For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Application Model
A Spring Cloud Stream application consists of a middleware-neutral core. The application communicates with the outside world by establishing bindings between destinations exposed by the external brokers and input/output arguments in your code. Broker specific details necessary to establish bindings are handled by middleware-specific Binder implementations.spring-doc.cn
SCSt with binder
Figure 1. Spring Cloud Stream Application
Fat JAR
Spring Cloud Stream applications can be run in stand-alone mode from your IDE for testing. To run a Spring Cloud Stream application in production, you can create an executable (or “fat”) JAR by using the standard Spring Boot tooling provided for Maven or Gradle. See the Spring Boot Reference Guide for more details.spring-doc.cn
