Prometheus (prometheus)
The prometheus endpoint provides Spring Boot application’s metrics in the format required for scraping by a Prometheus server.spring-doc.cn
Retrieving All Metrics
To retrieve all metrics, make a GET request to /actuator/prometheus, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/prometheus' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: text/plain;version=0.0.4;charset=utf-8
Content-Length: 3091
# HELP jvm_buffer_count_buffers An estimate of the number of buffers in the pool
# TYPE jvm_buffer_count_buffers gauge
jvm_buffer_count_buffers{id="direct"} 3.0
jvm_buffer_count_buffers{id="mapped"} 0.0
jvm_buffer_count_buffers{id="mapped - 'non-volatile memory'"} 0.0
# HELP jvm_buffer_memory_used_bytes An estimate of the memory that the Java virtual machine is using for this buffer pool
# TYPE jvm_buffer_memory_used_bytes gauge
jvm_buffer_memory_used_bytes{id="direct"} 45056.0
jvm_buffer_memory_used_bytes{id="mapped"} 0.0
jvm_buffer_memory_used_bytes{id="mapped - 'non-volatile memory'"} 0.0
# HELP jvm_buffer_total_capacity_bytes An estimate of the total capacity of the buffers in this pool
# TYPE jvm_buffer_total_capacity_bytes gauge
jvm_buffer_total_capacity_bytes{id="direct"} 45056.0
jvm_buffer_total_capacity_bytes{id="mapped"} 0.0
jvm_buffer_total_capacity_bytes{id="mapped - 'non-volatile memory'"} 0.0
# HELP jvm_memory_committed_bytes The amount of memory in bytes that is committed for the Java virtual machine to use
# TYPE jvm_memory_committed_bytes gauge
jvm_memory_committed_bytes{area="heap",id="G1 Eden Space"} 1.37363456E8
jvm_memory_committed_bytes{area="heap",id="G1 Old Gen"} 1.33169152E8
jvm_memory_committed_bytes{area="heap",id="G1 Survivor Space"} 2097152.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 2555904.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4456448.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.9267584E7
jvm_memory_committed_bytes{area="nonheap",id="Compressed Class Space"} 1.1927552E7
jvm_memory_committed_bytes{area="nonheap",id="Metaspace"} 8.5458944E7
# HELP jvm_memory_max_bytes The maximum amount of memory in bytes that can be used for memory management
# TYPE jvm_memory_max_bytes gauge
jvm_memory_max_bytes{area="heap",id="G1 Eden Space"} -1.0
jvm_memory_max_bytes{area="heap",id="G1 Old Gen"} 1.610612736E9
jvm_memory_max_bytes{area="heap",id="G1 Survivor Space"} -1.0
jvm_memory_max_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 5836800.0
jvm_memory_max_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 1.22912768E8
jvm_memory_max_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.22908672E8
jvm_memory_max_bytes{area="nonheap",id="Compressed Class Space"} 1.073741824E9
jvm_memory_max_bytes{area="nonheap",id="Metaspace"} -1.0
# HELP jvm_memory_used_bytes The amount of used memory
# TYPE jvm_memory_used_bytes gauge
jvm_memory_used_bytes{area="heap",id="G1 Eden Space"} 7.9691776E7
jvm_memory_used_bytes{area="heap",id="G1 Old Gen"} 8.5905408E7
jvm_memory_used_bytes{area="heap",id="G1 Survivor Space"} 2097152.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 1420544.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4421888.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.9245952E7
jvm_memory_used_bytes{area="nonheap",id="Compressed Class Space"} 1.1549656E7
jvm_memory_used_bytes{area="nonheap",id="Metaspace"} 8.4696272E7
The default response content type is text/plain;version=0.0.4. The endpoint can also produce application/openmetrics-text;version=1.0.0 when called with an appropriate Accept header, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/prometheus' -i -X GET \
    -H 'Accept: application/openmetrics-text; version=1.0.0; charset=utf-8'
HTTP/1.1 200 OK
Content-Type: application/openmetrics-text;version=1.0.0;charset=utf-8
Content-Length: 3096
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4325376.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.9202048E7
jvm_memory_committed_bytes{area="nonheap",id="Metaspace"} 8.5327872E7
jvm_memory_used_bytes{area="heap",id="G1 Eden Space"} 7.7594624E7
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 1473536.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4321024.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.919744E7
jvm_memory_used_bytes{area="nonheap",id="Compressed Class Space"} 1.1537536E7
jvm_memory_used_bytes{area="nonheap",id="Metaspace"} 8.4546456E7
# EOF
Query Parameters
The endpoint uses query parameters to limit the samples that it returns. The following table shows the supported query parameters:spring-doc.cn
Parameter Description
includedNamesspring-doc.cn
Restricts the samples to those that match the names. Optional.spring-doc.cn
Retrieving Filtered Metrics
To retrieve metrics matching specific names, make a GET request to /actuator/prometheus with the includedNames query parameter, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/prometheus?includedNames=jvm_memory_used_bytes%2Cjvm_memory_committed_bytes' -i -X GET
HTTP/1.1 200 OK
Content-Length: 1464
jvm_memory_used_bytes{area="heap",id="G1 Eden Space"} 8.0740352E7
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4422656.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.9252992E7
jvm_memory_used_bytes{area="nonheap",id="Compressed Class Space"} 1.1550256E7
jvm_memory_used_bytes{area="nonheap",id="Metaspace"} 8.4700104E7
