For the latest stable version, please use spring-cloud-stream 4.2.0! |
Bindings
As stated earlier, Bindings provide a bridge between the external messaging system (e.g., queue, topic etc.) and application-provided Producers and Consumers.
The following example shows a fully configured and functioning Spring Cloud Stream application that receives the payload of the message
as a String
type (see Content Type Negotiation section), logs it to the console and sends it down stream after converting it to upper case.
@SpringBootApplication
public class SampleApplication {
SpringApplication.run(SampleApplication.class, args);
public Function<String, String> uppercase() {
return value -> {
System.out.println("Received: " + value);
return value.toUpperCase();
The above example looks no different then any vanilla spring-boot application. It defines a single bean of type Function
and that is it. So, how does it become a spring-cloud-stream application?
It becomes a spring-cloud-stream application simply because of the presence of spring-cloud-stream and binder dependencies
and auto-configuration classes on the classpath, effectively setting the context for your boot application as a spring-cloud-stream application.
And in this context beans of type Supplier
, Function
or Consumer
are treated as defacto message handlers triggering
binding of to destinations exposed by the provided binder following certain naming conventions and
rules to avoid extra configuration.
