此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Boot 3.4.5spring-doc.cadn.net.cn
条件评估报告 (conditions)
conditionsendpoint 提供有关 Configuration 和 Auto-Configuration 类的条件评估的信息。spring-doc.cadn.net.cn
检索报告
要检索报告,请创建一个GETrequest 添加到/actuator/conditions,如以下基于 curl 的示例所示:spring-doc.cadn.net.cn
$ curl 'http://localhost:8080/actuator/conditions' -i -X GET
生成的响应类似于以下内容:spring-doc.cadn.net.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 3426
  "contexts" : {
    "application" : {
      "positiveMatches" : {
        "EndpointAutoConfiguration#propertiesEndpointAccessResolver" : [ {
          "condition" : "OnBeanCondition",
          "message" : "@ConditionalOnMissingBean (types: org.springframework.boot.actuate.endpoint.EndpointAccessResolver; SearchStrategy: all) did not find any beans"
        "EndpointAutoConfiguration#endpointOperationParameterMapper" : [ {
          "message" : "@ConditionalOnMissingBean (types: org.springframework.boot.actuate.endpoint.invoke.ParameterValueMapper; SearchStrategy: all) did not find any beans"
        "EndpointAutoConfiguration#endpointCachingOperationInvokerAdvisor" : [ {
          "message" : "@ConditionalOnMissingBean (types: org.springframework.boot.actuate.endpoint.invoker.cache.CachingOperationInvokerAdvisor; SearchStrategy: all) did not find any beans"
      "negativeMatches" : {
        "WebFluxEndpointManagementContextConfiguration" : {
          "notMatched" : [ {
            "condition" : "OnWebApplicationCondition",
            "message" : "not a reactive web application"
          "matched" : [ {
            "condition" : "OnClassCondition",
            "message" : "@ConditionalOnClass found required classes 'org.springframework.web.reactive.DispatcherHandler', 'org.springframework.http.server.reactive.HttpHandler'"
        "GsonHttpMessageConvertersConfiguration.GsonHttpMessageConverterConfiguration" : {
          "notMatched" : [ {
            "condition" : "GsonHttpMessageConvertersConfiguration.PreferGsonOrJacksonAndJsonbUnavailableCondition",
            "message" : "AnyNestedCondition 0 matched 2 did not; NestedCondition on GsonHttpMessageConvertersConfiguration.PreferGsonOrJacksonAndJsonbUnavailableCondition.JacksonJsonbUnavailable NoneNestedConditions 1 matched 1 did not; NestedCondition on GsonHttpMessageConvertersConfiguration.JacksonAndJsonbUnavailableCondition.JsonbPreferred @ConditionalOnPreferredJsonMapper JSONB no property was configured and Jackson is the default; NestedCondition on GsonHttpMessageConvertersConfiguration.JacksonAndJsonbUnavailableCondition.JacksonAvailable @ConditionalOnBean (types: org.springframework.http.converter.json.MappingJackson2HttpMessageConverter; SearchStrategy: all) found bean 'mappingJackson2HttpMessageConverter'; NestedCondition on GsonHttpMessageConvertersConfiguration.PreferGsonOrJacksonAndJsonbUnavailableCondition.GsonPreferred @ConditionalOnPreferredJsonMapper GSON no property was configured and Jackson is the default"
          "matched" : [ ]
        "WebMvcEndpointManagementContextConfiguration#managementHealthEndpointWebMvcHandlerMapping" : {
          "notMatched" : [ {
            "condition" : "OnManagementPortCondition",
            "message" : "Management Port actual port type (SAME) did not match required type (DIFFERENT)"
          "matched" : [ ]
      "unconditionalClasses" : [ "org.springframework.boot.autoconfigure.context.PropertyPlaceholderAutoConfiguration", "org.springframework.boot.actuate.autoconfigure.endpoint.jackson.JacksonEndpointAutoConfiguration", "org.springframework.boot.actuate.autoconfigure.endpoint.EndpointAutoConfiguration" ]
响应结构
响应包含应用程序条件评估的详细信息。 下表描述了响应的结构:spring-doc.cadn.net.cn
路径 类型 描述
contextsspring-doc.cadn.net.cn
Objectspring-doc.cadn.net.cn
以 id 为键的应用程序上下文。spring-doc.cadn.net.cn
contexts.*.positiveMatchesspring-doc.cadn.net.cn
具有匹配条件的类和方法。spring-doc.cadn.net.cn
contexts.*.positiveMatches.*.[].conditionspring-doc.cadn.net.cn
Stringspring-doc.cadn.net.cn
条件的名称。spring-doc.cadn.net.cn
contexts.*.positiveMatches.*.[].messagespring-doc.cadn.net.cn
条件匹配原因的详细信息。spring-doc.cadn.net.cn
contexts.*.negativeMatchesspring-doc.cadn.net.cn
条件不匹配的类和方法。spring-doc.cadn.net.cn
contexts.*.negativeMatches.*.notMatchedspring-doc.cadn.net.cn
Arrayspring-doc.cadn.net.cn
匹配的条件。spring-doc.cadn.net.cn
contexts.*.negativeMatches.*.notMatched.[].conditionspring-doc.cadn.net.cn
contexts.*.negativeMatches.*.notMatched.[].messagespring-doc.cadn.net.cn
条件不匹配原因的详细信息。spring-doc.cadn.net.cn
contexts.*.negativeMatches.*.matchedspring-doc.cadn.net.cn
contexts.*.negativeMatches.*.matched.[].conditionspring-doc.cadn.net.cn
contexts.*.negativeMatches.*.matched.[].messagespring-doc.cadn.net.cn
contexts.*.unconditionalClassesspring-doc.cadn.net.cn
无条件自动配置类的名称(如果有)。spring-doc.cadn.net.cn
contexts.*.parentIdspring-doc.cadn.net.cn
父应用程序上下文的 ID(如果有)。spring-doc.cadn.net.cn
