This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.5! |
Conditions Evaluation Report (conditions
The conditions
endpoint provides information about the evaluation of conditions on configuration and auto-configuration classes.
Retrieving the Report
To retrieve the report, make a GET
request to /actuator/conditions
, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/conditions' -i -X GET
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 3426
"contexts" : {
"application" : {
"positiveMatches" : {
"EndpointAutoConfiguration#propertiesEndpointAccessResolver" : [ {
"condition" : "OnBeanCondition",
"message" : "@ConditionalOnMissingBean (types: org.springframework.boot.actuate.endpoint.EndpointAccessResolver; SearchStrategy: all) did not find any beans"
"EndpointAutoConfiguration#endpointOperationParameterMapper" : [ {
"message" : "@ConditionalOnMissingBean (types: org.springframework.boot.actuate.endpoint.invoke.ParameterValueMapper; SearchStrategy: all) did not find any beans"
"EndpointAutoConfiguration#endpointCachingOperationInvokerAdvisor" : [ {
"message" : "@ConditionalOnMissingBean (types: org.springframework.boot.actuate.endpoint.invoker.cache.CachingOperationInvokerAdvisor; SearchStrategy: all) did not find any beans"
"negativeMatches" : {
"WebFluxEndpointManagementContextConfiguration" : {
"notMatched" : [ {
"condition" : "OnWebApplicationCondition",
"message" : "not a reactive web application"
"matched" : [ {
"condition" : "OnClassCondition",
"message" : "@ConditionalOnClass found required classes 'org.springframework.web.reactive.DispatcherHandler', 'org.springframework.http.server.reactive.HttpHandler'"
"GsonHttpMessageConvertersConfiguration.GsonHttpMessageConverterConfiguration" : {
"notMatched" : [ {
"condition" : "GsonHttpMessageConvertersConfiguration.PreferGsonOrJacksonAndJsonbUnavailableCondition",
"message" : "AnyNestedCondition 0 matched 2 did not; NestedCondition on GsonHttpMessageConvertersConfiguration.PreferGsonOrJacksonAndJsonbUnavailableCondition.JacksonJsonbUnavailable NoneNestedConditions 1 matched 1 did not; NestedCondition on GsonHttpMessageConvertersConfiguration.JacksonAndJsonbUnavailableCondition.JsonbPreferred @ConditionalOnPreferredJsonMapper JSONB no property was configured and Jackson is the default; NestedCondition on GsonHttpMessageConvertersConfiguration.JacksonAndJsonbUnavailableCondition.JacksonAvailable @ConditionalOnBean (types: org.springframework.http.converter.json.MappingJackson2HttpMessageConverter; SearchStrategy: all) found bean 'mappingJackson2HttpMessageConverter'; NestedCondition on GsonHttpMessageConvertersConfiguration.PreferGsonOrJacksonAndJsonbUnavailableCondition.GsonPreferred @ConditionalOnPreferredJsonMapper GSON no property was configured and Jackson is the default"
"matched" : [ ]
"WebMvcEndpointManagementContextConfiguration#managementHealthEndpointWebMvcHandlerMapping" : {
"notMatched" : [ {
"condition" : "OnManagementPortCondition",
"message" : "Management Port actual port type (SAME) did not match required type (DIFFERENT)"
"matched" : [ ]
"unconditionalClasses" : [ "org.springframework.boot.autoconfigure.context.PropertyPlaceholderAutoConfiguration", "org.springframework.boot.actuate.autoconfigure.endpoint.jackson.JacksonEndpointAutoConfiguration", "org.springframework.boot.actuate.autoconfigure.endpoint.EndpointAutoConfiguration" ]
Response Structure
The response contains details of the application’s condition evaluation. The following table describes the structure of the response:
Path | Type | Description |
Application contexts keyed by id. |
Classes and methods with conditions that were matched. |
Name of the condition. |
Details of why the condition was matched. |
Classes and methods with conditions that were not matched. |
Conditions that were matched. |
Details of why the condition was not matched. |
Names of unconditional auto-configuration classes if any. |
Id of the parent application context, if any. |
