Cloud Foundry Support
Spring Boot’s actuator module includes additional support that is activated when you deploy to a compatible Cloud Foundry instance. The /cloudfoundryapplication path provides an alternative secured route to all @Endpoint beans.spring-doc.cn
The extended support lets Cloud Foundry management UIs (such as the web application that you can use to view deployed applications) be augmented with Spring Boot actuator information. For example, an application status page can include full health information instead of the typical “running” or “stopped” status.spring-doc.cn
The /cloudfoundryapplication path is not directly accessible to regular users. To use the endpoint, you must pass a valid UAA token with the request.
Disabling Extended Cloud Foundry Actuator Support
If you want to fully disable the /cloudfoundryapplication endpoints, you can add the following setting to your application.properties file:spring-doc.cn
management.cloudfoundry.enabled=false
management:
  cloudfoundry:
    enabled: false
Cloud Foundry Self-signed Certificates
By default, the security verification for /cloudfoundryapplication endpoints makes SSL calls to various Cloud Foundry services. If your Cloud Foundry UAA or Cloud Controller services use self-signed certificates, you need to set the following property:spring-doc.cn
management.cloudfoundry.skip-ssl-validation=true
management:
  cloudfoundry:
    skip-ssl-validation: true
Custom Context Path
If the server’s context-path has been configured to anything other than /, the Cloud Foundry endpoints are not available at the root of the application. For example, if server.servlet.context-path=/app, Cloud Foundry endpoints are available at /app/cloudfoundryapplication/*.spring-doc.cn
If you expect the Cloud Foundry endpoints to always be available at /cloudfoundryapplication/*, regardless of the server’s context-path, you need to explicitly configure that in your application. The configuration differs, depending on the web server in use. For Tomcat, you can add the following configuration:spring-doc.cn
import java.io.IOException;
import java.util.Collections;
import jakarta.servlet.GenericServlet;
import jakarta.servlet.Servlet;
import jakarta.servlet.ServletContainerInitializer;
import jakarta.servlet.ServletContext;
import jakarta.servlet.ServletException;
import jakarta.servlet.ServletRequest;
import jakarta.servlet.ServletResponse;
import org.apache.catalina.Host;
import org.apache.catalina.core.StandardContext;
import org.apache.catalina.startup.Tomcat;
import org.springframework.boot.web.embedded.tomcat.TomcatServletWebServerFactory;
import org.springframework.boot.web.servlet.ServletContextInitializer;
public class MyCloudFoundryConfiguration {
	public TomcatServletWebServerFactory servletWebServerFactory() {
		return new TomcatServletWebServerFactory() {
			protected void prepareContext(Host host, ServletContextInitializer[] initializers) {
				super.prepareContext(host, initializers);
				StandardContext child = new StandardContext();
				child.addLifecycleListener(new Tomcat.FixContextListener());
				child.setPath("/cloudfoundryapplication");
				ServletContainerInitializer initializer = getServletContextInitializer(getContextPath());
				child.addServletContainerInitializer(initializer, Collections.emptySet());
				child.setCrossContext(true);
				host.addChild(child);
	private ServletContainerInitializer getServletContextInitializer(String contextPath) {
		return (classes, context) -> {
			Servlet servlet = new GenericServlet() {
				public void service(ServletRequest req, ServletResponse res) throws ServletException, IOException {
					ServletContext context = req.getServletContext().getContext(contextPath);
					context.getRequestDispatcher("/cloudfoundryapplication").forward(req, res);
			context.addServlet("cloudfoundry", servlet).addMapping("/*");
import org.apache.catalina.startup.Tomcat.FixContextListener
import java.util.Collections.emptySet
	fun servletWebServerFactory(): TomcatServletWebServerFactory {
		return object : TomcatServletWebServerFactory() {
			override fun prepareContext(host: Host, initializers: Array<ServletContextInitializer>) {
				val child = StandardContext()
				child.addLifecycleListener(FixContextListener())
				child.path = "/cloudfoundryapplication"
				val initializer = getServletContextInitializer(contextPath)
				child.addServletContainerInitializer(initializer, emptySet())
				child.crossContext = true
	private fun getServletContextInitializer(contextPath: String): ServletContainerInitializer {
		return ServletContainerInitializer { classes: Set<Class<*>?>?, context: ServletContext ->
			val servlet: Servlet = object : GenericServlet() {
				@Throws(ServletException::class, IOException::class)
				override fun service(req: ServletRequest, res: ServletResponse) {
					val servletContext = req.servletContext.getContext(contextPath)
					servletContext.getRequestDispatcher("/cloudfoundryapplication").forward(req, res)
If you’re using a Webflux based application, you can use the following configuration:spring-doc.cn
import java.util.Map;
import reactor.core.publisher.Mono;
import org.springframework.boot.autoconfigure.web.reactive.WebFluxProperties;
import org.springframework.boot.context.properties.EnableConfigurationProperties;
import org.springframework.context.ApplicationContext;
import org.springframework.http.server.reactive.ContextPathCompositeHandler;
import org.springframework.http.server.reactive.HttpHandler;
import org.springframework.http.server.reactive.ServerHttpRequest;
import org.springframework.http.server.reactive.ServerHttpResponse;
import org.springframework.web.server.adapter.WebHttpHandlerBuilder;
@EnableConfigurationProperties(WebFluxProperties.class)
public class MyReactiveCloudFoundryConfiguration {
	public HttpHandler httpHandler(ApplicationContext applicationContext, WebFluxProperties properties) {
		HttpHandler httpHandler = WebHttpHandlerBuilder.applicationContext(applicationContext).build();
		return new CloudFoundryHttpHandler(properties.getBasePath(), httpHandler);
	private static final class CloudFoundryHttpHandler implements HttpHandler {
		private final HttpHandler delegate;
		private final ContextPathCompositeHandler contextPathDelegate;
		private CloudFoundryHttpHandler(String basePath, HttpHandler delegate) {
			this.delegate = delegate;
			this.contextPathDelegate = new ContextPathCompositeHandler(Map.of(basePath, delegate));
		public Mono<Void> handle(ServerHttpRequest request, ServerHttpResponse response) {
			// Remove underlying context path first (e.g. Servlet container)
			String path = request.getPath().pathWithinApplication().value();
			if (path.startsWith("/cloudfoundryapplication")) {
				return this.delegate.handle(request, response);
			else {
				return this.contextPathDelegate.handle(request, response);
@EnableConfigurationProperties(WebFluxProperties::class)
	fun httpHandler(applicationContext: ApplicationContext, properties: WebFluxProperties): HttpHandler {
		val httpHandler = WebHttpHandlerBuilder.applicationContext(applicationContext).build()
		return CloudFoundryHttpHandler(properties.basePath, httpHandler)
	private class CloudFoundryHttpHandler(basePath: String, private val delegate: HttpHandler) : HttpHandler {
		private val contextPathDelegate = ContextPathCompositeHandler(mapOf(basePath to delegate))
		override fun handle(request: ServerHttpRequest, response: ServerHttpResponse): Mono<Void> {
			val path = request.path.pathWithinApplication().value()
			return if (path.startsWith("/cloudfoundryapplication")) {
			} else {
