For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Pausing and Resuming the Consumer
If you wish to suspend consumption but not cause a partition rebalance, you can pause and resume the consumer. This is facilitated by managing the binding lifecycle as shown in Binding visualization and control in the Spring Cloud Stream documentation, using State.PAUSED and State.RESUMED.spring-doc.cn
To resume, you can use an ApplicationListener (or @EventListener method) to receive ListenerContainerIdleEvent instances. The frequency at which events are published is controlled by the idleEventInterval property.spring-doc.cn
