Actuator REST API
This API documentation describes Spring Boot Actuators web endpoints.spring-doc.cn
Before you proceed, you should read the following topics:spring-doc.cn
In order to get the correct JSON responses documented below, Jackson must be available.
URLs
By default, all web endpoints are available beneath the path /actuator with URLs of the form /actuator/{id}. The /actuator base path can be configured by using the management.endpoints.web.base-path property, as shown in the following example:spring-doc.cn
management.endpoints.web.base-path=/manage
The preceding application.properties example changes the form of the endpoint URLs from /actuator/{id} to /manage/{id}. For example, the URL info endpoint would become /manage/info.spring-doc.cn
Timestamps
All timestamps that are consumed by the endpoints, either as query parameters or in the request body, must be formatted as an offset date and time as specified in ISO 8601.spring-doc.cn
