Servlet Web Applications
If you want to build servlet-based web applications, you can take advantage of Spring Boot’s auto-configuration for Spring MVC or Jersey.spring-doc.cn
The “Spring Web MVC Framework”
The Spring Web MVC framework (often referred to as “Spring MVC”) is a rich “model view controller” web framework. Spring MVC lets you create special @Controller or @RestController beans to handle incoming HTTP requests. Methods in your controller are mapped to HTTP by using @RequestMapping annotations.spring-doc.cn
The following code shows a typical @RestController that serves JSON data:spring-doc.cn
import java.util.List;
import org.springframework.web.bind.annotation.DeleteMapping;
import org.springframework.web.bind.annotation.GetMapping;
import org.springframework.web.bind.annotation.PathVariable;
import org.springframework.web.bind.annotation.RequestMapping;
import org.springframework.web.bind.annotation.RestController;
@RestController
@RequestMapping("/users")
public class MyRestController {
	private final UserRepository userRepository;
	private final CustomerRepository customerRepository;
	public MyRestController(UserRepository userRepository, CustomerRepository customerRepository) {
		this.userRepository = userRepository;
		this.customerRepository = customerRepository;
	@GetMapping("/{userId}")
	public User getUser(@PathVariable Long userId) {
		return this.userRepository.findById(userId).get();
	@GetMapping("/{userId}/customers")
	public List<Customer> getUserCustomers(@PathVariable Long userId) {
		return this.userRepository.findById(userId).map(this.customerRepository::findByUser).get();
	@DeleteMapping("/{userId}")
	public void deleteUser(@PathVariable Long userId) {
		this.userRepository.deleteById(userId);
@RestController
class MyRestController(private val userRepository: UserRepository, private val customerRepository: CustomerRepository) {
	fun getUser(@PathVariable userId: Long): User {
		return userRepository.findById(userId).get()
	fun getUserCustomers(@PathVariable userId: Long): List<Customer> {
		return userRepository.findById(userId).map(customerRepository::findByUser).get()
	fun deleteUser(@PathVariable userId: Long) {
“WebMvc.fn”, the functional variant, separates the routing configuration from the actual handling of the requests, as shown in the following example:spring-doc.cn
import org.springframework.http.MediaType;
import org.springframework.web.servlet.function.RequestPredicate;
import org.springframework.web.servlet.function.RouterFunction;
import org.springframework.web.servlet.function.ServerResponse;
import static org.springframework.web.servlet.function.RequestPredicates.accept;
import static org.springframework.web.servlet.function.RouterFunctions.route;
public class MyRoutingConfiguration {
	private static final RequestPredicate ACCEPT_JSON = accept(MediaType.APPLICATION_JSON);
	public RouterFunction<ServerResponse> routerFunction(MyUserHandler userHandler) {
		return route()
				.GET("/{user}", ACCEPT_JSON, userHandler::getUser)
				.GET("/{user}/customers", ACCEPT_JSON, userHandler::getUserCustomers)
				.DELETE("/{user}", ACCEPT_JSON, userHandler::deleteUser)
import org.springframework.web.servlet.function.RequestPredicates.accept
import org.springframework.web.servlet.function.RouterFunctions
	fun routerFunction(userHandler: MyUserHandler): RouterFunction<ServerResponse> {
		return RouterFunctions.route()
			.build()
	companion object {
		private val ACCEPT_JSON = accept(MediaType.APPLICATION_JSON)
import org.springframework.web.servlet.function.ServerRequest;
@Component
public class MyUserHandler {
	public ServerResponse getUser(ServerRequest request) {
	public ServerResponse getUserCustomers(ServerRequest request) {
	public ServerResponse deleteUser(ServerRequest request) {
@Component
	fun getUser(request: ServerRequest?): ServerResponse {
	fun getUserCustomers(request: ServerRequest?): ServerResponse {
	fun deleteUser(request: ServerRequest?): ServerResponse {
Spring MVC is part of the core Spring Framework, and detailed information is available in the reference documentation. There are also several guides that cover Spring MVC available at spring.io/guides.spring-doc.cn
You can define as many RouterFunction beans as you like to modularize the definition of the router. Beans can be ordered if you need to apply a precedence.
