For the latest stable version, please use spring-cloud-stream 4.2.0! |
Binder SPI
The Binder SPI consists of a number of interfaces, out-of-the box utility classes, and discovery strategies that provide a pluggable mechanism for connecting to external middleware.
The key point of the SPI is the Binder
interface, which is a strategy for connecting inputs and outputs to external middleware. The following listing shows the definition of the Binder
interface:
public interface Binder<T, C extends ConsumerProperties, P extends ProducerProperties> {
Binding<T> bindConsumer(String bindingName, String group, T inboundBindTarget, C consumerProperties);
Binding<T> bindProducer(String bindingName, T outboundBindTarget, P producerProperties);
The interface is parameterized, offering a number of extension points:
Input and output bind targets.
Extended consumer and producer properties, allowing specific Binder implementations to add supplemental properties that can be supported in a type-safe manner.
A typical binder implementation consists of the following:
A class that implements the
Binder
interface; -
A Spring
class that creates a bean of typeBinder
along with the middleware connection infrastructure. -
A
META-INF/spring.binders
file found on the classpath containing one or more binder definitions, as shown in the following example:kafka:\ org.springframework.cloud.stream.binder.kafka.config.KafkaBinderConfiguration
As it was mentioned earlier Binder abstraction is also one of the extension points of the framework. So if you can’t find a suitable binder in the preceding list you can implement your own binder on top of Spring Cloud Stream.
In the How to create a Spring Cloud Stream Binder from scratch post a community member documents
in details, with an example, a set of steps necessary to implement a custom binder.
The steps are also highlighted in the Implementing Custom Binders section.
