For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Using Existing Queues/Exchanges
By default, the binder will automatically provision a topic exchange with the name being derived from the value of the destination binding property <prefix><destination>. The destination defaults to the binding name, if not provided. When binding a consumer, a queue will automatically be provisioned with the name <prefix><destination>.<group> (if a group binding property is specified), or an anonymous, auto-delete queue when there is no group. The queue will be bound to the exchange with the "match-all" wildcard routing key (#) for a non-partitioned binding or <destination>-<instanceIndex> for a partitioned binding. The prefix is an empty String by default. If an output binding is specified with requiredGroups, a queue/binding will be provisioned for each group.spring-doc.cn
There are a number of rabbit-specific binding properties that allow you to modify this default behavior.spring-doc.cn
If you have an existing exchange/queue that you wish to use, you can completely disable automatic provisioning as follows, assuming the exchange is named myExchange and the queue is named myQueue:spring-doc.cn
  • spring.cloud.stream.bindings.<binding name>.destination=myExchangespring-doc.cn
  • spring.cloud.stream.bindings.<binding name>.group=myQueuespring-doc.cn
  • spring.cloud.stream.rabbit.bindings.<binding name>.consumer.bindQueue=falsespring-doc.cn
  • spring.cloud.stream.rabbit.bindings.<binding name>.consumer.declareExchange=falsespring-doc.cn
  • spring.cloud.stream.rabbit.bindings.<binding name>.consumer.queueNameGroupOnly=truespring-doc.cn
If you want the binder to provision the queue/exchange, but you want to do it using something other than the defaults discussed here, use the following properties. Refer to the property documentation above for more information.spring-doc.cn
  • spring.cloud.stream.rabbit.bindings.<binding name>.consumer.bindingRoutingKey=myRoutingKeyspring-doc.cn
  • spring.cloud.stream.rabbit.bindings.<binding name>.consumer.exchangeType=<type>spring-doc.cn
  • spring.cloud.stream.rabbit.bindings.<binding name>.producer.routingKeyExpression='myRoutingKey'spring-doc.cn
There are similar properties used when declaring a dead-letter exchange/queue, when autoBindDlq is true.spring-doc.cn