Spring MVC Auto-configuration
Spring Boot provides auto-configuration for Spring MVC that works well with most applications. It replaces the need for @EnableWebMvc and the two cannot be used together. In addition to Spring MVC’s defaults, the auto-configuration provides the following features:spring-doc.cn
If you want to keep those Spring Boot MVC customizations and make more MVC customizations (interceptors, formatters, view controllers, and other features), you can add your own @Configuration class of type WebMvcConfigurer but without @EnableWebMvc.spring-doc.cn
If you want to provide custom instances of RequestMappingHandlerMapping, RequestMappingHandlerAdapter, or ExceptionHandlerExceptionResolver, and still keep the Spring Boot MVC customizations, you can declare a bean of type WebMvcRegistrations and use it to provide custom instances of those components. The custom instances will be subject to further initialization and configuration by Spring MVC. To participate in, and if desired, override that subsequent processing, a WebMvcConfigurer should be used.spring-doc.cn
If you do not want to use the auto-configuration and want to take complete control of Spring MVC, add your own @Configuration annotated with @EnableWebMvc. Alternatively, add your own @Configuration-annotated DelegatingWebMvcConfiguration as described in the @EnableWebMvc API documentation.spring-doc.cn
Spring MVC Conversion Service
Spring MVC uses a different ConversionService to the one used to convert values from your application.properties or application.yaml file. It means that Period, Duration and DataSize converters are not available and that @DurationUnit and @DataSizeUnit annotations will be ignored.spring-doc.cn
If you want to customize the ConversionService used by Spring MVC, you can provide a WebMvcConfigurer bean with an addFormatters method. From this method you can register any converter that you like, or you can delegate to the static methods available on ApplicationConversionService.spring-doc.cn
Conversion can also be customized using the spring.mvc.format.* configuration properties. When not configured, the following defaults are used:spring-doc.cn
Property DateTimeFormatter Formats
spring.mvc.format.datespring-doc.cn
ofLocalizedDate(FormatStyle.SHORT)spring-doc.cn
java.util.Date and LocalDatespring-doc.cn
spring.mvc.format.timespring-doc.cn
ofLocalizedTime(FormatStyle.SHORT)spring-doc.cn
java.time’s LocalTime and OffsetTimespring-doc.cn
spring.mvc.format.date-timespring-doc.cn
ofLocalizedDateTime(FormatStyle.SHORT)spring-doc.cn
java.time’s LocalDateTime, OffsetDateTime, and ZonedDateTimespring-doc.cn
HttpMessageConverters
Spring MVC uses the HttpMessageConverter interface to convert HTTP requests and responses. Sensible defaults are included out of the box. For example, objects can be automatically converted to JSON (by using the Jackson library) or XML (by using the Jackson XML extension, if available, or by using JAXB if the Jackson XML extension is not available). By default, strings are encoded in UTF-8.spring-doc.cn
Any HttpMessageConverter bean that is present in the context is added to the list of converters. You can also override default converters in the same way.spring-doc.cn
If you need to add or customize converters, you can use Spring Boot’s HttpMessageConverters class, as shown in the following listing:spring-doc.cn
import org.springframework.boot.autoconfigure.http.HttpMessageConverters;
import org.springframework.http.converter.HttpMessageConverter;
public class MyHttpMessageConvertersConfiguration {
	public HttpMessageConverters customConverters() {
		HttpMessageConverter<?> additional = new AdditionalHttpMessageConverter();
		HttpMessageConverter<?> another = new AnotherHttpMessageConverter();
		return new HttpMessageConverters(additional, another);
	fun customConverters(): HttpMessageConverters {
		val additional: HttpMessageConverter<*> = AdditionalHttpMessageConverter()
		val another: HttpMessageConverter<*> = AnotherHttpMessageConverter()
		return HttpMessageConverters(additional, another)
For further control, you can also sub-class HttpMessageConverters and override its postProcessConverters and/or postProcessPartConverters methods. This can be useful when you want to re-order or remove some of the converters that Spring MVC configures by default.spring-doc.cn
MessageCodesResolver
Spring MVC has a strategy for generating error codes for rendering error messages from binding errors: MessageCodesResolver. If you set the spring.mvc.message-codes-resolver-format property PREFIX_ERROR_CODE or POSTFIX_ERROR_CODE, Spring Boot creates one for you (see the enumeration in DefaultMessageCodesResolver.Format).spring-doc.cn
Static Content
By default, Spring Boot serves static content from a directory called /static (or /public or /resources or /META-INF/resources) in the classpath or from the root of the ServletContext. It uses the ResourceHttpRequestHandler from Spring MVC so that you can modify that behavior by adding your own WebMvcConfigurer and overriding the addResourceHandlers method.spring-doc.cn
In a stand-alone web application, the default servlet from the container is not enabled. It can be enabled using the server.servlet.register-default-servlet property.spring-doc.cn
The default servlet acts as a fallback, serving content from the root of the ServletContext if Spring decides not to handle it. Most of the time, this does not happen (unless you modify the default MVC configuration), because Spring can always handle requests through the DispatcherServlet.spring-doc.cn
By default, resources are mapped on /**, but you can tune that with the spring.mvc.static-path-pattern property. For instance, relocating all resources to /resources/** can be achieved as follows:spring-doc.cn
spring.mvc.static-path-pattern=/resources/**
spring:
  mvc:
    static-path-pattern: "/resources/**"
You can also customize the static resource locations by using the spring.web.resources.static-locations property (replacing the default values with a list of directory locations). The root servlet context path, "/", is automatically added as a location as well.spring-doc.cn
In addition to the “standard” static resource locations mentioned earlier, a special case is made for Webjars content. By default, any resources with a path in /webjars/** are served from jar files if they are packaged in the Webjars format. The path can be customized with the spring.mvc.webjars-path-pattern property.spring-doc.cn
Do not use the src/main/webapp directory if your application is packaged as a jar. Although this directory is a common standard, it works only with war packaging, and it is silently ignored by most build tools if you generate a jar.
