Spring Integration Graph (integrationgraph)
The integrationgraph endpoint exposes a graph containing all Spring Integration components.spring-doc.cn
Retrieving the Spring Integration Graph
To retrieve the information about the application, make a GET request to /actuator/integrationgraph, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/integrationgraph' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 1037
  "contentDescriptor" : {
    "providerVersion" : "6.5.0-RC1",
    "providerFormatVersion" : 1.2,
    "provider" : "spring-integration"
  "nodes" : [ {
    "nodeId" : 1,
    "componentType" : "null-channel",
    "integrationPatternType" : "null_channel",
    "integrationPatternCategory" : "messaging_channel",
    "properties" : { },
    "name" : "nullChannel",
    "observed" : false
    "nodeId" : 2,
    "componentType" : "publish-subscribe-channel",
    "integrationPatternType" : "publish_subscribe_channel",
    "properties" : { },
    "name" : "errorChannel",
    "observed" : false
    "nodeId" : 3,
    "componentType" : "logging-channel-adapter",
    "integrationPatternType" : "outbound_channel_adapter",
    "integrationPatternCategory" : "messaging_endpoint",
    "properties" : { },
    "input" : "errorChannel",
    "name" : "errorLogger",
    "observed" : false
  "links" : [ {
    "from" : 2,
    "to" : 3,
    "type" : "input"
Response Structure
The response contains all Spring Integration components used within the application, as well as the links between them. More information about the structure can be found in the reference documentation.spring-doc.cn
Rebuilding the Spring Integration Graph
To rebuild the exposed graph, make a POST request to /actuator/integrationgraph, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/integrationgraph' -i -X POST
This will result in a 204 - No Content response:spring-doc.cn
HTTP/1.1 204 No Content
