For the latest stable version, please use spring-cloud-stream 4.2.0! |
Provided MessageConverters
As mentioned earlier, the framework already provides a stack of MessageConverters
to handle most common use cases.
The following list describes the provided MessageConverters
, in order of precedence (the first MessageConverter
that works is used):
JsonMessageConverter
: As the name suggests it supports conversion of the payload of theMessage
to/from POJO for cases whencontentType
isapplication/json
(DEFAULT). -
ByteArrayMessageConverter
: Supports conversion of the payload of theMessage
frombyte[]
tobyte[]
isapplication/octet-stream
. It is essentially a pass through and exists primarily for backward compatibility. -
ObjectStringMessageConverter
: Supports conversion of any type to aString
whencontentType
istext/plain
. It invokes Object’stoString()
method or, if the payload isbyte[]
, a newString(byte[])
When no appropriate converter is found, the framework throws an exception. When that happens, you should check your code and configuration and ensure you did not miss anything (that is, ensure that you provided a contentType
by using a binding or a header).
However, most likely, you found some uncommon case (such as a custom contentType
perhaps) and the current stack of provided MessageConverters
does not know how to convert. If that is the case, you can add custom MessageConverter
. See User-defined Message Converters.