Spring Boot also supports the advanced resource handling features provided by Spring MVC, allowing use cases such as cache-busting static resources or using version agnostic URLs for Webjars.spring-doc.cn
To use version agnostic URLs for Webjars, add the org.webjars:webjars-locator-lite dependency. Then declare your Webjar. Using jQuery as an example, adding "/webjars/jquery/jquery.min.js" results in "/webjars/jquery/x.y.z/jquery.min.js" where x.y.z is the Webjar version.spring-doc.cn
To use cache busting, the following configuration configures a cache busting solution for all static resources, effectively adding a content hash, such as <link href="/css/spring-2a2d595e6ed9a0b24f027f2b63b134d6.css"/>, in URLs:spring-doc.cn
spring.web.resources.chain.strategy.content.enabled=true
spring.web.resources.chain.strategy.content.paths=/**
spring:
  web:
    resources:
      chain:
        strategy:
          content:
            enabled: true
            paths: "/**"
Links to resources are rewritten in templates at runtime, thanks to a ResourceUrlEncodingFilter that is auto-configured for Thymeleaf and FreeMarker. You should manually declare this filter when using JSPs. Other template engines are currently not automatically supported but can be with custom template macros/helpers and the use of the ResourceUrlProvider.
When loading resources dynamically with, for example, a JavaScript module loader, renaming files is not an option. That is why other strategies are also supported and can be combined. A "fixed" strategy adds a static version string in the URL without changing the file name, as shown in the following example:spring-doc.cn
spring.web.resources.chain.strategy.fixed.enabled=true
spring.web.resources.chain.strategy.fixed.paths=/js/lib/
spring.web.resources.chain.strategy.fixed.version=v12
spring:
  web:
    resources:
      chain:
        strategy:
          content:
            enabled: true
            paths: "/**"
          fixed:
            enabled: true
            paths: "/js/lib/"
            version: "v12"
With this configuration, JavaScript modules located under "/js/lib/" use a fixed versioning strategy ("/v12/js/lib/mymodule.js"), while other resources still use the content one (<link href="/css/spring-2a2d595e6ed9a0b24f027f2b63b134d6.css"/>).spring-doc.cn
See WebProperties.Resources for more supported options.spring-doc.cn
This feature has been thoroughly described in a dedicated blog post and in Spring Framework’s reference documentation.spring-doc.cn
Welcome Page
Spring Boot supports both static and templated welcome pages. It first looks for an index.html file in the configured static content locations. If one is not found, it then looks for an index template. If either is found, it is automatically used as the welcome page of the application.spring-doc.cn
This only acts as a fallback for actual index routes defined by the application. The ordering is defined by the order of HandlerMapping beans which is by default the following:spring-doc.cn
RouterFunctionMappingspring-doc.cn
Endpoints declared with RouterFunction beansspring-doc.cn
RequestMappingHandlerMappingspring-doc.cn
Endpoints declared in @Controller beansspring-doc.cn
WelcomePageHandlerMappingspring-doc.cn
The welcome page supportspring-doc.cn
Custom Favicon
As with other static resources, Spring Boot checks for a favicon.ico in the configured static content locations. If such a file is present, it is automatically used as the favicon of the application.spring-doc.cn
Path Matching and Content Negotiation
Spring MVC can map incoming HTTP requests to handlers by looking at the request path and matching it to the mappings defined in your application (for example, @GetMapping annotations on Controller methods).spring-doc.cn
Spring Boot chooses to disable suffix pattern matching by default, which means that requests like "GET /projects/spring-boot.json" will not be matched to @GetMapping("/projects/spring-boot") mappings. This is considered as a best practice for Spring MVC applications. This feature was mainly useful in the past for HTTP clients which did not send proper "Accept" request headers; we needed to make sure to send the correct Content Type to the client. Nowadays, Content Negotiation is much more reliable.spring-doc.cn
There are other ways to deal with HTTP clients that do not consistently send proper "Accept" request headers. Instead of using suffix matching, we can use a query parameter to ensure that requests like "GET /projects/spring-boot?format=json" will be mapped to @GetMapping("/projects/spring-boot"):spring-doc.cn
spring.mvc.contentnegotiation.favor-parameter=true
spring:
  mvc:
    contentnegotiation:
      favor-parameter: true
Or if you prefer to use a different parameter name:spring-doc.cn
spring.mvc.contentnegotiation.parameter-name=myparam
spring:
  mvc:
    contentnegotiation:
      parameter-name: "myparam"
Most standard media types are supported out-of-the-box, but you can also define new ones:spring-doc.cn
spring.mvc.contentnegotiation.media-types.markdown=text/markdown
spring:
  mvc:
    contentnegotiation:
      media-types:
        markdown: "text/markdown"
As of Spring Framework 5.3, Spring MVC supports two strategies for matching request paths to controllers. By default, Spring Boot uses the PathPatternParser strategy. PathPatternParser is an optimized implementation but comes with some restrictions compared to the AntPathMatcher strategy. PathPatternParser restricts usage of some path pattern variants. It is also incompatible with configuring the DispatcherServlet with a path prefix (spring.mvc.servlet.path).spring-doc.cn
The strategy can be configured using the spring.mvc.pathmatch.matching-strategy configuration property, as shown in the following example:spring-doc.cn
spring.mvc.pathmatch.matching-strategy=ant-path-matcher
spring:
  mvc:
    pathmatch:
      matching-strategy: "ant-path-matcher"
