Environment (env)
The env endpoint provides information about the application’s Environment.spring-doc.cn
Retrieving the Entire Environment
To retrieve the entire environment, make a GET request to /actuator/env, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/env' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 78215
  "activeProfiles" : [ ],
  "defaultProfiles" : [ "default" ],
  "propertySources" : [ {
    "name" : "servletContextInitParams",
    "properties" : { }
    "name" : "systemProperties",
    "properties" : {
      "java.specification.version" : {
        "value" : "17"
      "java.class.path" : {
        "value" : "/home/runner/.gradle/caches/8.13/workerMain/gradle-worker.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator-autoconfigure/build/classes/java/test:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator-autoconfigure/build/resources/test:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator-autoconfigure/build/classes/java/main:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator-autoconfigure/build/resources/main:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-tools/spring-boot-test-support/build/libs/spring-boot-test-support-3.5.0-RC1.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator/build/libs/spring-boot-actuator-3.5.0-RC1.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-autoconfigure/build/libs/spring-boot-autoconfigure-3.5.0-RC1.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-test/build/libs/spring-boot-test-3.5.0-RC1.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot/build/libs/spring-boot-3.5.0-RC1.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot/build/libs/spring-boot-3.5.0-RC1-test-fixtures.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot/build/classes/kotlin/main:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot/build/classes/java/main:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot/build/resources/main:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.dataformat/jackson-dataformat-xml/2.18.3/665a683773f8a92ea270d87127e198531e39cafa/jackson-dataformat-xml-2.18.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.flywaydb/flyway-core/11.7.2/2e40f0465ab29c807a38aae56b4e636451a9ff99/flyway-core-11.7.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-wavefront/1.15.0-RC1/5b88b24d1b332aff3e4719227d97eb39c4af6dd/micrometer-registry-wavefront-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-tracing-reporter-wavefront/1.5.0-RC1/2a639b816ff7361077c2621d11d5364486c43852/micrometer-tracing-reporter-wavefront-1.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.wavefront/wavefront-internal-reporter-java/1.7.16/135f9be9f149a6f0614db155ddf51e216d0d2891/wavefront-internal-reporter-java-1.7.16.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.wavefront/wavefront-sdk-java/3.4.3/48a767aa5aa56b56e09c88e8be87de8707cafe77/wavefront-sdk-java-3.4.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.datatype/jackson-datatype-jsr310/2.18.3/cc57924cccf42fc852081c36215272f84ffcd991/jackson-datatype-jsr310-2.18.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-cassandra/4.5.0-RC1/ea52b681f140dbc575a2d7722fa1b66b696a2c37/spring-data-cassandra-4.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.cassandra/java-driver-query-builder/4.19.0/ecb2a71646413a70b7c13fa386478fa8f31bbe3d/java-driver-query-builder-4.19.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.cassandra/java-driver-core/4.19.0/f9294b37c6d2199f56b9701ad4970275961f864a/java-driver-core-4.19.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-elasticsearch/5.5.0-RC1/9a999f077ab8d94e881d7e4cb43772d07579f469/spring-data-elasticsearch-5.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.dataformat/jackson-dataformat-toml/2.18.3/336d144daa471ab11a7672f68565b6afb6914ced/jackson-dataformat-toml-2.18.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.media/jersey-media-json-jackson/3.1.10/fe379d7a9647ce4c38704457956d1a3630f4188/jersey-media-json-jackson-3.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.module/jackson-module-jakarta-xmlbind-annotations/2.18.3/aa8ebfd31dcfa3c5be0ee55962effe2eabb63ead/jackson-module-jakarta-xmlbind-annotations-2.18.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.dataformat/jackson-dataformat-yaml/2.18.3/66658356a375664262c227dad09adc51dbc09c54/jackson-dataformat-yaml-2.18.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-rest-webmvc/4.5.0-RC1/ea710c99c9c4a6f4450ee11acce1590b853216c2/spring-data-rest-webmvc-4.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-rest-core/4.5.0-RC1/7464c076534b9989a5cf8c93e128e75fc10bd87b/spring-data-rest-core-4.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.datatype/jackson-datatype-jdk8/2.18.3/621558295660935134b171ce2b0d9ad6842ec2ff/jackson-datatype-jdk8-2.18.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.core/jackson-core/2.18.3/78f80c259268200e588aa204dd97ecf09b76916e/jackson-core-2.18.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.kafka/kafka-streams/3.9.0/935b2f1897291ce0d6e515d5453cff2094f33854/kafka-streams-3.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.core/jackson-annotations/2.18.3/7fa21cf7da4598f8240e4ebd9779249622af1acd/jackson-annotations-2.18.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/activemq-broker/6.1.6/edece27364088addb26434f20dfad08af0baa5c3/activemq-broker-6.1.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-couchbase/5.5.0-RC1/b37e4bf5894d9fe15f360ada2b64930ef360786f/spring-data-couchbase-5.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.restdocs/spring-restdocs-mockmvc/3.0.3/ac8256fceb81f1022c80b2de1541e4618874d437/spring-restdocs-mockmvc-3.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.restdocs/spring-restdocs-webtestclient/3.0.3/448b2289eebf06828d02d5dfded008c5ec8b33f4/spring-restdocs-webtestclient-3.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.restdocs/spring-restdocs-core/3.0.3/8d3f5bcc661cda01b5d70672a1112ed9e83fbbb9/spring-restdocs-core-3.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.core/jackson-databind/2.18.3/537e3886263e3b3464385040453e92567fd509e2/jackson-databind-2.18.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/ch.qos.logback/logback-classic/1.5.18/fc371f3fc97a639de2d67947cffb7518ec5e3d40/logback-classic-1.5.18.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-jakarta-server/2.40.0/128169666f6c3f1f0de3c98a139eaedcb20aee44/artemis-jakarta-server-2.40.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-server/2.40.0/ef4a9a54066f1acede8e019e3b38a5312172c39b/artemis-server-2.40.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.ben-manes.caffeine/caffeine/3.2.0/35eba09997476a39492ac7f7b2bb0e8292c09d17/caffeine-3.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.hazelcast/hazelcast-spring/5.5.0/be80826e47712a9f1cf66b9a3f790a6584810fb2/hazelcast-spring-5.5.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.hazelcast/hazelcast/5.5.0/e838d3f54dc1900310b5caff87ff25a5d3ed0d4b/hazelcast-5.5.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.zaxxer/HikariCP/6.3.0/bebd113244c9d9926c6b792f28110ed6380cacc2/HikariCP-6.3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.lettuce/lettuce-core/6.5.5.RELEASE/a0ebf832d20b572b3d62b82ac17b249a0d2b87d8/lettuce-core-6.5.5.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.kafka/spring-kafka/3.3.5/9e77add42162e1c7d7f5bf4b0e47f14aa3f62749/spring-kafka-3.3.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-jakarta9/1.15.0-RC1/528e2909860febae704e698990a86811fbdab705/micrometer-jakarta9-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-observation-test/1.15.0-RC1/8c844f9e9cea6c3e7ce20f467d359b8c526c9eb2/micrometer-observation-test-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-tracing-bridge-brave/1.5.0-RC1/9e0103f6cf6c9156fc33d44bdcb6be7b890e5a6/micrometer-tracing-bridge-brave-1.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-tracing-bridge-otel/1.5.0-RC1/2addaa63a1d022951d9de33df55b399423b593b7/micrometer-tracing-bridge-otel-1.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-tracing/1.5.0-RC1/4cf7f8335b183f3b0c74eee2f4d176daf73823c8/micrometer-tracing-1.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.amqp/spring-rabbit/3.2.5/706d36de584e349bb33076f26f8f6b258ce5a1d2/spring-rabbit-3.2.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.batch/spring-batch-core/5.2.2/141649d81fae24922d98775cd4b4aecc254528e6/spring-batch-core-5.2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.graphql/spring-graphql/1.4.0-RC1/2dbeea208e0e70cae394ab8720d237391e69e60d/spring-graphql-1.4.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-jpa/3.5.0-RC1/1c4544abbe664692b07f2f87cf8e6ce0b764915b/spring-data-jpa-3.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-mongodb/4.5.0-RC1/ebb9360bfe68136d89ee5bd4bf40f3e376078ede/spring-data-mongodb-4.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-ldap/3.5.0-RC1/24e2bd0e65831548fd36e8d52f263a37cc29d21e/spring-data-ldap-3.