对于最新的稳定版本,请使用 spring-cloud-stream 4.2.0spring-doc.cadn.net.cn
KafkaBindingRebalanceListener 函数
应用程序可能希望在最初分配分区时将主题/分区查找到任意偏移量,或在消费者上执行其他作。 从版本 2.1 开始,如果您提供单个KafkaBindingRebalanceListenerbean 时,它将被连接到所有 Kafka 消费者绑定中。spring-doc.cadn.net.cn
public interface KafkaBindingRebalanceListener {
	 * Invoked by the container before any pending offsets are committed.
	 * @param bindingName the name of the binding.
	 * @param consumer the consumer.
	 * @param partitions the partitions.
	default void onPartitionsRevokedBeforeCommit(String bindingName, Consumer<?, ?> consumer,
			Collection<TopicPartition> partitions) {
	 * Invoked by the container after any pending offsets are committed.
	default void onPartitionsRevokedAfterCommit(String bindingName, Consumer<?, ?> consumer, Collection<TopicPartition> partitions) {
	 * Invoked when partitions are initially assigned or after a rebalance.
	 * Applications might only want to perform seek operations on an initial assignment.
	 * @param initial true if this is the initial assignment.
	default void onPartitionsAssigned(String bindingName, Consumer<?, ?> consumer, Collection<TopicPartition> partitions,
			boolean initial) {
您无法设置resetOffsetsconsumer 属性设置为true当您提供 Rebalance 侦听器时。spring-doc.cadn.net.cn
