>
The environment property of the particular binder can also be used for any Spring Boot property, including this spring.main.sources which can be useful for adding additional configurations for the particular binders, e.g. overriding auto-configured beans.
For example;spring-doc.cn
environment:
    spring:
        main:
           sources: com.acme.config.MyCustomBinderConfiguration
To activate a specific profile for the particular binder environment, you should use a spring.profiles.active property:spring-doc.cn
environment:
    spring:
        profiles:
           active: myBinderProfile