Spring MVC will throw a NoHandlerFoundException if a handler is not found for a request. Note that, by default, the serving of static content is mapped to /** and will, therefore, provide a handler for all requests. If no static content is available, ResourceHttpRequestHandler will throw a NoResourceFoundException. For a NoHandlerFoundException to be thrown, set spring.mvc.static-path-pattern to a more specific value such as /resources/** or set spring.web.resources.add-mappings to false to disable serving of static content entirely.spring-doc.cn
ConfigurableWebBindingInitializer
Spring MVC uses a WebBindingInitializer to initialize a WebDataBinder for a particular request. If you create your own ConfigurableWebBindingInitializer @Bean, Spring Boot automatically configures Spring MVC to use it.spring-doc.cn
Template Engines
As well as REST web services, you can also use Spring MVC to serve dynamic HTML content. Spring MVC supports a variety of templating technologies, including Thymeleaf, FreeMarker, and JSPs. Also, many other templating engines include their own Spring MVC integrations.spring-doc.cn
Spring Boot includes auto-configuration support for the following templating engines:spring-doc.cn
If possible, JSPs should be avoided. There are several known limitations when using them with embedded servlet containers.
When you use one of these templating engines with the default configuration, your templates are picked up automatically from src/main/resources/templates.spring-doc.cn
Depending on how you run your application, your IDE may order the classpath differently. Running your application in the IDE from its main method results in a different ordering than when you run your application by using Maven or Gradle or from its packaged jar. This can cause Spring Boot to fail to find the expected template. If you have this problem, you can reorder the classpath in the IDE to place the module’s classes and resources first.
Error Handling
By default, Spring Boot provides an /error mapping that handles all errors in a sensible way, and it is registered as a “global” error page in the servlet container. For machine clients, it produces a JSON response with details of the error, the HTTP status, and the exception message. For browser clients, there is a “whitelabel” error view that renders the same data in HTML format (to customize it, add a View that resolves to error).spring-doc.cn
There are a number of server.error properties that can be set if you want to customize the default error handling behavior. See the Server Properties section of the Appendix.spring-doc.cn
To replace the default behavior completely, you can implement ErrorController and register a bean definition of that type or add a bean of type ErrorAttributes to use the existing mechanism but replace the contents.spring-doc.cn
The BasicErrorController can be used as a base class for a custom ErrorController. This is particularly useful if you want to add a handler for a new content type (the default is to handle text/html specifically and provide a fallback for everything else). To do so, extend BasicErrorController, add a public method with a @RequestMapping that has a produces attribute, and create a bean of your new type.
As of Spring Framework 6.0, RFC 9457 Problem Details is supported. Spring MVC can produce custom error messages with the application/problem+json media type, like:spring-doc.cn
	"type": "https://example.org/problems/unknown-project",
	"title": "Unknown project",
	"status": 404,
	"detail": "No project found for id 'spring-unknown'",
	"instance": "/projects/spring-unknown"
This support can be enabled by setting spring.mvc.problemdetails.enabled to true.spring-doc.cn
You can also define a class annotated with @ControllerAdvice to customize the JSON document to return for a particular controller and/or exception type, as shown in the following example:spring-doc.cn
import jakarta.servlet.RequestDispatcher;
import jakarta.servlet.http.HttpServletRequest;
import org.springframework.http.HttpStatus;
import org.springframework.http.ResponseEntity;
import org.springframework.web.bind.annotation.ControllerAdvice;
import org.springframework.web.bind.annotation.ExceptionHandler;
import org.springframework.web.bind.annotation.ResponseBody;
import org.springframework.web.servlet.mvc.method.annotation.ResponseEntityExceptionHandler;
@ControllerAdvice(basePackageClasses = SomeController.class)
public class MyControllerAdvice extends ResponseEntityExceptionHandler {
	@ResponseBody
	@ExceptionHandler(MyException.class)
	public ResponseEntity<?> handleControllerException(HttpServletRequest request, Throwable ex) {
		HttpStatus status = getStatus(request);
		return new ResponseEntity<>(new MyErrorBody(status.value(), ex.getMessage()), status);
	private HttpStatus getStatus(HttpServletRequest request) {
		Integer code = (Integer) request.getAttribute(RequestDispatcher.ERROR_STATUS_CODE);
		HttpStatus status = HttpStatus.resolve(code);
		return (status != null) ? status : HttpStatus.INTERNAL_SERVER_ERROR;
@ControllerAdvice(basePackageClasses = [SomeController::class])
class MyControllerAdvice : ResponseEntityExceptionHandler() {
	@ResponseBody
	@ExceptionHandler(MyException::class)
	fun handleControllerException(request: HttpServletRequest, ex: Throwable): ResponseEntity<*> {
		val status = getStatus(request)
		return ResponseEntity(MyErrorBody(status.value(), ex.message), status)
	private fun getStatus(request: HttpServletRequest): HttpStatus {
		val code = request.getAttribute(RequestDispatcher.ERROR_STATUS_CODE) as Int
		val status = HttpStatus.resolve(code)
		return status ?: HttpStatus.INTERNAL_SERVER_ERROR
In the preceding example, if MyException is thrown by a controller defined in the same package as SomeController, a JSON representation of the MyErrorBody POJO is used instead of the ErrorAttributes representation.spring-doc.cn
