This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.5! |
Publishing your Application
Publishing with the Maven-publish Plugin
To publish your Spring Boot jar or war, add it to the publication using the artifact
method on MavenPublication
Pass the task that produces that artifact that you wish to publish to the artifact
method.
For example, to publish the artifact produced by the default bootJar
task:
Groovy
Kotlin
publishing {
publications {
bootJava(MavenPublication) {
artifact tasks.named("bootJar")
repositories {
maven {
url = 'https://repo.example.com'
publishing {
publications {
create<MavenPublication>("bootJava") {
artifact(tasks.named("bootJar"))
repositories {
maven {
url = uri("https://repo.example.com")
Distributing with the Application Plugin
When the application
plugin is applied a distribution named boot
is created.
This distribution contains the archive produced by the bootJar
or bootWar
task and scripts to launch it on Unix-like platforms and Windows.
Zip and tar distributions can be built by the bootDistZip
and bootDistTar
tasks respectively.
To use the application
plugin, its mainClassName
property must be configured with the name of your application’s main class.
