For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Sender Result Channel
Starting with version 4.0.3, you can configure the resultMetadataChannel to receive SenderResult<?> s to determine success/failure of sends.spring-doc.cn
The SenderResult contains correlationMetadata to allow you to correlate results with sends; it also contains RecordMetadata, which indicates the TopicPartition and offset of the sent record.spring-doc.cn
The resultMetadataChannel must be a FluxMessageChannel instance.spring-doc.cn
Here is an example of how to use this feature, with correlation metadata of type Integer:spring-doc.cn
FluxMessageChannel sendResults() {
    return new FluxMessageChannel();
@ServiceActivator(inputChannel = "sendResults")
void handleResults(SenderResult<Integer> result) {
    if (result.exception() != null) {
        failureFor(result);
    else {
        successFor(result);
To set the correlation metadata on an output record, set the CORRELATION_ID header:spring-doc.cn
streamBridge.send("words1", MessageBuilder.withPayload("foobar")
        .setCorrelationId(42)
        .build());
When using the feature with a Function, the function output type must be a Message<?> with the correlation id header set to the desired value.spring-doc.cn
Metadata should be unique, at least for the duration of the send.spring-doc.cn
