此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Boot 3.4.5spring-doc.cadn.net.cn
配置属性 (configprops)
configpropsendpoint 提供有关应用程序的@ConfigurationProperties豆。spring-doc.cadn.net.cn
检索所有 @ConfigurationProperties 个 Bean
要检索所有@ConfigurationPropertiesbeans 中,制作一个GETrequest 添加到/actuator/configprops,如以下基于 curl 的示例所示:spring-doc.cadn.net.cn
$ curl 'http://localhost:8080/actuator/configprops' -i -X GET
生成的响应类似于以下内容:spring-doc.cadn.net.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 3411
  "contexts" : {
    "application" : {
      "beans" : {
        "management.endpoints.web.cors-org.springframework.boot.actuate.autoconfigure.endpoint.web.CorsEndpointProperties" : {
          "prefix" : "management.endpoints.web.cors",
          "properties" : {
            "allowedOrigins" : [ ],
            "maxAge" : "PT30M",
            "exposedHeaders" : [ ],
            "allowedOriginPatterns" : [ ],
            "allowedHeaders" : [ ],
            "allowedMethods" : [ ]
          "inputs" : {
            "maxAge" : { },
        "management.endpoints.web-org.springframework.boot.actuate.autoconfigure.endpoint.web.WebEndpointProperties" : {
          "prefix" : "management.endpoints.web",
          "properties" : {
            "pathMapping" : { },
            "exposure" : {
              "include" : [ "*" ],
              "exclude" : [ ]
            "basePath" : "/actuator",
            "discovery" : {
              "enabled" : true
          "inputs" : {
            "exposure" : {
              "include" : [ {
                "value" : "*",
                "origin" : "\"management.endpoints.web.exposure.include\" from property source \"Inlined Test Properties\""
              "exclude" : [ ]
            "basePath" : { },
            "discovery" : {
              "enabled" : { }
        "spring.web-org.springframework.boot.autoconfigure.web.WebProperties" : {
          "prefix" : "spring.web",
          "properties" : {
            "localeResolver" : "ACCEPT_HEADER",
            "resources" : {
              "staticLocations" : [ "classpath:/META-INF/resources/", "classpath:/resources/", "classpath:/static/", "classpath:/public/" ],
              "addMappings" : true,
              "chain" : {
                "cache" : true,
                "compressed" : false,
                "strategy" : {
                  "fixed" : {
                    "enabled" : false,
                    "paths" : [ "/**" ]
                  "content" : {
                    "enabled" : false,
                    "paths" : [ "/**" ]
              "cache" : {
                "cachecontrol" : { },
                "useLastModified" : true
          "inputs" : {
            "localeResolver" : { },
            "resources" : {
              "staticLocations" : [ { }, { }, { }, { } ],
              "addMappings" : { },
              "chain" : {
                "cache" : { },
                "compressed" : { },
                "strategy" : {
                  "fixed" : {
                    "enabled" : { },
                    "paths" : [ { } ]
                  "content" : {
                    "enabled" : { },
                    "paths" : [ { } ]
              "cache" : {
                "useLastModified" : { }
响应结构
响应包含应用程序的@ConfigurationProperties豆。 下表描述了响应的结构:spring-doc.cadn.net.cn
路径 类型 描述
contextsspring-doc.cadn.net.cn
Objectspring-doc.cadn.net.cn
以 id 为键的应用程序上下文。spring-doc.cadn.net.cn
contexts.*.beans.*spring-doc.cadn.net.cn
@ConfigurationProperties以 Bean 名称为键的 bean。spring-doc.cadn.net.cn
contexts.*.beans.*.prefixspring-doc.cadn.net.cn
Stringspring-doc.cadn.net.cn
应用于 Bean 属性名称的前缀。spring-doc.cadn.net.cn
contexts.*.beans.*.propertiesspring-doc.cadn.net.cn
Bean 的属性作为名称-值对。spring-doc.cadn.net.cn
contexts.*.beans.*.inputsspring-doc.cadn.net.cn
绑定到此 bean 时使用的 configuration 属性的来源和值。spring-doc.cadn.net.cn
contexts.*.parentIdspring-doc.cadn.net.cn
父应用程序上下文的 ID(如果有)。spring-doc.cadn.net.cn
按前缀检索 @ConfigurationProperties Bean
要检索@ConfigurationPropertiesbean 映射在某个前缀下,则创建一个GETrequest 添加到/actuator/configprops/{prefix},如以下基于 curl 的示例所示:spring-doc.cadn.net.cn
$ curl 'http://localhost:8080/actuator/configprops/spring.jackson' -i -X GET
HTTP/1.1 200 OK
Content-Disposition: inline;filename=f.txt
Content-Length: 878
  "contexts" : {
    "application" : {
      "beans" : {
        "spring.jackson-org.springframework.boot.autoconfigure.jackson.JacksonProperties" : {
          "prefix" : "spring.jackson",
          "properties" : {
            "serialization" : { },
            "visibility" : { },
            "parser" : { },
            "datatype" : {
              "jsonNode" : { },
              "enum" : { }
            "deserialization" : { },
            "generator" : { },
            "mapper" : { }
          "inputs" : {
            "visibility" : { },
            "parser" : { },
            "datatype" : {
              "jsonNode" : { },
              "enum" : { }
            "generator" : { },
            "mapper" : { }
{prefix}不需要精确,更通用的前缀将返回该前缀 Stem 下映射的所有 bean。
响应结构
路径 类型 描述