In some cases, errors handled at the controller level are not recorded by web observations or the metrics infrastructure. Applications can ensure that such exceptions are recorded with the observations by setting the handled exception on the observation context.spring-doc.cn
Custom Error Pages
If you want to display a custom HTML error page for a given status code, you can add a file to an /error directory. Error pages can either be static HTML (that is, added under any of the static resource directories) or be built by using templates. The name of the file should be the exact status code or a series mask.spring-doc.cn
For example, to map 404 to a static HTML file, your directory structure would be as follows:spring-doc.cn
src/
 +- main/
     +- java/
     |   + <source code>
     +- resources/
         +- public/
             +- error/
             |   +- 404.html
             +- <other public assets>
To map all 5xx errors by using a FreeMarker template, your directory structure would be as follows:spring-doc.cn
src/
 +- main/
     +- java/
     |   + <source code>
     +- resources/
         +- templates/
             +- error/
             |   +- 5xx.ftlh
             +- <other templates>
For more complex mappings, you can also add beans that implement the ErrorViewResolver interface, as shown in the following example:spring-doc.cn
import java.util.Map;
import org.springframework.boot.autoconfigure.web.servlet.error.ErrorViewResolver;
import org.springframework.web.servlet.ModelAndView;
public class MyErrorViewResolver implements ErrorViewResolver {
	public ModelAndView resolveErrorView(HttpServletRequest request, HttpStatus status, Map<String, Object> model) {
		// Use the request or status to optionally return a ModelAndView
		if (status == HttpStatus.INSUFFICIENT_STORAGE) {
			// We could add custom model values here
			new ModelAndView("myview");
		return null;
class MyErrorViewResolver : ErrorViewResolver {
	override fun resolveErrorView(request: HttpServletRequest, status: HttpStatus,
			model: Map<String, Any>): ModelAndView? {
			return ModelAndView("myview")
		return null
You can also use regular Spring MVC features such as @ExceptionHandler methods and @ControllerAdvice. The ErrorController then picks up any unhandled exceptions.spring-doc.cn
Mapping Error Pages Outside of Spring MVC
For applications that do not use Spring MVC, you can use the ErrorPageRegistrar interface to directly register ErrorPage instances. This abstraction works directly with the underlying embedded servlet container and works even if you do not have a Spring MVC DispatcherServlet.spring-doc.cn
import org.springframework.boot.web.server.ErrorPage;
import org.springframework.boot.web.server.ErrorPageRegistrar;
import org.springframework.boot.web.server.ErrorPageRegistry;
public class MyErrorPagesConfiguration {
	public ErrorPageRegistrar errorPageRegistrar() {
		return this::registerErrorPages;
	private void registerErrorPages(ErrorPageRegistry registry) {
		registry.addErrorPages(new ErrorPage(HttpStatus.BAD_REQUEST, "/400"));
	fun errorPageRegistrar(): ErrorPageRegistrar {
		return ErrorPageRegistrar { registry: ErrorPageRegistry -> registerErrorPages(registry) }
	private fun registerErrorPages(registry: ErrorPageRegistry) {
		registry.addErrorPages(ErrorPage(HttpStatus.BAD_REQUEST, "/400"))
If you register an ErrorPage with a path that ends up being handled by a Filter (as is common with some non-Spring web frameworks, like Jersey and Wicket), then the Filter has to be explicitly registered as an ERROR dispatcher, as shown in the following example:
import java.util.EnumSet;
import jakarta.servlet.DispatcherType;
import org.springframework.boot.web.servlet.FilterRegistrationBean;
public class MyFilterConfiguration {
	public FilterRegistrationBean<MyFilter> myFilter() {
		FilterRegistrationBean<MyFilter> registration = new FilterRegistrationBean<>(new MyFilter());
		registration.setDispatcherTypes(EnumSet.allOf(DispatcherType.class));
		return registration;
	fun myFilter(): FilterRegistrationBean<MyFilter> {
		val registration = FilterRegistrationBean(MyFilter())
		registration.setDispatcherTypes(EnumSet.allOf(DispatcherType::class.java))
		return registration
Note that the default FilterRegistrationBean does not include the ERROR dispatcher type.spring-doc.cn
Error Handling in a WAR Deployment
When deployed to a servlet container, Spring Boot uses its error page filter to forward a request with an error status to the appropriate error page. This is necessary as the servlet specification does not provide an API for registering error pages. Depending on the container that you are deploying your war file to and the technologies that your application uses, some additional configuration may be required.spring-doc.cn
The error page filter can only forward the request to the correct error page if the response has not already been committed. By default, WebSphere Application Server 8.0 and later commits the response upon successful completion of a servlet’s service method. You should disable this behavior by setting com.ibm.ws.webcontainer.invokeFlushAfterService to false.spring-doc.cn
CORS Support
Cross-origin resource sharing (CORS) is a W3C specification implemented by most browsers that lets you specify in a flexible way what kind of cross-domain requests are authorized, instead of using some less secure and less powerful approaches such as IFRAME or JSONP.spring-doc.cn
As of version 4.2, Spring MVC supports CORS. Using controller method CORS configuration with @CrossOrigin annotations in your Spring Boot application does not require any specific configuration. Global CORS configuration can be defined by registering a WebMvcConfigurer bean with a customized addCorsMappings(CorsRegistry) method, as shown in the following example:spring-doc.cn
import org.springframework.web.servlet.config.annotation.CorsRegistry;
import org.springframework.web.servlet.config.annotation.WebMvcConfigurer;