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-webmvc/6.2.6/48c37c417d00b9dc12e344892b206bbbf67f0945/spring-webmvc-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.integration/spring-integration-jmx/6.5.0-RC1/9dc106e9598bcaea808c6cf6141a402ec9f7449f/spring-integration-jmx-6.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.integration/spring-integration-core/6.5.0-RC1/66d38bf83bd730dadb4689dba55bcdb01e26a906/spring-integration-core-6.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-config/6.5.0-RC1/e16c916050c66d2de0c6518783eef7aca7390532/spring-security-config-6.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-oauth2-resource-server/6.5.0-RC1/e742f100a57df6da5327df45f7ebeff8eda8fe72/spring-security-oauth2-resource-server-6.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-saml2-service-provider/6.5.0-RC1/bc654efb12016c3d7a80b6df34a2d0335d145846/spring-security-saml2-service-provider-6.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-test/6.5.0-RC1/bbea2f265852ec8b0957093e95b6d964adcf0e64/spring-security-test-6.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-web/6.5.0-RC1/7c47d0d92e68a68f93c9a667ca15e52af886fa45/spring-security-web-6.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-redis/3.5.0-RC1/3e4a2ab212613408d86a4b23e8bb1a01b3d88306/spring-data-redis-3.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-context-support/6.2.6/e4d6f186e074dd3071906661637406554e4ecfcf/spring-context-support-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-keyvalue/3.5.0-RC1/f6d64936e5f57613fd3e3d913bee537127a4826e/spring-data-keyvalue-3.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.ldap/spring-ldap-core/3.3.0-RC1/4fc6072f9826c7c5b3ceffe261b421748368d55d/spring-ldap-core-3.3.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-oauth2-jose/6.5.0-RC1/199ae7dcecc2fe7cd50d21b98782c7e45bbc28bf/spring-security-oauth2-jose-6.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-oauth2-core/6.5.0-RC1/1aa2d1ebb59bb4e5c8914ba5e1053c36af5c1ca/spring-security-oauth2-core-6.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-core/6.5.0-RC1/bc73de8d5c3f6a826764082912b6fe0ae0d54fa5/spring-security-core-6.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.hateoas/spring-hateoas/2.5.0-RC1/d3a37d096ff73df0626012b08f510da0bfe7addd/spring-hateoas-2.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.plugin/spring-plugin-core/3.0.0/d56aa02dd7272dca30aa598dc8b72e823227046a/spring-plugin-core-3.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-context/6.2.6/ae08b2ec4a49ab7acb0b5eea7c309363139d54ad/spring-context-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-jms/6.2.6/7ec36a5812680863864521601fe3ab38fbbfcb1/spring-jms-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cache2k/cache2k-micrometer/2.6.1.Final/58731da010cc872915e012325027954bdc3122c8/cache2k-micrometer-2.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hibernate.orm/hibernate-micrometer/6.6.13.Final/3e099e56331cd11340c8cfcb3ea3bf413504ed1c/hibernate-micrometer-6.6.13.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-stackdriver/1.15.0-RC1/defc8096e3f5396cfb63dfd2830e1e8950662e82/micrometer-registry-stackdriver-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.ext/jersey-micrometer/3.1.10/99c62fbc9a0a70486674f2b81260fc2f172be90a/jersey-micrometer-3.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-java21/1.15.0-RC1/74199ecadde3fa301a01e6dee6a46add46db9b75/micrometer-java21-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-appoptics/1.15.0-RC1/9122f84ecc66c39d08088d83c506b043bf2227ef/micrometer-registry-appoptics-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-atlas/1.15.0-RC1/c0dd6b7a3e71b1bed2518b3166baa5391cfebee3/micrometer-registry-atlas-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-datadog/1.15.0-RC1/df9a0e49d9c3aeff600c796952a3fc6ee4d59b3c/micrometer-registry-datadog-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-dynatrace/1.15.0-RC1/ccf106834cd7dd1dc07e4a1c101c0635f53f1b59/micrometer-registry-dynatrace-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-elastic/1.15.0-RC1/80e8e2cb134f5116b56ce25cc4e9267370be9211/micrometer-registry-elastic-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-ganglia/1.15.0-RC1/506a4c7c9f3539b0855a6dc41ed6920baa2d000d/micrometer-registry-ganglia-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-graphite/1.15.0-RC1/7fe1d33f3b8150394717c986c663d29784ef606f/micrometer-registry-graphite-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-humio/1.15.0-RC1/3ba177d65c8fc87667e2452fe257fc023e74964b/micrometer-registry-humio-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-influx/1.15.0-RC1/96efca9fb01370b6961cfa4cdb43470af459912/micrometer-registry-influx-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-jmx/1.15.0-RC1/ea41981ed4404649f66c811490076b7e212020c6/micrometer-registry-jmx-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-kairos/1.15.0-RC1/f9f2c5cdbc846e67655c11bc12111c6a13846615/micrometer-registry-kairos-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-new-relic/1.15.0-RC1/7059eb2b7d37bec0767f4c33417400e50afa338/micrometer-registry-new-relic-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-otlp/1.15.0-RC1/e478181cef8efba8eb1c8d837fac03a2c9e457ed/micrometer-registry-otlp-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-prometheus/1.15.0-RC1/bed64196212a270e15a4885865950ef3b436e83e/micrometer-registry-prometheus-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-signalfx/1.15.0-RC1/b22db5ff67f33d23ca19811bf1c32784f5e6d15a/micrometer-registry-signalfx-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-statsd/1.15.0-RC1/ff6fdfba19e8b1a469864a26031ee7da5158aa92/micrometer-registry-statsd-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-core/1.15.0-RC1/cb45693ab302ea603937b3c02e556207663d529a/micrometer-core-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-webflux/6.2.6/85edcb71e32e1fab71369c622017ada8c779fa34/spring-webflux-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-web/6.2.6/17a4f806e877a1064a2442fe7545b0036fb9550f/spring-web-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-observation/1.15.0-RC1/1884d9a50210ad3651ebc3e2ce7a992de9240f00/micrometer-observation-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.reporter2/zipkin-reporter-brave/3.5.0/90f22269460ed8893b6a73248a0a4b0986ecea7c/zipkin-reporter-brave-3.5.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-zipkin/1.49.0/932d9bf9f634989dcd7c36df3273d930e4bb72c/opentelemetry-exporter-zipkin-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-otlp/1.49.0/13c344de7e46f87be7ccb28d29e08bb078f92af5/opentelemetry-exporter-otlp-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor.netty/reactor-netty-http/1.2.5/b3f2a54919a1e15ca9543380b045ba54ca4e57cc/reactor-netty-http-1.2.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-exporter-pushgateway/1.3.6/5e5ebc15a3bfa5ca77b6dd2da750bd80eeba3932/prometheus-metrics-exporter-pushgateway-1.3.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.r2dbc/r2dbc-pool/1.0.2.RELEASE/c6a07e2e312e9bc8a897759a1004023187451c4f/r2dbc-pool-1.0.2.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.r2dbc/r2dbc-proxy/1.1.5.RELEASE/ca3de357825915774cf2464deeaf470c368c7cd7/r2dbc-proxy-1.1.5.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.r2dbc/r2dbc-h2/1.0.0.RELEASE/b99b52c87e7f32136f58131ad7b7a3e2eb168f75/r2dbc-h2-1.0.0.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.r2dbc/r2dbc-spi/1.0.0.RELEASE/e3d15b2d27fdb8fdb76a181b21d5c752adf1d165/r2dbc-spi-1.0.0.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/activemq-openwire-legacy/6.1.6/97650c33b91f5bc9d7793e6b2fa9bf5e6e91576c/activemq-openwire-legacy-6.1.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/activemq-client/6.1.6/64c52537aebd2b88cb3c39e2aa2c5e833fc76772/activemq-client-6.1.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-jakarta-service-extensions/2.40.0/ceadbad2c639a1be89983614a3c4dd617534cc05/artemis-jakarta-service-extensions-2.40.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-jakarta-client/2.40.0/8e49b3c5b70dc83614e106c50b36a47e927f16d/artemis-jakarta-client-2.40.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.jms/jakarta.jms-api/3.1.0/e194cf91a3f908e4846542849ac11a8e0b3c68ad/jakarta.jms-api-3.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hibernate.orm/hibernate-core/6.6.13.Final/e7f1b2d53e89b9863dca12cd5f1b261ba413415b/hibernate-core-6.6.13.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.persistence/jakarta.persistence-api/3.1.0/66901fa1c373c6aff65c13791cc11da72060a8d6/jakarta.persistence-api-3.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.undertow/undertow-servlet/2.3.18.Final/d54a5f19d47abc27d11610f8af7dcb9eda000992/undertow-servlet-2.3.18.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty.ee10/jetty-ee10-webapp/12.0.19/99b8f3273b41d7862f1c4f54f48df03cf85a43b7/jetty-ee10-webapp-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty.ee10/jetty-ee10-servlet/12.0.19/e0b5fa5b9f30a707282fde836ee50e51b662085a/jetty-ee10-servlet-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.servlet/jakarta.servlet-api/6.0.0/abecc699286e65035ebba9844c03931357a6a963/jakarta.servlet-api-6.