For the latest stable version, please use spring-cloud-stream 4.2.0! |
Content Type Negotiation
Data transformation is one of the core features of any message-driven microservice architecture. Given that, in Spring Cloud Stream, such data
is represented as a Spring Message
, a message may have to be transformed to a desired shape or size before reaching its destination. This is required for two reasons:
To convert the contents of the incoming message to match the signature of the application-provided handler.
To convert the contents of the outgoing message to the wire format.
The wire format is typically byte[]
(that is true for the Kafka and Rabbit binders), but it is governed by the binder implementation.
In Spring Cloud Stream, message transformation is accomplished with an org.springframework.messaging.converter.MessageConverter
As a supplement to the details to follow, you may also want to read the following blog post. |
