For the latest stable version, please use spring-cloud-stream 4.2.0! |
Binding Service Properties
These properties are exposed via org.springframework.cloud.stream.config.BindingServiceProperties
- spring.cloud.stream.instanceCount
The number of deployed instances of an application. Must be set for partitioning on the producer side. Must be set on the consumer side when using RabbitMQ and with Kafka if
autoRebalanceEnabled=false
.Default:
1
. - spring.cloud.stream.instanceIndex
The instance index of the application: A number from
0
toinstanceCount - 1
. Used for partitioning with RabbitMQ and with Kafka ifautoRebalanceEnabled=false
. Automatically set in Cloud Foundry to match the application’s instance index. - spring.cloud.stream.dynamicDestinations
A list of destinations that can be bound dynamically (for example, in a dynamic routing scenario). If set, only listed destinations can be bound.
Default: empty (letting any destination be bound).
- spring.cloud.stream.defaultBinder
The default binder to use, if multiple binders are configured. See Multiple Binders on the Classpath.
Default: empty.
- spring.cloud.stream.overrideCloudConnectors
This property is only applicable when the
cloud
profile is active and Spring Cloud Connectors are provided with the application. If the property isfalse
(the default), the binder detects a suitable bound service (for example, a RabbitMQ service bound in Cloud Foundry for the RabbitMQ binder) and uses it for creating connections (usually through Spring Cloud Connectors). When set totrue
, this property instructs binders to completely ignore the bound services and rely on Spring Boot properties (for example, relying on thespring.rabbitmq.*
properties provided in the environment for the RabbitMQ binder). The typical usage of this property is to be nested in a customized environment when connecting to multiple systems.Default:
false
. - spring.cloud.stream.bindingRetryInterval
The interval (in seconds) between retrying binding creation when, for example, the binder does not support late binding and the broker (for example, Apache Kafka) is down. Set it to zero to treat such conditions as fatal, preventing the application from starting.
Default:
30