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/javax.cache/cache-api/1.1.1/c56fb980eb5208bfee29a9a5b9d951aba076bd91/cache-api-1.1.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-jdbc-store/2.40.0/feb17c992204d9d5b34cb621ce6be0018d52f62d/artemis-jdbc-store-2.40.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-dbcp2/2.13.0/6c854db2a54004880cb9d1e436d64d45a475bbcf/commons-dbcp2-2.13.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.kafka/kafka-clients/3.9.0/e87443101adb03975297788cf7f2b5387c3cfe2d/kafka-clients-3.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.logging.log4j/log4j-to-slf4j/2.24.3/da1143e2a2531ee1c2d90baa98eb50a28a39d5a7/log4j-to-slf4j-2.24.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.logging.log4j/log4j-api/2.24.3/b02c125db8b6d295adf72ae6e71af5d83bce2370/log4j-api-2.24.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat.embed/tomcat-embed-core/10.1.40/fc1c09b726336dc6f7dde0408cebb1a56a3a28d3/tomcat-embed-core-10.1.40.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat.embed/tomcat-embed-el/10.1.40/1b321790508c1d410689b4f496dae18a97fa6ae9/tomcat-embed-el-10.1.40.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat/tomcat-jdbc/10.1.40/4db003ae78770b37111953e56c340161ecae6e35/tomcat-jdbc-10.1.40.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-aspects/6.2.6/2bb7fe48b4fef28af71be32815200c19ac95f783/spring-aspects-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.aspectj/aspectjweaver/1.9.24/9b5aeb0cea9f958b9c57fb80e62996e95a3e9379/aspectjweaver-1.9.24.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cache2k/cache2k-spring/2.6.1.Final/cd312efb1645de91bdd8571b98273cb0acf52d15/cache2k-spring-2.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.angus/angus-mail/2.0.3/56f811522d693700013768db83b741a65da6c61c/angus-mail-2.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty.http2/jetty-http2-server/12.0.19/e9da998f4e24188efd9b75e14a91dd3ae89760e4/jetty-http2-server-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-ee/12.0.19/d5f9758628897272237fb8e3bb02dc2c1636690c/jetty-ee-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-session/12.0.19/7a8cab3e28b28ff8e6c3fda9311f8b72b9b05945/jetty-session-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-security/12.0.19/9c9e3bb94722579e37cd3f0f3356bcc238082628/jetty-security-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-server/12.0.19/9688d92d1b9809c8fc523f0cd2ff95d1d926aab9/jetty-server-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/co.elastic.clients/elasticsearch-java/8.17.4/c687fe9ee19bb2ca3da6628775908374abaa3be0/elasticsearch-java-8.17.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.elasticsearch.client/elasticsearch-rest-client/8.17.4/5f899f6c8be60ccedcf19f85ebc0694d41a1c090/elasticsearch-rest-client-8.17.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.ext/jersey-spring6/3.1.10/d1c894e01ea70cb41fb10f38974f7e56fc4a1538/jersey-spring6-3.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.containers/jersey-container-servlet-core/3.1.10/a2106c310bfc6847e5ed5ca85b306645ff6a0c66/jersey-container-servlet-core-3.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.core/jersey-server/3.1.10/c0c631cfa916560b24aa3f0af1550aec6a87e69f/jersey-server-3.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hibernate.validator/hibernate-validator/8.0.2.Final/220e64815dd87535525331de20570017f899eb13/hibernate-validator-8.0.2.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.influxdb/influxdb-java/2.25/9e1a7661b4f5bdcac9b8553f11ea18f3aa208751/influxdb-java-2.25.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.jupiter/junit-jupiter/5.12.2/64d3ec64ae06517bc14b7faaaec7c996b0d05bea/junit-jupiter-5.12.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mockito/mockito-junit-jupiter/5.17.0/4399e19e3fb5b55230027583323e4c883d5da07d/mockito-junit-jupiter-5.17.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.jupiter/junit-jupiter-params/5.12.2/ff1434a66d1fb84c2c709cde2e2d56d5c8f4fad3/junit-jupiter-params-5.12.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.jupiter/junit-jupiter-engine/5.12.2/b8df7575b8cd3a94dbe27b481d1cd52c57864559/junit-jupiter-engine-5.12.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.jupiter/junit-jupiter-api/5.12.2/6de3a3256c5d90f4a439edcb6c2e8dc5180907b0/junit-jupiter-api-5.12.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.platform/junit-platform-engine/1.12.2/8519ece93f91b8115705d36be2c36d49808935cd/junit-platform-engine-1.12.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.platform/junit-platform-commons/1.12.2/b89e88a89ee009937374a4c96912e007b34c8e35/junit-platform-commons-1.12.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.platform/junit-platform-launcher/1.12.2/79d49ad13017c67a8bf76e10ba5ac8937d811772/junit-platform-launcher-1.12.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.liquibase/liquibase-core/4.31.1/7578a1c2842d458c31eddb05c7ac82899af1893f/liquibase-core-4.31.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/mongodb-driver-reactivestreams/5.4.0/f6a6943c5b156a99629697ada49e3a7dedbd42b0/mongodb-driver-reactivestreams-5.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/mongodb-driver-sync/5.4.0/d653f1994afa21bc930ea509b92f75c2bfd6e5f/mongodb-driver-sync-5.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.neo4j.driver/neo4j-java-driver/5.28.4/a2d51625d4cf4ee0e55e49a184bc7f7b5ffd30e4/neo4j-java-driver-5.28.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.quartz-scheduler/quartz/2.5.0/f5f0e256f6c82299e0bccbf559a8ca38bd8c187b/quartz-2.5.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-orm/6.2.6/b579360aaab1e52ec95d0538cc3c89fa8689485d/spring-orm-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-jdbc/6.2.6/529137b0f92d8cfd13876e6aa8df9088246b4755/spring-jdbc-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-messaging/6.2.6/60547522ef488acc4c927dec64cf9bb2cca9022a/spring-messaging-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.session/spring-session-core/3.5.0-RC1/64a3c280ff45b53f5d4f94e3cd5afd78bb4824db/spring-session-core-3.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/redis.clients/jedis/5.2.0/a3e3905dcc06a48738783883d13f43873df22e31/jedis-5.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-otlp-common/1.49.0/3cbc37d54ed2afe360b45a239a4441682449ad53/opentelemetry-exporter-otlp-common-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-sender-okhttp/1.49.0/fc22759ea44f9b874f1589e50582ac5c2c961770/opentelemetry-exporter-sender-okhttp-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-common/1.49.0/e3a7e383ee7042380a6ce9280d49c6efd8a58555/opentelemetry-exporter-common-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor/reactor-test/3.7.5/7ab3b0c5b5b18e9defbf35c6b58b740beece1b43/reactor-test-3.7.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-exporter-common/1.3.6/f7438450887f9cf0aed9004272a8452fed6d83ad/prometheus-metrics-exporter-common-1.3.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-exposition-formats/1.3.6/13189bdc1931415f03c8993798902cec8e54fb10/prometheus-metrics-exposition-formats-1.3.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.okhttp3/mockwebserver/4.12.0/3bc54cc5c87cd632031d0881f3c313d3799a1476/mockwebserver-4.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.jayway.jsonpath/json-path/2.9.0/37fe2217f577b0b68b18e62c4d17a8858ecf9b69/json-path-2.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.undertow/undertow-core/2.3.18.Final/981cd13a9f0a626c9365a83d7f8ce1e932d5e4de/undertow-core-2.3.18.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-oxm/6.2.6/b5d94c0552ad63802454d248bddfe976617064a0/spring-oxm-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jaxb/jaxb-runtime/4.0.5/ca84c2a7169b5293e232b9d00d1e4e36d4c3914a/jaxb-runtime-4.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jaxb/jaxb-core/4.0.5/7b4b11ea5542eea4ad55e1080b23be436795b3/jaxb-core-4.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.xml.bind/jakarta.xml.bind-api/4.0.2/6cd5a999b834b63238005b7144136379dc36cad2/jakarta.xml.bind-api-4.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.aspectj/aspectjrt/1.9.24/c3e1f7f219500466e49fa963a2b9870cc2480cb/aspectjrt-1.9.24.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.assertj/assertj-core/3.27.3/31f5d58a202bd5df4993fb10fa2cffd610c20d6f/assertj-core-3.27.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.awaitility/awaitility/4.3.0/f0c0bc1e404e500bab3f498b922eaedeae1c0207/awaitility-4.3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cache2k/cache2k-core/2.6.1.Final/7e333caaafa2bf4e489b58537b5c4218a4e6505/cache2k-core-2.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cache2k/cache2k-api/2.6.1.Final/6afd23d7897fff56515f0cefa6a846bdebe10bce/cache2k-api-2.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/junit/junit/4.13.2/8ac9e16d933b6fb43bc7f576336b8f4d7eb5ba12/junit-4.13.