Using the CLI
Once you have installed the CLI, you can run it by typing spring and pressing Enter at the command line. If you run spring without any arguments, a help screen is displayed, as follows:spring-doc.cn
$ spring
usage: spring [--help] [--version]
       <command> [<args>]
Available commands are:
  init [options] [location]
    Initialize a new project using Spring Initializr (start.spring.io)
  encodepassword [options] <password to encode>
    Encode a password for use with Spring Security
  shell
    Start a nested shell
Common options:
  --debug Verbose mode
    Print additional status information for the command you are running
See 'spring help <command>' for more information on a specific command.
You can type spring help to get more details about any of the supported commands, as shown in the following example:spring-doc.cn
$ spring help init
spring init - Initialize a new project using Spring Initializr (start.spring.io)
usage: spring init [options] [location]
Option                       Description
-a, --artifact-id <String>   Project coordinates; infer archive name (for
                               example 'test')
-b, --boot-version <String>  Spring Boot version (for example '1.2.0.RELEASE')
--build <String>             Build system to use (for example 'maven' or
                               'gradle') (default: maven)
-d, --dependencies <String>  Comma-separated list of dependency identifiers to
                               include in the generated project
--description <String>       Project description
-f, --force                  Force overwrite of existing files
--format <String>            Format of the generated content (for example
                               'build' for a build file, 'project' for a
                               project archive) (default: project)
-g, --group-id <String>      Project coordinates (for example 'org.test')
-j, --java-version <String>  Language level (for example '1.8')
-l, --language <String>      Programming language  (for example 'java')
--list                       List the capabilities of the service. Use it to
                               discover the dependencies and the types that are
                               available
-n, --name <String>          Project name; infer application name
-p, --packaging <String>     Project packaging (for example 'jar')
--package-name <String>      Package name
-t, --type <String>          Project type. Not normally needed if you use --
                               build and/or --format. Check the capabilities of
                               the service (--list) for more details
--target <String>            URL of the service to use (default: https://start.
                               spring.io)
-v, --version <String>       Project version (for example '0.0.1-SNAPSHOT')
-x, --extract                Extract the project archive. Inferred if a
                               location is specified without an extension
examples:
    To list all the capabilities of the service:
        $ spring init --list
    To creates a default project:
        $ spring init
    To create a web my-app.zip:
        $ spring init -d=web my-app.zip
    To create a web/data-jpa gradle project unpacked:
        $ spring init -d=web,jpa --build=gradle my-dir
The version command provides a quick way to check which version of Spring Boot you are using, as follows:spring-doc.cn
$ spring version
Spring CLI v3.5.0-RC1
Initialize a New Project
The init command lets you create a new project by using start.spring.io without leaving the shell, as shown in the following example:spring-doc.cn
$ spring init --dependencies=web,data-jpa my-project
Using service at https://start.spring.io
Project extracted to '/Users/developer/example/my-project'
The preceding example creates a my-project directory with a Maven-based project that uses spring-boot-starter-web and spring-boot-starter-data-jpa. You can list the capabilities of the service by using the --list flag, as shown in the following example:spring-doc.cn
Capabilities of https://start.spring.io
Available dependencies:
actuator - Actuator: Production ready features to help you monitor and manage your application
web - Web: Support for full-stack web development, including Tomcat and spring-webmvc
websocket - Websocket: Support for WebSocket development
ws - WS: Support for Spring Web Services
Available project types:
gradle-build -  Gradle Config [format:build, build:gradle]
gradle-project -  Gradle Project [format:project, build:gradle]
maven-build -  Maven POM [format:build, build:maven]
maven-project -  Maven Project [format:project, build:maven] (default)
The init command supports many options. See the help output for more details. For instance, the following command creates a Gradle project that uses Java 17 and war packaging:spring-doc.cn
$ spring init --build=gradle --java-version=17 --dependencies=websocket --packaging=war sample-app.zip
Content saved to 'sample-app.zip'
Using the Embedded Shell
Spring Boot includes command-line completion scripts for the BASH and zsh shells. If you do not use either of these shells (perhaps you are a Windows user), you can use the shell command to launch an integrated shell, as shown in the following example:spring-doc.cn
$ spring shell
Spring Boot (v3.5.0-RC1)
Hit TAB to complete. Type \'help' and hit RETURN for help, and \'exit' to quit.
From inside the embedded shell, you can run other commands directly:spring-doc.cn
$ version
The embedded shell supports ANSI color output as well as tab completion. If you need to run a native command, you can use the ! prefix. To exit the embedded shell, press ctrl-c.spring-doc.cn
