This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.5! |
Observability
Observability is the ability to observe the internal state of a running system from the outside. It consists of the three pillars: logging, metrics and traces.
For metrics and traces, Spring Boot uses Micrometer Observation.
To create your own observations (which will lead to metrics and traces), you can inject an ObservationRegistry
import io.micrometer.observation.Observation;
import io.micrometer.observation.ObservationRegistry;
@Component
public class MyCustomObservation {
private final ObservationRegistry observationRegistry;
public MyCustomObservation(ObservationRegistry observationRegistry) {
this.observationRegistry = observationRegistry;
public void doSomething() {
Observation.createNotStarted("doSomething", this.observationRegistry)
.lowCardinalityKeyValue("locale", "en-US")
.highCardinalityKeyValue("userId", "42")
.observe(() -> {
// Execute business logic here
Low cardinality tags will be added to metrics and traces, while high cardinality tags will only be added to traces. |
Beans of type ObservationPredicate
, GlobalObservationConvention
, ObservationFilter
and ObservationHandler
will be automatically registered on the ObservationRegistry
You can additionally register any number of ObservationRegistryCustomizer
beans to further configure the registry.
Observability for JDBC can be configured using a separate project. The Datasource Micrometer project provides a Spring Boot starter which automatically creates observations when JDBC operations are invoked. Read more about it in the reference documentation. |
Observability for R2DBC is built into Spring Boot.
To enable it, add the io.r2dbc:r2dbc-proxy dependency to your project.
Context Propagation
Observability support relies on the Context Propagation library for forwarding the current observation across threads and reactive pipelines.
By default, ThreadLocal
values are not automatically reinstated in reactive operators.
This behavior is controlled with the spring.reactor.context-propagation
property, which can be set to auto
to enable automatic propagation.
For more details about observations please see the Micrometer Observation documentation.
Common Tags
Common tags are generally used for dimensional drill-down on the operating environment, such as host, instance, region, stack, and others. Common tags are applied to all observations as low cardinality tags and can be configured, as the following example shows:
Properties
YAML
management.observations.key-values.region=us-east-1
management.observations.key-values.stack=prod
management:
observations:
key-values:
region: "us-east-1"
stack: "prod"
The preceding example adds region
and stack
tags to all observations with a value of us-east-1
and prod
, respectively.
Preventing Observations
If you’d like to prevent some observations from being reported, you can use the management.observations.enable
properties:
Properties
YAML
management.observations.enable.denied.prefix=false
management.observations.enable.another.denied.prefix=false
management:
observations:
enable:
denied:
prefix: false
another:
denied:
prefix: false
The preceding example will prevent all observations with a name starting with denied.prefix
or another.denied.prefix
If you want to prevent Spring Security from reporting observations, set the property management.observations.enable.spring.security to false .
If you need greater control over the prevention of observations, you can register beans of type ObservationPredicate
Observations are only reported if all the ObservationPredicate
beans return true
for that observation.
import io.micrometer.observation.Observation.Context;
import io.micrometer.observation.ObservationPredicate;
@Component
class MyObservationPredicate implements ObservationPredicate {
public boolean test(String name, Context context) {
return !name.contains("denied");
The preceding example will prevent all observations whose name contains "denied".
OpenTelemetry Support
There are several ways to support OpenTelemetry in your application. You can use the OpenTelemetry Java Agent or the OpenTelemetry Spring Boot Starter, which are supported by the OTel community; the metrics and traces use the semantic conventions defined by OTel libraries. This documentation describes OpenTelemetry as officially supported by the Spring team, using Micrometer and the OTLP exporter; the metrics and traces use the semantic conventions described in the Spring projects documentation, such as Spring Framework. |
Spring Boot’s actuator module includes basic support for OpenTelemetry.
It provides a bean of type OpenTelemetry
, and if there are beans of type SdkTracerProvider
, ContextPropagators
, SdkLoggerProvider
or SdkMeterProvider
in the application context, they automatically get registered.
Additionally, it provides a Resource
bean.
The attributes of the auto-configured Resource
can be configured via the management.opentelemetry.resource-attributes
configuration property.
Auto-configured attributes will be merged with attributes from the OTEL_RESOURCE_ATTRIBUTES
and OTEL_SERVICE_NAME
environment variables, with attributes configured through the configuration property taking precedence over those from the environment variables.
If you have defined your own Resource
bean, this will no longer be the case.
Spring Boot does not provide auto-configuration for OpenTelemetry metrics or logging. OpenTelemetry tracing is only auto-configured when used together with Micrometer Tracing. |
The OTEL_RESOURCE_ATTRIBUTES environment variable consists of a list of key-value pairs.
For example: key1=value1,key2=value2,key3=spring%20boot .
All attribute values are treated as strings, and any characters outside the baggage-octet range must be percent-encoded.
The next sections will provide more details about logging, metrics and traces.
Micrometer Observation Annotations support
To enable scanning of observability annotations like @Observed
, @Timed
, @Counted
, @MeterTag
and @NewSpan
, you need to set the management.observations.annotations.enabled
property to true
This feature is supported by Micrometer directly.
Please refer to the Micrometer, Micrometer Observation and Micrometer Tracing reference docs.
When you annotate methods or classes which are already instrumented (for example, Spring Data repositories or Spring MVC controllers), you will get duplicate observations.
In that case you can either disable the automatic instrumentation using properties or an ObservationPredicate and rely on your annotations, or you can remove your annotations.
