Shutdown (shutdown)
The shutdown endpoint is used to shut down the application.spring-doc.cn
Shutting Down the Application
To shut down the application, make a POST request to /actuator/shutdown, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/shutdown' -i -X POST
A response similar to the following is produced:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 41
  "message" : "Shutting down, bye..."
Response Structure
The response contains details of the result of the shutdown request. The following table describes the structure of the response:spring-doc.cn
Path Type Description
messagespring-doc.cn
Stringspring-doc.cn
Message describing the result of the request.spring-doc.cn