public class MyCorsConfiguration {
	public WebMvcConfigurer corsConfigurer() {
		return new WebMvcConfigurer() {
			public void addCorsMappings(CorsRegistry registry) {
				registry.addMapping("/api/**");
	fun corsConfigurer(): WebMvcConfigurer {
		return object : WebMvcConfigurer {
			override fun addCorsMappings(registry: CorsRegistry) {
JAX-RS and Jersey
If you prefer the JAX-RS programming model for REST endpoints, you can use one of the available implementations instead of Spring MVC. Jersey and Apache CXF work quite well out of the box. CXF requires you to register its Servlet or Filter as a @Bean in your application context. Jersey has some native Spring support, so we also provide auto-configuration support for it in Spring Boot, together with a starter.spring-doc.cn
To get started with Jersey, include the spring-boot-starter-jersey as a dependency and then you need one @Bean of type ResourceConfig in which you register all the endpoints, as shown in the following example:spring-doc.cn
import org.glassfish.jersey.server.ResourceConfig;
@Component
public class MyJerseyConfig extends ResourceConfig {
	public MyJerseyConfig() {
		register(MyEndpoint.class);
Jersey’s support for scanning executable archives is rather limited. For example, it cannot scan for endpoints in a package found in a fully executable jar file or in WEB-INF/classes when running an executable war file. To avoid this limitation, the packages method should not be used, and endpoints should be registered individually by using the register method, as shown in the preceding example.
For more advanced customizations, you can also register an arbitrary number of beans that implement ResourceConfigCustomizer.spring-doc.cn
All the registered endpoints should be a @Component with HTTP resource annotations (@GET and others), as shown in the following example:spring-doc.cn
import jakarta.ws.rs.GET;
import jakarta.ws.rs.Path;
@Component
@Path("/hello")
public class MyEndpoint {
	@GET
	public String message() {
		return "Hello";
Since the @Endpoint is a Spring @Component, its lifecycle is managed by Spring and you can use the @Autowired annotation to inject dependencies and use the @Value annotation to inject external configuration. By default, the Jersey servlet is registered and mapped to /*. You can change the mapping by adding @ApplicationPath to your ResourceConfig.spring-doc.cn
By default, Jersey is set up as a servlet in a @Bean of type ServletRegistrationBean named jerseyServletRegistration. By default, the servlet is initialized lazily, but you can customize that behavior by setting spring.jersey.servlet.load-on-startup. You can disable or override that bean by creating one of your own with the same name. You can also use a filter instead of a servlet by setting spring.jersey.type=filter (in which case, the @Bean to replace or override is jerseyFilterRegistration). The filter has an @Order, which you can set with spring.jersey.filter.order. When using Jersey as a filter, a servlet that will handle any requests that are not intercepted by Jersey must be present. If your application does not contain such a servlet, you may want to enable the default servlet by setting server.servlet.register-default-servlet to true. Both the servlet and the filter registrations can be given init parameters by using spring.jersey.init.* to specify a map of properties.spring-doc.cn
Embedded Servlet Container Support
For servlet application, Spring Boot includes support for embedded Tomcat, Jetty, and Undertow servers. Most developers use the appropriate starter to obtain a fully configured instance. By default, the embedded server listens for HTTP requests on port 8080.spring-doc.cn
Servlets, Filters, and Listeners
When using an embedded servlet container, you can register servlets, filters, and all the listeners (such as HttpSessionListener) from the servlet spec, either by using Spring beans or by scanning for servlet components.spring-doc.cn
Registering Servlets, Filters, and Listeners as Spring Beans
Any Servlet, Filter, or servlet *Listener instance that is a Spring bean is registered with the embedded container. This can be particularly convenient if you want to refer to a value from your application.properties during configuration.spring-doc.cn
By default, if the context contains only a single Servlet, it is mapped to /. In the case of multiple servlet beans, the bean name is used as a path prefix. Filters map to /*.spring-doc.cn
If convention-based mapping is not flexible enough, you can use the ServletRegistrationBean, FilterRegistrationBean, and ServletListenerRegistrationBean classes for complete control. If you prefer annotations over ServletRegistrationBean and FilterRegistrationBean, you can also use @ServletRegistration and @FilterRegistration as an alternative.spring-doc.cn
It is usually safe to leave filter beans unordered. If a specific order is required, you should annotate the Filter with @Order or make it implement Ordered. You cannot configure the order of a Filter by annotating its bean method with @Order. If you cannot change the Filter class to add @Order or implement Ordered, you must define a FilterRegistrationBean for the Filter and set the registration bean’s order using the setOrder(int) method. Or, if you prefer annotations, you can also use @FilterRegistration and set the order attribute. Avoid configuring a filter that reads the request body at Ordered.HIGHEST_PRECEDENCE, since it might go against the character encoding configuration of your application. If a servlet filter wraps the request, it should be configured with an order that is less than or equal to OrderedFilter.REQUEST_WRAPPER_FILTER_MAX_ORDER.spring-doc.cn
To see the order of every Filter in your application, enable debug level logging for the web logging group (logging.level.web=debug). Details of the registered filters, including their order and URL patterns, will then be logged at startup.
