For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Kafka Streams topology visualization
Kafka Streams binder provides the following actuator endpoints for retrieving the topology description using which you can visualize the topology using external tools.spring-doc.cn
/actuator/kafkastreamstopologyspring-doc.cn
/actuator/kafkastreamstopology/<application-id of the processor>spring-doc.cn
You need to include the actuator and web dependencies from Spring Boot to access these endpoints. Further, you also need to add kafkastreamstopology to management.endpoints.web.exposure.include property. By default, the kafkastreamstopology endpoint is disabled.spring-doc.cn
