Caches (caches)
The caches endpoint provides access to the application’s caches.spring-doc.cn
Retrieving All Caches
To retrieve the application’s caches, make a GET request to /actuator/caches, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/caches' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 435
  "cacheManagers" : {
    "anotherCacheManager" : {
      "caches" : {
        "countries" : {
          "target" : "java.util.concurrent.ConcurrentHashMap"
    "cacheManager" : {
      "caches" : {
        "cities" : {
        "countries" : {
Response Structure
The response contains details of the application’s caches. The following table describes the structure of the response:spring-doc.cn
Path Type Description
cacheManagersspring-doc.cn
Objectspring-doc.cn
Cache managers keyed by id.spring-doc.cn
cacheManagers.*.cachesspring-doc.cn
Objectspring-doc.cn
Caches in the application context keyed by name.spring-doc.cn
cacheManagers.*.caches.*.targetspring-doc.cn
Stringspring-doc.cn
Fully qualified name of the native cache.spring-doc.cn
Retrieving Caches by Name
To retrieve a cache by name, make a GET request to /actuator/caches/{name}, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/caches/cities' -i -X GET
The preceding example retrieves information about the cache named cities. The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Length: 113
  "target" : "java.util.concurrent.ConcurrentHashMap",
  "name" : "cities",
  "cacheManager" : "cacheManager"
Query Parameters
If the requested name is specific enough to identify a single cache, no extra parameter is required. Otherwise, the cacheManager must be specified. The following table shows the supported query parameters:spring-doc.cn
Parameter Description
cacheManagerspring-doc.cn
Name of the cacheManager to qualify the cache. May be omitted if the cache name is unique.spring-doc.cn
Response Structure
The response contains details of the requested cache. The following table describes the structure of the response:spring-doc.cn
namespring-doc.cn
Stringspring-doc.cn
Cache name.spring-doc.cn
Stringspring-doc.cn
Cache manager name.spring-doc.cn
targetspring-doc.cn
Stringspring-doc.cn
Evict All Caches
To clear all available caches, make a DELETE request to /actuator/caches as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/caches' -i -X DELETE
Evict a Cache by Name
To evict a particular cache, make a DELETE request to /actuator/caches/{name} as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/caches/countries?cacheManager=anotherCacheManager' -i -X DELETE \
    -H 'Content-Type: application/x-www-form-urlencoded'
As there are two caches named countries, the cacheManager has to be provided to specify which Cache should be cleared.
Request Structure