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hamcrest/hamcrest-library/3.0/d42c7c6c28654a3d1eb654edaa82fd85c01ce417/hamcrest-library-3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hamcrest/hamcrest-core/3.0/254f69f4b0ca22198acfc19fcdd5f96140431c3e/hamcrest-core-3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hamcrest/hamcrest/3.0/8fd9b78a8e6a6510a078a9e30e9e86a6035cfaf7/hamcrest-3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hsqldb/hsqldb/2.7.3/85b49338b36f3051d217295596cf92beb92e4bfb/hsqldb-2.7.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mockito/mockito-core/5.17.0/f5fe5a2f94eb65f4f83ca0607bfe13ec0d9c6f3b/mockito-core-5.17.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.skyscreamer/jsonassert/1.5.3/aaa43e0823d2a0e106e8754d6a9c4ab24e05e9bc/jsonassert-1.5.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-core-test/6.2.6/d9c83406fb85b9cb6f4db3d31f47dae92f223301/spring-core-test-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-test/6.2.6/1f1d95749dca9a7535f0ba51e1dfdbf987bebcf1/spring-test-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.yaml/snakeyaml/2.4/e0666b825b796f85521f02360e77f4c92c5a7a07/snakeyaml-2.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.management.j2ee/jakarta.management.j2ee-api/1.1.4/dbbe7575f97efd0b04f3a8455cf82c256c853055/jakarta.management.j2ee-api-1.1.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.transaction/jakarta.transaction-api/2.0.1/51a520e3fae406abb84e2e1148e6746ce3f80a1a/jakarta.transaction-api-2.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-saml-impl/4.0.1/995986fd848ede1443469f3aff1f82b740224262/opensaml-saml-impl-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-saml-api/4.0.1/2205aba935f4da468382a3dc5f32c3821ec1564c/opensaml-saml-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-soap-impl/4.0.1/38bfaf5fc189774e94ead218bd1c754da295c226/opensaml-soap-impl-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-profile-api/4.0.1/bece5f6d30d4051e6eeaf2b88dd1e5a13f6b28b7/opensaml-profile-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-soap-api/4.0.1/d8e11e31cb5164788a530478e1831969e94a38b6/opensaml-soap-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-xmlsec-impl/4.0.1/efa15ba85127ac3b20c75b8d4f04c7e92325a00a/opensaml-xmlsec-impl-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-xmlsec-api/4.0.1/edb4365d3d183933cf0d0b31966ea352b8d20c60/opensaml-xmlsec-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-security-impl/4.0.1/64568e9aa8bd7bcd76983e462f9eb2c3dcacbdce/opensaml-security-impl-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-security-api/4.0.1/f3d33ca18cde2a7c7e3643aeca9f03974be9577d/opensaml-security-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-messaging-api/4.0.1/eb9c9971f6bd2a6681a2a692a1f29a35874de389/opensaml-messaging-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-core/4.0.1/ec3d1734137d6ccabba7d6d5e149f571beeaa673/opensaml-core-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-tx/6.2.6/fb46b2d651a6c509625bc6e7e38865137f658eca/spring-tx-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.amqp/spring-amqp/3.2.5/450307954c2fde84d81d2418dc4c20fd95b6425e/spring-amqp-3.2.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-commons/3.5.0-RC1/37144d2eb580d48d3bbb3af59ff5102594a4861d/spring-data-commons-3.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-aop/6.2.6/ab5502a1e9694f2ecd001ecb1ee1fc46b29cfbd9/spring-aop-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-beans/6.2.6/d43abe3b5765748210c511043b1d4904ca216a9f/spring-beans-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.batch/spring-batch-infrastructure/5.2.2/19e109ec420e6e6c191b7a5f3262b7fded4c348d/spring-batch-infrastructure-5.2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-expression/6.2.6/d9efc768cfda1d97c8fe769a9d50f936eb7f18e2/spring-expression-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-core/6.2.6/4639dac5fc46cb6a9f6eb2709decfb90313e0f2c/spring-core-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.vaadin.external.google/android-json/0.0.20131108.vaadin1/fa26d351fe62a6a17f5cda1287c1c6110dec413f/android-json-0.0.20131108.vaadin1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-resolver-provider/3.9.4/d5e38634c1251e000f7718437973a730346bc336/maven-resolver-provider-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-model-builder/3.9.4/b12e45736ddfb51f648e1579877a293659e5a96e/maven-model-builder-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-connector-basic/1.9.14/ffeb368f5587513b29ef9771514ec36d246e65f5/maven-resolver-connector-basic-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-impl/1.9.14/2aa090aca572f7061e5c57f714ef0445bbb4555f/maven-resolver-impl-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-transport-http/1.9.14/1eb4acdce7f21526bd06654b3d7b1edf80370ce8/maven-resolver-transport-http-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-spi/1.9.14/a190c3d49791240c87799f29848505fc9fd8be11/maven-resolver-spi-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-util/1.9.14/ea6fd2997903700191711dee4448746ed30fe4b9/maven-resolver-util-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-api/1.9.14/bd5b7cd9d15c2efcab4d8c8215e769523e8843e4/maven-resolver-api-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/context-propagation/1.1.3/19cea055eed20e80875705fcf9943ca8e978cf92/context-propagation-1.1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.core/jersey-client/3.1.10/35d87d5a4af28c80e380a00efba94d9af8998849/jersey-client-3.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.inject/jersey-hk2/3.1.10/85fa449300069937189bf0cfeb6da765e5e3854a/jersey-hk2-3.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.core/jersey-common/3.1.10/d9d17fdec864f33de58efe240ec53816f95c03f3/jersey-common-3.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2/3.0.6/12187beb6321e6a7fdc2ef4d196e16c8c58a3a1/hk2-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-core/3.0.6/78dfb2117c3148e357a0cec8f514e60bbf689efd/hk2-core-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-runlevel/3.0.6/3c347e9bb20f13d98b72ae2b4fc84f14bcbb187e/hk2-runlevel-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-locator/3.0.6/92d5c92c9f23bea4b8681c6f8d6ba3d708619f81/hk2-locator-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-api/3.0.6/5a5152dea2c43384f5c07985eb27140134074ecb/hk2-api-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-utils/3.0.6/b3187d0673c0fd52de197e52c62545c34d4eda29/hk2-utils-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.inject/jakarta.inject-api/2.0.1/4c28afe1991a941d7702fe1362c365f0a8641d1e/jakarta.inject-api-2.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-storage-api/4.0.1/4e46a7f965ac9f91976b0f298fd4d4e69e9056db/opensaml-storage-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.shibboleth.utilities/java-support/8.0.0/298f946e93922d789b6231599a446cea9dbbe80e/java-support-8.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.santuario/xmlsec/2.1.4/cb43326f02e3e77526c24269c8b5d3cc3f7f6653/xmlsec-2.1.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.cloud/google-cloud-monitoring/3.61.0/4498704cf08eddfbba30ff9116e2857d8ebf54e7/google-cloud-monitoring-3.61.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.auth/google-auth-library-oauth2-http/1.33.1/dacefb5c52f35713b3c1ae42fb2f85fb15e6fcfe/google-auth-library-oauth2-http-1.33.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.http-client/google-http-client-gson/1.46.3/ca996d6b803d1eecb5d24f60c63687ced9b28088/google-http-client-gson-1.46.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.http-client/google-http-client/1.46.3/486ca37492048ddd230f5fef65c9411d7b65fb67/google-http-client-1.46.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.httpcomponents/httpclient/4.5.14/1194890e6f56ec29177673f2f12d0b8e627dec98/httpclient-4.5.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/commons-codec/commons-codec/1.18.0/ee45d1cf6ec2cc2b809ff04b4dc7aec858e0df8f/commons-codec-1.18.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opencensus/opencensus-contrib-http-util/0.31.1/3c13fc5715231fadb16a9b74a44d9d59c460cfa8/opencensus-contrib-http-util-0.31.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.guava/guava/33.4.0-jre/3fcc0a259f724c7de54a6a55ea7e26d3d5c0cac/guava-33.4.0-jre.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api.grpc/proto-google-cloud-monitoring-v3/3.61.0/9ba5d8e9e12d52f1ab7ac1b61bb2df9967179dc8/proto-google-cloud-monitoring-v3-3.61.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.code.findbugs/jsr305/3.0.2/25ea2e8b0c338a877313bd4672d3fe056ea78f0d/jsr305-3.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.dropwizard.metrics/metrics-graphite/4.2.30/a3496cf1147482e8974f322296e92e421f0eff13/metrics-graphite-4.2.30.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.dropwizard.metrics/metrics-jmx/4.2.30/71068f43e2aaca144a04ace266fbf62160ee253b/metrics-jmx-4.2.30.