For the latest stable version, please use spring-cloud-stream 4.2.0! |
Health Indicator
Spring Cloud Stream provides a health indicator for binders.
It is registered under the name binders
and can be enabled or disabled by setting the management.health.binders.enabled
property.
To enable health check you first need to enable both "web" and "actuator" by including its dependencies (see Binding visualization and control)
If management.health.binders.enabled
is not set explicitly by the application, then management.health.defaults.enabled
is matched as true
and the binder health indicators are enabled.
If you want to disable health indicator completely, then you have to set management.health.binders.enabled
to false
You can use Spring Boot actuator health endpoint to access the health indicator - /actuator/health
By default, you will only receive the top level application status when you hit the above endpoint.
In order to receive the full details from the binder specific health indicators, you need to include the property management.endpoint.health.show-details
with the value ALWAYS
in your application.
Health indicators are binder-specific and certain binder implementations may not necessarily provide a health indicator.
If you want to completely disable all health indicators available out of the box and instead provide your own health indicators,
you can do so by setting property management.health.binders.enabled
to false
and then provide your own HealthIndicator
beans in your application.
In this case, the health indicator infrastructure from Spring Boot will still pick up these custom beans.
Even if you are not disabling the binder health indicators, you can still enhance the health checks by providing your own HealthIndicator
beans in addition to the out of the box health checks.
When you have multiple binders in the same application, health indicators are enabled by default unless the application turns them off by setting management.health.binders.enabled
to false
In this case, if the user wants to disable health check for a subset of the binders, then that should be done by setting management.health.binders.enabled
to false
in the multi binder configurations’s environment.
See Connecting to Multiple Systems for details on how environment specific properties can be provided.
If there are multiple binders present in the classpath but not all of them are used in the application, this may cause some issues in the context of health indicators.
There may be implementation specific details as to how the health checks are performed. For example, a Kafka binder may decide the status as DOWN
if there are no destinations registered by the binder.
Lets take a concrete situation. Imagine you have both Kafka and Kafka Streams binders present in the classpath, but only use the Kafka Streams binder in the application code, i.e. only provide bindings using the Kafka Streams binder.
Since Kafka binder is not used and it has specific checks to see if any destinations are registered, the binder health check will fail.
The top level application health check status will be reported as DOWN
In this situation, you can simply remove the dependency for kafka binder from your application since you are not using it.
