Aspect-Oriented Programming
Spring Boot provides auto-configuration for aspect-oriented programming (AOP). You can learn more about AOP with Spring in the Spring Framework reference documentation.spring-doc.cn
By default, Spring Boot’s auto-configuration configures Spring AOP to use CGLib proxies. To use JDK proxies instead, set spring.aop.proxy-target-class to false.spring-doc.cn
If AspectJ is on the classpath, Spring Boot’s auto-configuration will automatically enable AspectJ auto proxy such that @EnableAspectJAutoProxy is not required.spring-doc.cn