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.dropwizard.metrics/metrics-core/4.2.30/4c0093ffbe0d6a90253e47277ce6dc4f759aff7b/metrics-core-4.2.30.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.velocity/velocity-engine-core/2.2/68d899cb70cd27d495562fa808feb2da4926d38f/velocity-engine-core-2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-named-locks/1.9.14/71cf74d91b4f6de1bff8fc1fafb401d9ac42b1b8/maven-resolver-named-locks-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-core-client/2.40.0/9f897c3b14da44d9b045595316e39c55072ae6a4/artemis-core-client-2.40.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-selector/2.40.0/58dae473d6ee8805503167086cfd8d862627c606/artemis-selector-2.40.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-journal/2.40.0/bf46c2fd3761c0e7f22fb6e61489ebf157e87013/artemis-journal-2.40.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-lockmanager-api/2.40.0/7e29a26a20f9aad01e12bc862f18f6fb54e6ec10/artemis-lockmanager-api-2.40.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-commons/2.40.0/5c428a029199ae6ef8816e39292f348d554c15b0/artemis-commons-2.40.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-xml/12.0.19/c19a05516530b9f19a620d80c5a40d4708b2da40/jetty-xml-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty.http2/jetty-http2-common/12.0.19/509cab703028dbdea742832c3d4103e17d377db1/jetty-http2-common-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty.http2/jetty-http2-hpack/12.0.19/b8e1620f022665ad2e357acec5568867aea64253/jetty-http2-hpack-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-http/12.0.19/f992617613998fb592dfd267446c2182376ca029/jetty-http-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-io/12.0.19/b949237228faf1407eea07352103e46279cb8fff/jetty-io-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.netflix.spectator/spectator-reg-atlas/1.8.10/e238bbc010e91eac5cd3cc43d5ba285420f4ce3f/spectator-reg-atlas-1.8.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.rabbitmq/amqp-client/5.25.0/f3303742cae7b0ef37b9966a54de82b635dc0207/amqp-client-5.25.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-util/12.0.19/5dd72392608420f6828c9a3b4bec4f37f83dfcd8/jetty-util-12.0.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.netflix.spectator/spectator-ext-ipc/1.8.10/8726595efef28717a0082774493f899ef10de1e1/spectator-ext-ipc-1.8.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.netflix.spectator/spectator-api/1.8.10/b08be7b22a3f514759bbb2182052cf4df600d549/spectator-api-1.8.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.couchbase.client/java-client/3.8.0/e7349c3d4ab663cc3db24459ebdbe12ebde1d5c8/java-client-3.8.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.couchbase.client/core-io/3.8.0/90cb721152c1a278168f92deef65aa57a97e1814/core-io-3.8.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/de.dentrassi.crypto/pem-keystore/3.0.0/80bfceb7eddd28ba8a49a512b58f4e446aff924b/pem-keystore-3.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.hierynomus/asn-one/0.6.0/7f6141541e0a4d3ae0b02c901c2c1e9a772eb3d7/asn-one-0.6.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.slf4j/slf4j-api/2.0.17/d9e58ac9c7779ba3bf8142aff6c830617a7fe60f/slf4j-api-2.0.17.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.httpcomponents/httpcore/4.4.16/51cf043c87253c9f58b539c9f7e44c8894223850/httpcore-4.4.16.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.okhttp3/logging-interceptor/4.12.0/e922c1f14d365c0f2bed140cc0825e18462c2778/logging-interceptor-4.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.reporter2/zipkin-sender-okhttp3/3.5.0/378d4baeba330c7f1c44a53472957a9f412be528/zipkin-sender-okhttp3-3.5.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.retrofit2/converter-moshi/2.9.0/db0979801926e6d39bc2478736145f9761c3e034/converter-moshi-2.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.retrofit2/retrofit/2.9.0/d8fdfbd5da952141a665a403348b74538efc05ff/retrofit-2.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.okhttp3/okhttp/4.12.0/2f4525d4a200e97e1b87449c2cd9bd2e25b7e8cd/okhttp-4.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.okio/okio-jvm/3.6.0/5600569133b7bdefe1daf9ec7f4abeb6d13e1786/okio-jvm-3.6.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jetbrains.kotlin/kotlin-stdlib-jdk7/1.9.25/1c166692314a2639e5edfed0d23ed7eee4a5c7a5/kotlin-stdlib-jdk7-1.9.25.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jetbrains.kotlin/kotlin-stdlib/1.9.25/f700a2f2b8f0d6d0fde48f56d894dc722fb029d7/kotlin-stdlib-1.9.25.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jetbrains.kotlin/kotlin-stdlib-jdk8/1.9.25/20d44e880a284f7b5cd99dd69450b403073f49b2/kotlin-stdlib-jdk8-1.9.25.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.bytebuddy/byte-buddy/1.17.5/88450f120903b7e72470462cdbd2b75a3842223c/byte-buddy-1.17.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.bytebuddy/byte-buddy-agent/1.17.5/58f9507f5f28d1d3e7adfb4ec2fe37c29d332c9b/byte-buddy-agent-1.17.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml/classmate/1.7.0/e98374da1f2143ac8e6e0a95036994bb19137a3/classmate-1.7.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.opencsv/opencsv/5.9/284ea0b60a24b71a530100783185e7d547ab5339/opencsv-5.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-configuration2/2.11.0/af5a2c6abe587074c0be1107fcb27fa2fad91304/commons-configuration2-2.11.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-text/1.13.0/ba2ed5521c491cabf7ecdb57f77922561c2e8958/commons-text-1.13.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-artifact/3.9.4/9738999a0459221e758ebe728449c43567d7fecc/maven-artifact-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-lang3/3.17.0/b17d2136f0460dcc0d2016ceefca8723bdf4ee70/commons-lang3-3.17.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-pool2/2.12.1/e5c7b6c9f5a4b59be2bba213fbec70b413376fc1/commons-pool2-2.12.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.graphql-java/graphql-java/23.1/a30b85fa821dbbf482fc62654d28796993a2bc9d/graphql-java-23.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.code.gson/gson/2.13.1/853ce06c11316b33a8eae5e9095da096a9528b8f/gson-2.13.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.h2database/h2/2.3.232/4fcc05d966ccdb2812ae8b9a718f69226c0cf4e2/h2-2.3.232.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.httpcomponents/httpasyncclient/4.1.5/cd18227f1eb8e9a263286c1d7362ceb24f6f9b32/httpasyncclient-4.1.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.httpcomponents/httpcore-nio/4.4.16/cd21c80a9956be48c4c1cfd2f594ba02857d0927/httpcore-nio-4.4.16.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.angus/angus-activation/2.0.2/41f1e0ddd157c856926ed149ab837d110955a9fc/angus-activation-2.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.mail/jakarta.mail-api/2.1.3/a327aa5f514ba86e80d54584417d7376ed2bde0e/jakarta.mail-api-2.1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.activation/jakarta.activation-api/2.1.3/fa165bd70cda600368eee31555222776a46b881f/jakarta.activation-api-2.1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.annotation/jakarta.annotation-api/2.1.1/48b9bda22b091b1f48b13af03fe36db3be6e1ae3/jakarta.annotation-api-2.1.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.parsson/parsson/1.0.5/f68020271ff70f79412f70ca45973703b6e907c/parsson-1.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.json/jakarta.json-api/2.1.3/4febd83e1d9d1561d078af460ecd19532383735c/jakarta.json-api-2.1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.validation/jakarta.validation-api/3.0.2/92b6631659ba35ca09e44874d3eb936edfeee532/jakarta.validation-api-3.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.ext/jersey-entity-filtering/3.1.10/6528601d67f788e0b9ebaee28ea045bc93cd81f6/jersey-entity-filtering-3.1.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.ws.rs/jakarta.ws.rs-api/3.1.0/15ce10d249a38865b58fc39521f10f29ab0e3363/jakarta.ws.rs-api-3.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jboss.xnio/xnio-nio/3.8.16.Final/9aab17706a371a212fd051b09c7959d29d051379/xnio-nio-3.8.16.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jboss.xnio/xnio-api/3.8.16.Final/7c98c649a4583523c23cc0a7e62ddace1f486b54/xnio-api-3.8.16.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.wildfly.client/wildfly-client-config/1.0.1.Final/2a803b23c40a0de0f03a90d1fd3755747bc05f4b/wildfly-client-config-1.0.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jboss.threads/jboss-threads/3.5.0.Final/dd23d4788b3eafe9597ef3fe028e46ceb293ba8d/jboss-threads-3.5.0.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jboss.logging/jboss-logging/3.6.1.Final/886afbb445b4016a37c8960a7aef6ebd769ce7e5/jboss-logging-3.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.minidev/json-smart/2.5.2/95d166b18f95907be0f46cdb9e1c0695eed03387/json-smart-2.5.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/ch.qos.logback/logback-core/1.5.18/6c0375624f6f36b4e089e2488ba21334a11ef13f/logback-core-1.5.18.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor.addons/reactor-pool/1.1.2/9b6334fbf10cfa816b1e97183966a64ca6b67334/reactor-pool-1.1.