Take care when registering Filter beans since they are initialized very early in the application lifecycle. If you need to register a Filter that interacts with other beans, consider using a DelegatingFilterProxyRegistrationBean instead.
Servlet Context Initialization
Embedded servlet containers do not directly execute the ServletContainerInitializer interface or Spring’s WebApplicationInitializer interface. This is an intentional design decision intended to reduce the risk that third party libraries designed to run inside a war may break Spring Boot applications.spring-doc.cn
If you need to perform servlet context initialization in a Spring Boot application, you should register a bean that implements the ServletContextInitializer interface. The single onStartup method provides access to the ServletContext and, if necessary, can easily be used as an adapter to an existing WebApplicationInitializer.spring-doc.cn
Scanning for Servlets, Filters, and listeners
When using an embedded container, automatic registration of classes annotated with @WebServlet, @WebFilter, and @WebListener can be enabled by using @ServletComponentScan.spring-doc.cn
@ServletComponentScan has no effect in a standalone container, where the container’s built-in discovery mechanisms are used instead.
The ServletWebServerApplicationContext
Under the hood, Spring Boot uses a different type of ApplicationContext for embedded servlet container support. The ServletWebServerApplicationContext is a special type of WebApplicationContext that bootstraps itself by searching for a single ServletWebServerFactory bean. Usually a TomcatServletWebServerFactory, JettyServletWebServerFactory, or UndertowServletWebServerFactory has been auto-configured.spring-doc.cn
You usually do not need to be aware of these implementation classes. Most applications are auto-configured, and the appropriate ApplicationContext and ServletWebServerFactory are created on your behalf.
In an embedded container setup, the ServletContext is set as part of server startup which happens during application context initialization. Because of this beans in the ApplicationContext cannot be reliably initialized with a ServletContext. One way to get around this is to inject ApplicationContext as a dependency of the bean and access the ServletContext only when it is needed. Another way is to use a callback once the server has started. This can be done using an ApplicationListener which listens for the ApplicationStartedEvent as follows:spring-doc.cn
import jakarta.servlet.ServletContext;
import org.springframework.boot.context.event.ApplicationStartedEvent;
import org.springframework.context.ApplicationContext;
import org.springframework.context.ApplicationListener;
import org.springframework.web.context.WebApplicationContext;
public class MyDemoBean implements ApplicationListener<ApplicationStartedEvent> {
	private ServletContext servletContext;
	public void onApplicationEvent(ApplicationStartedEvent event) {
		ApplicationContext applicationContext = event.getApplicationContext();
		this.servletContext = ((WebApplicationContext) applicationContext).getServletContext();
Customizing Embedded Servlet Containers
Common servlet container settings can be configured by using Spring Environment properties. Usually, you would define the properties in your application.properties or application.yaml file.spring-doc.cn
Common server settings include:spring-doc.cn
  • Network settings: Listen port for incoming HTTP requests (server.port), interface address to bind to (server.address), and so on.spring-doc.cn
  • Session settings: Whether the session is persistent (server.servlet.session.persistent), session timeout (server.servlet.session.timeout), location of session data (server.servlet.session.store-dir), and session-cookie configuration (server.servlet.session.cookie.*).spring-doc.cn
  • Error management: Location of the error page (server.error.path) and so on.spring-doc.cn
  • SSLspring-doc.cn
  • HTTP compressionspring-doc.cn
Spring Boot tries as much as possible to expose common settings, but this is not always possible. For those cases, dedicated namespaces offer server-specific customizations (see server.tomcat and server.undertow). For instance, access logs can be configured with specific features of the embedded servlet container.spring-doc.cn
See the ServerProperties class for a complete list.
