Scheduled Tasks (scheduledtasks)
The scheduledtasks endpoint provides information about the application’s scheduled tasks.spring-doc.cn
Retrieving the Scheduled Tasks
To retrieve the scheduled tasks, make a GET request to /actuator/scheduledtasks, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/scheduledtasks' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 1222
  "cron" : [ {
    "runnable" : {
      "target" : "com.example.Processor.processOrders"
    "expression" : "0 0 0/3 1/1 * ?",
    "nextExecution" : {
      "time" : "2025-04-25T11:59:59.999125677Z"
  "fixedDelay" : [ {
    "runnable" : {
      "target" : "com.example.Processor.purge"
    "initialDelay" : 0,
    "interval" : 5000,
    "nextExecution" : {
      "time" : "2025-04-25T09:57:37.813891850Z"
    "lastExecution" : {
      "time" : "2025-04-25T09:57:32.807424433Z",
      "status" : "SUCCESS"
  "fixedRate" : [ {
    "runnable" : {
      "target" : "com.example.Processor.retrieveIssues"
    "initialDelay" : 10000,
    "interval" : 3000,
    "nextExecution" : {
      "time" : "2025-04-25T09:57:42.793388964Z"
  "custom" : [ {
    "runnable" : {
      "target" : "com.example.Processor$CustomTriggeredRunnable@3c775fd7"
    "trigger" : "com.example.Processor$CustomTrigger@139be871",
    "lastExecution" : {
      "exception" : {
        "message" : "Failed while running custom task",
        "type" : "java.lang.IllegalStateException"
      "time" : "2025-04-25T09:57:32.845509498Z",
      "status" : "ERROR"
Response Structure
The response contains details of the application’s scheduled tasks. The following table describes the structure of the response:spring-doc.cn
Path Type Description
cronspring-doc.cn
Arrayspring-doc.cn
Cron tasks, if any.spring-doc.cn
cron.[].runnable.targetspring-doc.cn
Stringspring-doc.cn
Target that will be executed.spring-doc.cn
cron.[].nextExecution.timespring-doc.cn
Stringspring-doc.cn
Time of the next scheduled execution.spring-doc.cn
cron.[].expressionspring-doc.cn
Stringspring-doc.cn
Cron expression.spring-doc.cn
fixedDelayspring-doc.cn
Arrayspring-doc.cn
Fixed delay tasks, if any.spring-doc.cn
fixedDelay.[].runnable.targetspring-doc.cn
Stringspring-doc.cn
fixedDelay.[].initialDelayspring-doc.cn
Numberspring-doc.cn
Delay, in milliseconds, before first execution.spring-doc.cn
fixedDelay.[].nextExecution.timespring-doc.cn
Stringspring-doc.cn
Time of the next scheduled execution, if known.spring-doc.cn
fixedDelay.[].intervalspring-doc.cn
Numberspring-doc.cn
Interval, in milliseconds, between the end of the last execution and the start of the next.spring-doc.cn
fixedRatespring-doc.cn
Arrayspring-doc.cn
Fixed rate tasks, if any.spring-doc.cn
fixedRate.[].runnable.targetspring-doc.cn
Stringspring-doc.cn
fixedRate.[].intervalspring-doc.cn
Numberspring-doc.cn
Interval, in milliseconds, between the start of each execution.spring-doc.cn
fixedRate.[].initialDelayspring-doc.cn
Numberspring-doc.cn
fixedRate.[].nextExecution.timespring-doc.cn
Stringspring-doc.cn
customspring-doc.cn
Arrayspring-doc.cn
Tasks with custom triggers, if any.spring-doc.cn
custom.[].runnable.targetspring-doc.cn
Stringspring-doc.cn
custom.[].triggerspring-doc.cn
Stringspring-doc.cn
Trigger for the task.spring-doc.cn
*.[].lastExecutionspring-doc.cn
Objectspring-doc.cn
Last execution of this task, if any.spring-doc.cn
*.[].lastExecution.statusspring-doc.cn
Stringspring-doc.cn
Status of the last execution (STARTED, SUCCESS, ERROR).spring-doc.cn
*.[].lastExecution.timespring-doc.cn
Stringspring-doc.cn
Time of the last execution.spring-doc.cn
*.[].lastExecution.exception.typespring-doc.cn
Stringspring-doc.cn
Exception type thrown by the task, if any.spring-doc.cn
*.[].lastExecution.exception.messagespring-doc.cn
Stringspring-doc.cn
Message of the exception thrown by the task, if any.spring-doc.cn