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor.netty/reactor-netty-core/1.2.5/42af645f3cfc221f74573103773a9def598d2231/reactor-netty-core-1.2.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor/reactor-core/3.7.5/2ffb9b7043593da9a80b91f14cc30f4914183f3a/reactor-core-3.7.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.graphql-java/java-dataloader/4.0.0/95c0e8714f00d695aba6c625d970f4e9ab52cd7f/java-dataloader-4.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.reactivestreams/reactive-streams/1.0.4/3864a1320d97d7b045f729a326e1e077661f31b7/reactive-streams-1.0.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.retry/spring-retry/2.0.11/bd4fae67445baf330b69b6b786748a308ab31f6/spring-retry-2.0.11.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat/tomcat-annotations-api/10.1.40/3ecf7d64aa485e3c9847e84b213d276bc2a69b0/tomcat-annotations-api-10.1.40.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-model/3.9.4/5b79d873cf6d13b3fc4020eac04e2a62ebbfa0aa/maven-model-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-repository-metadata/3.9.4/ef368d45a2caa54634de221540994ca2d810c4c9/maven-repository-metadata-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.codehaus.plexus/plexus-utils/3.5.1/c6bfb17c97ecc8863e88778ea301be742c62b06d/plexus-utils-3.5.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.guava/failureaccess/1.0.2/c4a06a64e650562f30b7bf9aaec1bfed43aca12b/failureaccess-1.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.guava/listenablefuture/9999.0-empty-to-avoid-conflict-with-guava/b421526c5f297295adef1c886e5246c39d4ac629/listenablefuture-9999.0-empty-to-avoid-conflict-with-guava.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.checkerframework/checker-qual/3.49.0/54be36cb42c9b991c109e467e2bfa82af4cda44e/checker-qual-3.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.errorprone/error_prone_annotations/2.38.0/fc0ae991433e8590ba51cd558421478318a74c8c/error_prone_annotations-2.38.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.j2objc/j2objc-annotations/3.0.0/7399e65dd7e9ff3404f4535b2f017093bdb134c7/j2objc-annotations-3.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cryptacular/cryptacular/1.2.4/4994c015d87886212683245d13e87f6fb903a760/cryptacular-1.2.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.bouncycastle/bcpkix-jdk15on/1.64/3dac163e20110817d850d17e0444852a6d7d0bd7/bcpkix-jdk15on-1.64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.bouncycastle/bcprov-jdk15on/1.64/1467dac1b787b5ad2a18201c0c281df69882259e/bcprov-jdk15on-1.64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.woodstox/woodstox-core/7.0.0/beb19c02e7e28a8a4acf4a9cc8c3280ec3b94722/woodstox-core-7.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.reporter2/zipkin-reporter/3.5.0/d9cf12e2cafb67130b20f639ba045341a7571dc7/zipkin-reporter-3.5.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.aws/brave-propagation-aws/1.3.0/c34a1d6e21b7359aeb3f3be63b9042e2297d6598/brave-propagation-aws-1.3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.brave/brave-context-slf4j/6.1.0/eefcfa360464a1776a69e3f21719f9e0c1cfdaba/brave-context-slf4j-6.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.brave/brave-instrumentation-http/6.1.0/acc098f6f21446c8f8750d942b003a8a67942b8b/brave-instrumentation-http-6.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.brave/brave/6.1.0/dee3c145aeed7e2618f32cfa76902257ec77eb31/brave-6.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.cassandra/java-driver-guava-shaded/4.19.0/1bd03bb761905d9568189c9f37da01ba07f4b8ee/java-driver-guava-shaded-4.19.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.datastax.oss/native-protocol/1.5.1/97e812373a5fe7667384e7ad67819d2c71878bf8/native-protocol-1.5.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jaxb/txw2/4.0.5/f36a4ef12120a9bb06d766d6a0e54b144fd7ed98/txw2-4.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.sun.istack/istack-commons-runtime/4.1.2/18ec117c85f3ba0ac65409136afa8e42bc74e739/istack-commons-runtime-4.1.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jspecify/jspecify/1.0.0/7425a601c1c7ec76645a78d22b8c6a627edee507/jspecify-1.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-commons/1.15.0-RC1/3331846b991c8cd1f1ef478aa23f387db7f21e9/micrometer-commons-1.15.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/mongodb-driver-core/5.4.0/841d146db6f27815825585a2c1beec50fb986185/mongodb-driver-core-5.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/bson-record-codec/5.4.0/8c026aff119a12ec477be552aecfd880885c74e0/bson-record-codec-5.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/bson/5.4.0/cf10fa61c22e8b2e292388020295669470b3ee23/bson-5.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.neo4j.bolt/neo4j-bolt-connection-netty/1.1.0/37e8c3ac3c60a35bde327ccd989b2a167a3b25d0/neo4j-bolt-connection-netty-1.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec-http2/4.1.119.Final/648b066861723b60635bef2047229ed73d0cbd04/netty-codec-http2-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-handler-proxy/4.1.119.Final/50a0d16a6e5c714a6f2bfe49badd9678da4a0a92/netty-handler-proxy-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec-http/4.1.119.Final/23196984df6083cc39bef22a54c6cf5b157f3824/netty-codec-http-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-resolver-dns-native-macos/4.1.119.Final/23cc363910cf38e2de91ab8703bb05373e6d2e42/netty-resolver-dns-native-macos-4.1.119.Final-osx-x86_64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-resolver-dns-classes-macos/4.1.119.Final/6185080a70da30c1efa315ae3780c5baca6ff306/netty-resolver-dns-classes-macos-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-resolver-dns/4.1.119.Final/aa1809477e369484dbe52b99cb2a5e1228be2fc4/netty-resolver-dns-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-handler/4.1.119.Final/a0059b8d779ce566b524efd6d73ba4fcff3cd5d9/netty-handler-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-native-epoll/4.1.119.Final/500fdc2000a47c07ad6c0ea230127f5ac3c9ad5c/netty-transport-native-epoll-4.1.119.Final-linux-x86_64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-classes-epoll/4.1.119.Final/1d2d986ae0615d50f5cee338f0e9e73f46e8158/netty-transport-classes-epoll-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-native-kqueue/4.1.119.Final/d599d0cf9710adc28dd3cb34d323edd03a6d28b3/netty-transport-native-kqueue-4.1.119.Final-osx-x86_64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-classes-kqueue/4.1.119.Final/e3e70378ab16b97af83b79dc67227299ae20c90/netty-transport-classes-kqueue-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-native-unix-common/4.1.119.Final/55afdeb456bccf8eecb06431f3c1537269afe9af/netty-transport-native-unix-common-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec-socks/4.1.119.Final/18ea7a77080c64e9f63f5b79367461b4b1d53a2e/netty-codec-socks-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec-dns/4.1.119.Final/a5e64de87e9b90434832a185891bfcbca87a2b7b/netty-codec-dns-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec/4.1.119.Final/337ca8e8c3ef23925e02d56347b414d7616d1d02/netty-codec-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport/4.1.119.Final/d05df879054297962d056b77460fc4ff20e30073/netty-transport-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-buffer/4.1.119.Final/5864149b2e5a2af7b05fe9e9dc3e4b70d3060a7c/netty-buffer-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-resolver/4.1.119.Final/e1f7c90aff71bdf0e2294a200b5f89244f88dcf7/netty-resolver-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-common/4.1.119.Final/2f7c360b03c0aceab7efc1f7c2b75274f0f35909/netty-common-4.1.119.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-tcnative-classes/2.0.70.Final/5f75accc769e69f2e6c1e56ba3a08b6c4bcc25f8/netty-tcnative-classes-2.0.70.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-extension-autoconfigure-spi/1.49.0/8e50edb776225ff7c9fc60e34702ef748fca765d/opentelemetry-sdk-extension-autoconfigure-spi-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk/1.49.0/85e0b7a9920118e25a79851b71228a5000db74d8/opentelemetry-sdk-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-trace/1.49.0/f6ebec3f8e5181a0d1be82cfb5c9a5a9b6be14c7/opentelemetry-sdk-trace-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-metrics/1.49.0/1eae6b8b460b24bec7ce68786e7bb63d7b93e170/opentelemetry-sdk-metrics-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-logs/1.49.0/7b8897105c46f560a6a43bd08277a55641fa4405/opentelemetry-sdk-logs-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-common/1.49.0/6434472ab86600910d8b5f0346653bbc8f8b7067/opentelemetry-sdk-common-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-extension-trace-propagators/1.49.0/c75a1fb9ba9b5e26160fbaebf5225822994b09f5/opentelemetry-extension-trace-propagators-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-api/1.49.0/caff686096f0f99257c16dda87a3ca45b9f0cd25/opentelemetry-api-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-context/1.49.0/824271413685e92b21d0554637edb1d4446ba3d0/opentelemetry-context-1.49.