SameSite Cookies
The SameSite cookie attribute can be used by web browsers to control if and how cookies are submitted in cross-site requests. The attribute is particularly relevant for modern web browsers which have started to change the default value that is used when the attribute is missing.spring-doc.cn
If you want to change the SameSite attribute of your session cookie, you can use the server.servlet.session.cookie.same-site property. This property is supported by auto-configured Tomcat, Jetty and Undertow servers. It is also used to configure Spring Session servlet based SessionRepository beans.spring-doc.cn
For example, if you want your session cookie to have a SameSite attribute of None, you can add the following to your application.properties or application.yaml file:spring-doc.cn
server.servlet.session.cookie.same-site=none
server:
  servlet:
    session:
      cookie:
        same-site: "none"
If you want to change the SameSite attribute on other cookies added to your HttpServletResponse, you can use a CookieSameSiteSupplier. The CookieSameSiteSupplier is passed a Cookie and may return a SameSite value, or null.spring-doc.cn
There are a number of convenience factory and filter methods that you can use to quickly match specific cookies. For example, adding the following bean will automatically apply a SameSite of Lax for all cookies with a name that matches the regular expression myapp.*.spring-doc.cn
import org.springframework.boot.web.servlet.server.CookieSameSiteSupplier;
public class MySameSiteConfiguration {
	public CookieSameSiteSupplier applicationCookieSameSiteSupplier() {
		return CookieSameSiteSupplier.ofLax().whenHasNameMatching("myapp.*");
	fun applicationCookieSameSiteSupplier(): CookieSameSiteSupplier {
Character Encoding
The character encoding behavior of the embedded servlet container for request and response handling can be configured using the server.servlet.encoding.* configuration properties.spring-doc.cn
When a request’s Accept-Language header indicates a locale for the request it will be automatically mapped to a charset by the servlet container. Each container provides default locale to charset mappings and you should verify that they meet your application’s needs. When they do not, use the server.servlet.encoding.mapping configuration property to customize the mappings, as shown in the following example:spring-doc.cn
server.servlet.encoding.mapping.ko=UTF-8
server:
  servlet:
    encoding:
      mapping:
        ko: "UTF-8"
In the preceding example, the ko (Korean) locale has been mapped to UTF-8. This is equivalent to a <locale-encoding-mapping-list> entry in a web.xml file of a traditional war deployment.spring-doc.cn
Programmatic Customization
If you need to programmatically configure your embedded servlet container, you can register a Spring bean that implements the WebServerFactoryCustomizer interface. WebServerFactoryCustomizer provides access to the ConfigurableServletWebServerFactory, which includes numerous customization setter methods. The following example shows programmatically setting the port:spring-doc.cn
import org.springframework.boot.web.server.WebServerFactoryCustomizer;
import org.springframework.boot.web.servlet.server.ConfigurableServletWebServerFactory;
@Component
public class MyWebServerFactoryCustomizer implements WebServerFactoryCustomizer<ConfigurableServletWebServerFactory> {
	public void customize(ConfigurableServletWebServerFactory server) {
		server.setPort(9000);
@Component
class MyWebServerFactoryCustomizer : WebServerFactoryCustomizer<ConfigurableServletWebServerFactory> {
	override fun customize(server: ConfigurableServletWebServerFactory) {
TomcatServletWebServerFactory, JettyServletWebServerFactory and UndertowServletWebServerFactory are dedicated variants of ConfigurableServletWebServerFactory that have additional customization setter methods for Tomcat, Jetty and Undertow respectively. The following example shows how to customize TomcatServletWebServerFactory that provides access to Tomcat-specific configuration options:spring-doc.cn
import java.time.Duration;
import org.springframework.boot.web.embedded.tomcat.TomcatServletWebServerFactory;
@Component
public class MyTomcatWebServerFactoryCustomizer implements WebServerFactoryCustomizer<TomcatServletWebServerFactory> {
	public void customize(TomcatServletWebServerFactory server) {
		server.addConnectorCustomizers((connector) -> connector.setAsyncTimeout(Duration.ofSeconds(20).toMillis()));
@Component
class MyTomcatWebServerFactoryCustomizer : WebServerFactoryCustomizer<TomcatServletWebServerFactory> {
	override fun customize(server: TomcatServletWebServerFactory) {
		server.addConnectorCustomizers({ connector -> connector.asyncTimeout = Duration.ofSeconds(20).toMillis() })
Customizing ConfigurableServletWebServerFactory Directly
For more advanced use cases that require you to extend from ServletWebServerFactory, you can expose a bean of such type yourself.spring-doc.cn
Setters are provided for many configuration options. Several protected method “hooks” are also provided should you need to do something more exotic. See the ConfigurableServletWebServerFactory API documentation for details.spring-doc.cn
Auto-configured customizers are still applied on your custom factory, so use that option carefully.
JSP Limitations
When running a Spring Boot application that uses an embedded servlet container (and is packaged as an executable archive), there are some limitations in the JSP support.spring-doc.cn
  • With Jetty and Tomcat, it should work if you use war packaging. An executable war will work when launched with java -jar, and will also be deployable to any standard container. JSPs are not supported when using an executable jar.spring-doc.cn
  • Undertow does not support JSPs.spring-doc.cn
  • Creating a custom error.jsp page does not override the default view for error handling. Custom error pages should be used instead.spring-doc.cn
