This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.5! |
Configuration Properties (configprops
The configprops
endpoint provides information about the application’s @ConfigurationProperties
beans.
Retrieving All @ConfigurationProperties Beans
To retrieve all of the @ConfigurationProperties
beans, make a GET
request to /actuator/configprops
, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/configprops' -i -X GET
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 3411
"contexts" : {
"application" : {
"beans" : {
"management.endpoints.web.cors-org.springframework.boot.actuate.autoconfigure.endpoint.web.CorsEndpointProperties" : {
"prefix" : "management.endpoints.web.cors",
"properties" : {
"allowedOrigins" : [ ],
"maxAge" : "PT30M",
"exposedHeaders" : [ ],
"allowedOriginPatterns" : [ ],
"allowedHeaders" : [ ],
"allowedMethods" : [ ]
"inputs" : {
"maxAge" : { },
"management.endpoints.web-org.springframework.boot.actuate.autoconfigure.endpoint.web.WebEndpointProperties" : {
"prefix" : "management.endpoints.web",
"properties" : {
"pathMapping" : { },
"exposure" : {
"include" : [ "*" ],
"exclude" : [ ]
"basePath" : "/actuator",
"discovery" : {
"enabled" : true
"inputs" : {
"exposure" : {
"include" : [ {
"value" : "*",
"origin" : "\"management.endpoints.web.exposure.include\" from property source \"Inlined Test Properties\""
"exclude" : [ ]
"basePath" : { },
"discovery" : {
"enabled" : { }
"spring.web-org.springframework.boot.autoconfigure.web.WebProperties" : {
"prefix" : "spring.web",
"properties" : {
"localeResolver" : "ACCEPT_HEADER",
"resources" : {
"staticLocations" : [ "classpath:/META-INF/resources/", "classpath:/resources/", "classpath:/static/", "classpath:/public/" ],
"addMappings" : true,
"chain" : {
"cache" : true,
"compressed" : false,
"strategy" : {
"fixed" : {
"enabled" : false,
"paths" : [ "/**" ]
"content" : {
"enabled" : false,
"paths" : [ "/**" ]
"cache" : {
"cachecontrol" : { },
"useLastModified" : true
"inputs" : {
"localeResolver" : { },
"resources" : {
"staticLocations" : [ { }, { }, { }, { } ],
"addMappings" : { },
"chain" : {
"cache" : { },
"compressed" : { },
"strategy" : {
"fixed" : {
"enabled" : { },
"paths" : [ { } ]
"content" : {
"enabled" : { },
"paths" : [ { } ]
"cache" : {
"useLastModified" : { }
Response Structure
The response contains details of the application’s @ConfigurationProperties
beans.
The following table describes the structure of the response:
Path | Type | Description |
Application contexts keyed by id. |
Prefix applied to the names of the bean’s properties. |
Properties of the bean as name-value pairs. |
Origin and value of the configuration property used when binding to this bean. |
Id of the parent application context, if any. |
Retrieving @ConfigurationProperties Beans By Prefix
To retrieve the @ConfigurationProperties
beans mapped under a certain prefix, make a GET
request to /actuator/configprops/{prefix}
$ curl 'http://localhost:8080/actuator/configprops/spring.jackson' -i -X GET
HTTP/1.1 200 OK
Content-Disposition: inline;filename=f.txt
Content-Length: 878
"contexts" : {
"application" : {
"beans" : {
"spring.jackson-org.springframework.boot.autoconfigure.jackson.JacksonProperties" : {
"prefix" : "spring.jackson",
"properties" : {
"serialization" : { },
"visibility" : { },
"parser" : { },
"datatype" : {
"jsonNode" : { },
"enum" : { }
"deserialization" : { },
"generator" : { },
"mapper" : { }
"inputs" : {
"visibility" : { },
"parser" : { },
"datatype" : {
"jsonNode" : { },
"enum" : { }
"generator" : { },
"mapper" : { }
The {prefix} does not need to be exact, a more general prefix will return all beans mapped under that prefix stem.
Response Structure
beans.
