对于最新的稳定版本,请使用 spring-cloud-stream 4.2.0! |
发行商确认
有两种机制可以获取发布消息的结果;在每种情况下,Connection Factory 都必须具有publisherConfirmType
设置ConfirmType.CORRELATED
“遗留”机制是将confirmAckChannel
添加到消息通道的 bean 名称,您可以从中异步检索确认;负 ACK 被发送到 Error Channel (如果启用) - 请参阅 Error Channels。
在 3.1 版中添加的首选机制是使用相关数据标头并通过其Future<Confirm>
财产。
这对于批处理侦听器特别有用,因为您可以在等待结果之前发送多条消息。
要使用此技术,请将useConfirmHeader
property 设置为 true
以下简单应用程序是使用此方法的一个示例:
spring.cloud.stream.bindings.input-in-0.group=someGroup
spring.cloud.stream.bindings.input-in-0.consumer.batch-mode=true
spring.cloud.stream.source=output
spring.cloud.stream.bindings.output-out-0.producer.error-channel-enabled=true
spring.cloud.stream.rabbit.bindings.output-out-0.producer.useConfirmHeader=true
spring.cloud.stream.rabbit.bindings.input-in-0.consumer.auto-bind-dlq=true
spring.cloud.stream.rabbit.bindings.input-in-0.consumer.batch-size=10
spring.rabbitmq.publisher-confirm-type=correlated
spring.rabbitmq.publisher-returns=true
@SpringBootApplication
public class Application {
private static final Logger log = LoggerFactory.getLogger(Application.class);
SpringApplication.run(Application.class, args);
@Autowired
private StreamBridge bridge;
Consumer<List<String>> input() {
return list -> {
List<MyCorrelationData> results = new ArrayList<>();
list.forEach(str -> {
log.info("Received: " + str);
MyCorrelationData corr = new MyCorrelationData(UUID.randomUUID().toString(), str);
results.add(corr);
this.bridge.send("output-out-0", MessageBuilder.withPayload(str.toUpperCase())
.setHeader(AmqpHeaders.PUBLISH_CONFIRM_CORRELATION, corr)
.build());
results.forEach(correlation -> {
try {
Confirm confirm = correlation.getFuture().get(10, TimeUnit.SECONDS);
log.info(confirm + " for " + correlation.getPayload());
if (correlation.getReturnedMessage() != null) {
log.error("Message for " + correlation.getPayload() + " was returned ");
// throw some exception to invoke binder retry/error handling
catch (InterruptedException e) {
Thread.currentThread().interrupt();
throw new IllegalStateException(e);
catch (ExecutionException | TimeoutException e) {
public ApplicationRunner runner(BatchingRabbitTemplate template) {
return args -> IntStream.range(0, 10).forEach(i ->
template.convertAndSend("input-in-0", "input-in-0.rbgh303", "foo" + i));
public BatchingRabbitTemplate template(CachingConnectionFactory cf, TaskScheduler taskScheduler) {
BatchingStrategy batchingStrategy = new SimpleBatchingStrategy(10, 1000000, 1000);
return new BatchingRabbitTemplate(cf, batchingStrategy, taskScheduler);
class MyCorrelationData extends CorrelationData {
private final String payload;
MyCorrelationData(String id, String payload) {
super(id);
this.payload = payload;
public String getPayload() {
return this.payload;
如您所见,我们发送每条消息,然后等待发布结果。 如果无法路由消息,则在 future 完成之前,将使用返回的消息填充关联数据。
关联数据必须具有唯一的id ,以便框架可以执行关联。 |
不能同时设置useConfirmHeader
和confirmAckChannel
但是,在以下情况下,您仍然可以在 Error 频道中收到返回的消息useConfirmHeader
为 true,但使用 correlation 标头更方便。