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-core/1.3.6/44ed241094654bc74b92190e2b20053cfe025c72/prometheus-metrics-core-1.3.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-exposition-textformats/1.3.6/dd3bc5613557d700d7f9f8d6fc466fd8f9ae15c4/prometheus-metrics-exposition-textformats-1.3.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-config/1.3.6/752835b9c6864548517543bee2541dc49b2328e4/prometheus-metrics-config-1.3.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-model/1.3.6/c596fb819e2210ed0b342b9bd89b1fbb7b80b6f9/prometheus-metrics-model-1.3.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-tracer-common/1.3.6/a690d4105fbb74b4d426ad361473e42dfaf400f9/prometheus-metrics-tracer-common-1.3.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-jcl/6.2.6/f4468f33de0015179abb6055964801bc962f8d51/spring-jcl-6.2.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-crypto/6.5.0-RC1/6535a3597f96d497e9fde85d1c670fea505df18d/spring-security-crypto-6.5.0-RC1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.typesafe/config/1.4.1/19058a07624a87f90d129af7cd9c68bee94535a9/config-1.4.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-posix/3.1.15/f7d6737adcbd5925d625b8f99166de2cbf13caac/jnr-posix-3.1.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hdrhistogram/HdrHistogram/2.2.2/7959933ebcc0f05b2eaa5af0a0c8689fa257b15c/HdrHistogram-2.2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hibernate.common/hibernate-commons-annotations/7.0.3.Final/e183c4be8bb41d12e9f19b374e00c34a0a85f439/hibernate-commons-annotations-7.0.3.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.smallrye/jandex/3.2.0/f17ad860f62a08487b9edabde608f8ac55c62fa7/jandex-3.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.antlr/antlr4-runtime/4.13.0/5a02e48521624faaf5ff4d99afc88b01686af655/antlr4-runtime-4.13.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.msgpack/msgpack-core/0.9.8/6ea511f551465a0c9670e1bfb403c15d3315b540/msgpack-core-0.9.8.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.json/json/20240303/ebb88e8fb5122b7506d5cf1d69f1ccdb790d22a/json-20240303.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.luben/zstd-jni/1.5.6-4/ba9e303e0b5e94cdd0017390d7d8c06f47fd61f7/zstd-jni-1.5.6-4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.lz4/lz4-java/1.8.0/4b986a99445e49ea5fbf5d149c4b63f6ed6c6780/lz4-java-1.8.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.xerial.snappy/snappy-java/1.1.10.5/ac605269f3598506196e469f1fb0d7ed5c55059e/snappy-java-1.1.10.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.rocksdb/rocksdbjni/7.9.2/6409b667493149191b09fe1fce94bada6096a3e9/rocksdbjni-7.9.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-collections4/4.4/62ebe7544cb7164d87e0637a2a6a2bdc981395e8/commons-collections4-4.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/commons-io/commons-io/2.18.0/44084ef756763795b31c578403dd028ff4a22950/commons-io-2.18.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.neo4j.bolt/neo4j-bolt-connection-pooled/1.1.0/4f3f9502926601fd6180315fe755cd4d7193294e/neo4j-bolt-connection-pooled-1.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.neo4j.bolt/neo4j-bolt-connection-routed/1.1.0/4165cf75cd4a9266f044c859339e4e8eb15b21e8/neo4j-bolt-connection-routed-1.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.neo4j.bolt/neo4j-bolt-connection/1.1.0/53b2acda90771732d8286eae207767853a754354/neo4j-bolt-connection-1.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat/tomcat-juli/10.1.40/cb75a8fe659c7b70d789b2dfa67f0e394f0a6a3b/tomcat-juli-10.1.40.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.codehaus.plexus/plexus-interpolation/1.26/25b919c664b79795ccde0ede5cee0fd68b544197/plexus-interpolation-1.26.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-builder-support/3.9.4/671110e56110d5c89eda904f198719a2b5fa4a21/maven-builder-support-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.sisu/org.eclipse.sisu.inject/0.3.5/d4265dd4f0f1d7a06d80df5a5f475d5ff9c17140/org.eclipse.sisu.inject-0.3.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.codehaus.woodstox/stax2-api/4.2.2/b0d746cadea928e5264f2ea294ea9a1bf815bbde/stax2-api-4.2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.fusesource.hawtbuf/hawtbuf/1.11/8f0e50ad8bea37b84b698ec40cce09e47714a63e/hawtbuf-1.11.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/spring-bridge/3.0.6/e7047f31108550310f1ed9c2814caea58d875ccc/spring-bridge-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.dynatrace.metric.util/dynatrace-metric-utils-java/2.2.1/a25d8db688874b00aef7539d3bcefda603024c60/dynatrace-metric-utils-java-2.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/info.ganglia.gmetric4j/gmetric4j/1.0.10/3d62003123b586adb86cb028cc0f8a8c3a701d81/gmetric4j-1.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry.proto/opentelemetry-proto/1.5.0-alpha/fb744be44e48818d8f0c97ef7b6bcc82ad3d2626/opentelemetry-proto-1.5.0-alpha.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.signalfx.public/signalfx-java/1.0.49/171fc4b2e0c5933437e81ed456be932f9f62291c/signalfx-java-1.0.49.jar:/home/runner/.gradle/caches/modules-2/files-2.1/aopalliance/aopalliance/1.0/235ba8b489512805ac13a8f9ea77a1ca5ebe3e8/aopalliance-1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.contrib.brave-propagation-w3c/brave-propagation-tracecontext/0.2.0/bdc26787eb3bf99e7172b53df4e170e9a067b44/brave-propagation-tracecontext-0.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry.semconv/opentelemetry-semconv/1.32.0/1b7114e94ed7ac6ebc79f885dabb174a428c1c88/opentelemetry-semconv-1.32.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.objenesis/objenesis/3.3/1049c09f1de4331e8193e579448d0916d75b7631/objenesis-3.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.thoughtworks.qdox/qdox/2.2.0/39651eb3ce73d6e506490ea352e1e13eab6b55e8/qdox-2.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.nimbusds/nimbus-jose-jwt/9.37.3/700f71ffefd60c16bd8ce711a956967ea9071cec/nimbus-jose-jwt-9.37.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.latencyutils/LatencyUtils/2.0.3/769c0b82cb2421c8256300e907298a9410a2a3d3/LatencyUtils-2.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-ffi/2.2.11/bcf004ce358c87fc4cd2853b658d336348d0370f/jnr-ffi-2.2.11.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-constants/0.10.3/af19ec7359dd72cbc7869c00bf7cdfa4c308e985/jnr-constants-0.10.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.moshi/moshi/1.8.0/752e7b187599d3ccb174d00ba7235e29add736be/moshi-1.8.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opencensus/opencensus-api/0.31.1/66a60c7201c2b8b20ce495f0295b32bb0ccbbc57/opencensus-api-0.31.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-context/1.70.0/375570c198b9ff46f2202731d11271bb5cb396fa/grpc-context-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-api/1.70.0/c0d185f8435e2dbc9b0f430d1e89600858ee24ee/grpc-api-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-stub/1.70.0/b9aec2580e53ff84c01752cd07a8fa050d924336/grpc-stub-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.codehaus.mojo/animal-sniffer-annotations/1.24/aa9ba58d30e0aad7f1808fce9c541ea3760678d8/animal-sniffer-annotations-1.24.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-protobuf/1.70.0/3927190c6a6968c285b7a318064cb49cee44dbae/grpc-protobuf-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-protobuf-lite/1.70.0/e9c211eaf74510bce07f2215a2c8ae81338f77dc/grpc-protobuf-lite-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api/api-common/2.46.1/b38a684c734963a72c204aa208dd31018d79bf3a/api-common-2.46.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.auto.value/auto-value-annotations/1.11.0/f0d047931d07cfbc6fa4079854f181ff62891d6f/auto-value-annotations-1.11.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.protobuf/protobuf-java/4.28.3/625a6534f0baef7e34a4a0e84b94ea0012385760/protobuf-java-4.28.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api.grpc/proto-google-common-protos/2.54.1/aa342c093e2b75ecc341f28d2ee6c2b4480169c2/proto-google-common-protos-2.54.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api/gax/2.63.1/6c9a340608a63e24dc8acd8da84afd8ffecca4b7/gax-2.63.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.auth/google-auth-library-credentials/1.33.1/e3d0772d9a99ddbf137c5098ab17c2c3012162c2/google-auth-library-credentials-1.33.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.protobuf/protobuf-java-util/3.25.5/38cc5ce479603e36466feda2a9f1dfdb2210ef00/protobuf-java-util-3.25.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api/gax-grpc/2.63.1/3d20d2583fbb4ca5ca8023c614410f270a98b423/gax-grpc-2.63.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-inprocess/1.70.0/6df33f3da4603c6ae3cd7717cf14093b05d039b/grpc-inprocess-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-core/1.70.0/727f3b07d5ef9b21d9eb00c166991ea4273a3794/grpc-core-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.android/annotations/4.1.1.4/a1678ba907bf92691d879fef34e1a187038f9259/annotations-4.1.1.