Integrating with Actuator
Spring Boot Actuator displays build-related information if a META-INF/build-info.properties file is present. The build-info goal generates such file with the coordinates of the project and the build time. It also allows you to add an arbitrary number of additional properties, as shown in the following example:spring-doc.cn
<project>
	<modelVersion>4.0.0</modelVersion>
	<artifactId>build-info</artifactId>
	<build>
		<plugins>
			<plugin>
				<executions>
					<execution>
						<goals>
							<goal>build-info</goal>
						</goals>
						<configuration>
							<additionalProperties>
								<encoding.source>UTF-8</encoding.source>
								<encoding.reporting>UTF-8</encoding.reporting>
								<java.version>${java.version}</java.version>
							</additionalProperties>
						</configuration>
					</execution>
				</executions>
			</plugin>
		</plugins>
	</build>
</project>
This configuration will generate a build-info.properties at the expected location with three additional keys.spring-doc.cn
java.version is expected to be a regular property available in the project. It will be interpolated as you would expect.
spring-boot:build-info
org.springframework.boot:spring-boot-maven-plugin:3.5.0-RC1spring-doc.cn
Generate a build-info.properties file based on the content of the current MavenProject.spring-doc.cn
Optional parameters
Name Type Default
additionalPropertiesspring-doc.cn
Mapspring-doc.cn
excludeInfoPropertiesspring-doc.cn
Listspring-doc.cn
outputFilespring-doc.cn
Filespring-doc.cn
${project.build.outputDirectory}/META-INF/build-info.propertiesspring-doc.cn
skipspring-doc.cn
booleanspring-doc.cn
falsespring-doc.cn
timespring-doc.cn
Stringspring-doc.cn
${project.build.outputTimestamp}spring-doc.cn
Parameter details
Additional properties to store in the build-info.properties file. Each entry is prefixed by build. in the generated build-info.properties.spring-doc.cn
Namespring-doc.cn
Typespring-doc.cn
java.util.Mapspring-doc.cn
Default valuespring-doc.cn
User propertyspring-doc.cn
Sincespring-doc.cn
Properties that should be excluded build-info.properties file. Can be used to exclude the standard group, artifact, name, version or time properties as well as items from additionalProperties.spring-doc.cn
Namespring-doc.cn
Typespring-doc.cn
java.util.Listspring-doc.cn
Sincespring-doc.cn
outputFile
The location of the generated build-info.properties file.spring-doc.cn
Namespring-doc.cn
Typespring-doc.cn
java.io.Filespring-doc.cn
Sincespring-doc.cn
skip
Skip the execution.spring-doc.cn
Namespring-doc.cn
skipspring-doc.cn
Typespring-doc.cn
falsespring-doc.cn
spring-boot.build-info.skipspring-doc.cn
Sincespring-doc.cn
3.1.0spring-doc.cn
time
The value used for the build.time property in a form suitable for Instant#parse(CharSequence). Defaults to project.build.outputTimestamp or session.request.startTime if the former is not set. To disable the build.time property entirely, use 'off' or add it to excludeInfoProperties.spring-doc.cn
Namespring-doc.cn
timespring-doc.cn
Typespring-doc.cn
java.lang.Stringspring-doc.cn
Sincespring-doc.cn
2.2.0spring-doc.cn
