Process Monitoring
In the spring-boot module, you can find two classes to create files that are often useful for process monitoring:spring-doc.cn
By default, these writers are not activated, but you can enable them:spring-doc.cn
Extending Configuration
In the META-INF/spring.factories file, you can activate the listener (or listeners) that writes a PID file:spring-doc.cn
org.springframework.context.ApplicationListener=\
org.springframework.boot.context.ApplicationPidFileWriter,\
org.springframework.boot.web.context.WebServerPortFileWriter
Programmatically Enabling Process Monitoring
You can also activate a listener by invoking the SpringApplication.addListeners(…​) method and passing the appropriate Writer object. This method also lets you customize the file name and path in the Writer constructor.spring-doc.cn