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-alts/1.70.0/6fd444d12ea79f6ae7f85cc8687612fd60988723/grpc-alts-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-grpclb/1.70.0/f7929004de760f224f25082d598ce01edcbae4c9/grpc-grpclb-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.conscrypt/conscrypt-openjdk-uber/2.5.2/d858f142ea189c62771c505a6548d8606ac098fe/conscrypt-openjdk-uber-2.5.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-auth/1.70.0/f4a6748cb62acb01fb05c95296399bc9930191c/grpc-auth-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-netty-shaded/1.70.0/8a4450921c3a1c1410404e560679d0a15e943ae1/grpc-netty-shaded-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-util/1.70.0/8f34c6f76bcba2ab52cc304f92f04688af70e0f8/grpc-util-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.perfmark/perfmark-api/0.27.0/f86f575a41b091786a4b027cd9c0c1d2e3fc1c01/perfmark-api-0.27.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-googleapis/1.70.0/9f1130a89891bc2158405b282a89feedd09c27bf/grpc-googleapis-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-xds/1.70.0/e19bfdf3c327ca2d77a0b0b949ac324c425d6dca/grpc-xds-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-services/1.70.0/8b5577bbae01737d51a0dfcba1da07bd4cf4ebc6/grpc-services-1.70.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.re2j/re2j/1.7/2949632c1b4acce0d7784f28e3152e9cf3c2ec7a/re2j-1.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.threeten/threetenbp/1.7.0/8703e893440e550295aa358281db468625bc9a05/threetenbp-1.7.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.wildfly.common/wildfly-common/1.5.4.Final/735ceee5616d5143bac1bc740e444697073c002f/wildfly-common-1.5.4.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.minidev/accessors-smart/2.5.2/ce16fd235cfee48e67eda33e684423bba09f7d07/accessors-smart-2.5.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jgroups/jgroups/5.3.13.Final/b183b12ba220050a844b55438e4853b7183668fe/jgroups-5.3.13.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/commons-beanutils/commons-beanutils/1.10.1/22c392b43aa32e1364fb39647111edfa91df9070/commons-beanutils-1.10.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jctools/jctools-core/4.0.5/9ab38ca19877236986db4894ef1400a7ca23db80/jctools-core-4.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/commons-collections/commons-collections/3.2.2/8ad72fe39fa8c91eaaf12aadb21e0c3661fe26d5/commons-collections-3.2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/activemq-artemis-native/2.0.0/a1bdd3cea7822f3b90063456b0c9928702076bd1/activemq-artemis-native-2.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.zipkin2/zipkin/2.27.1/74b5227ae2fe515217107fd228707e4d960ec3ec/zipkin-2.27.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/osgi-resource-locator/1.0.3/de3b21279df7e755e38275137539be5e2c80dd58/osgi-resource-locator-1.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/class-model/3.0.6/cdb59ed7b763f2fbee0a5595b2d1bad91d22f27f/class-model-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.javassist/javassist/3.30.2-GA/284580b5e42dfa1b8267058566435d9e93fae7f7/javassist-3.30.2-GA.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opentest4j/opentest4j/1.3.0/152ea56b3a72f655d4fd677fc0ef2596c3dd5e6e/opentest4j-1.3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jetbrains/annotations/13.0/919f0dfe192fb4e063e7dacadee7f8bb9a2672a9/annotations-13.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.acplt.remotetea/remotetea-oncrpc/1.1.2/705c490ad22ff4627389853439f9decf5ee69be/remotetea-oncrpc-1.1.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.tdunning/t-digest/3.2/2ab94758b0276a8a26102adf8d528cf6d0567b9a/t-digest-3.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.atteo/evo-inflector/1.3/4cf8b5f363c60e63f8b7688ac053590460f2768e/evo-inflector-1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.stephenc.jcip/jcip-annotations/1.0-1/ef31541dd28ae2cefdd17c7ebf352d93e9058c63/jcip-annotations-1.0-1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jffi/1.3.9/b776ea131fa693af2c943368b52acf94131cbd7/jffi-1.3.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jffi/1.3.9/163d683f80c06911f3e770c723d6e399e4c59448/jffi-1.3.9-native.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm-util/9.2/fbc178fc5ba3dab50fd7e8a5317b8b647c8e8946/asm-util-9.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm-commons/9.6/f1a9e5508eff490744144565c47326c8648be309/asm-commons-9.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm-analysis/9.2/7487dd756daf96cab9986e44b9d7bcb796a61c10/asm-analysis-9.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm-tree/9.6/c0cdda9d211e965d2a4448aa3fd86110f2f8c2de/asm-tree-9.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm/9.7.1/f0ed132a49244b042cd0e15702ab9f2ce3cc8436/asm-9.7.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-a64asm/1.0.0/a1cb8dbe71b5a6a0288043c3ba3ca64545be165/jnr-a64asm-1.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-x86asm/1.0.2/6936bbd6c5b235665d87bd450f5e13b52d4b48/jnr-x86asm-1.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2.external/aopalliance-repackaged/3.0.6/e3c3f17b649c97155640616026bd32b1043b3c1d/aopalliance-repackaged-3.0.6.jar"
      "java.vm.vendor" : {
        "value" : "BellSoft"
    "name" : "systemEnvironment",
    "properties" : {
      "JAVA_HOME" : {
        "value" : "/opt/hostedtoolcache/Java_Liberica_jdk/17.0.15-10/x64",
        "origin" : "System Environment Property \"JAVA_HOME\""
    "name" : "Config resource 'class path resource [org/springframework/boot/actuate/autoconfigure/env/application.properties]' via location 'classpath:/org/springframework/boot/actuate/autoconfigure/env/'",
    "properties" : {
      "com.example.cache.max-size" : {
        "value" : "1000",
        "origin" : "class path resource [org/springframework/boot/actuate/autoconfigure/env/application.properties] - 1:29"
    "name" : "logCorrelation",
    "properties" : { }
    "name" : "applicationInfo",
    "properties" : { }
Sanitization of sensitive values has been switched off for this example.
Response Structure
The response contains details of the application’s Environment. The following table describes the structure of the response:spring-doc.cn
Path Type Description
activeProfilesspring-doc.cn
Arrayspring-doc.cn
Names of the active profiles, if any.spring-doc.cn
defaultProfilesspring-doc.cn
Arrayspring-doc.cn
Names of the default profiles, if any.spring-doc.cn
propertySourcesspring-doc.cn
Arrayspring-doc.cn
Property sources in order of precedence.spring-doc.cn
propertySources.[].namespring-doc.cn
Stringspring-doc.cn
Name of the property source.spring-doc.cn
propertySources.[].propertiesspring-doc.cn
Objectspring-doc.cn
Properties in the property source keyed by property name.spring-doc.cn
propertySources.[].properties.*.valuespring-doc.cn
Stringspring-doc.cn
Value of the property.spring-doc.cn
propertySources.[].properties.*.originspring-doc.cn
Stringspring-doc.cn
Origin of the property, if any.spring-doc.cn
Retrieving a Single Property
To retrieve a single property, make a GET request to /actuator/env/{property.name}, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/env/com.example.cache.max-size' -i -X GET
The preceding example retrieves information about the property named com.example.cache.max-size. The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Disposition: inline;filename=f.txt
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 793
{"property":{"source":"Config resource 'class path resource [org/springframework/boot/actuate/autoconfigure/env/application.properties]' via location 'classpath:/org/springframework/boot/actuate/autoconfigure/env/'","value":"1000"},"activeProfiles":[],"defaultProfiles":["default"],"propertySources":[{"name":"servletContextInitParams"},{"name":"systemProperties"},{"name":"systemEnvironment"},{"name":"Config resource 'class path resource [org/springframework/boot/actuate/autoconfigure/env/application.properties]' via location 'classpath:/org/springframework/boot/actuate/autoconfigure/env/'","property":{"value":"1000","origin":"class path resource [org/springframework/boot/actuate/autoconfigure/env/application.properties] - 1:29"}},{"name":"logCorrelation"},{"name":"applicationInfo"}]}
Response Structure
The response contains details of the requested property. The following table describes the structure of the response:spring-doc.cn
propertyspring-doc.cn
Objectspring-doc.cn
Property from the environment, if found.spring-doc.cn
property.sourcespring-doc.cn
Stringspring-doc.cn
Name of the source of the property.spring-doc.cn
property.valuespring-doc.cn
Stringspring-doc.cn
Arrayspring-doc.cn
Arrayspring-doc.cn
Arrayspring-doc.cn
Stringspring-doc.cn
propertySources.[].propertyspring-doc.cn
Objectspring-doc.cn
Property in the property source, if any.spring-doc.cn
propertySources.[].property.valuespring-doc.cn
Variesspring-doc.cn
propertySources.[].property.originspring-doc.cn
Stringspring-doc.cn
