This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.5! |
Application Startup (startup
The startup
endpoint provides information about the application’s startup sequence.
Retrieving the Application Startup Steps
The application startup steps can either be retrieved as a snapshot (GET
) or drained from the buffer (POST
Retrieving a snapshot of the Application Startup Steps
To retrieve the steps recorded so far during the application startup phase, make a GET
request to /actuator/startup
, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/startup' -i -X GET
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 893
"springBootVersion" : "3.5.0-RC1",
"timeline" : {
"startTime" : "2025-04-25T09:57:34.400545574Z",
"events" : [ {
"endTime" : "2025-04-25T09:57:34.880459457Z",
"duration" : "PT0.000005651S",
"startTime" : "2025-04-25T09:57:34.880453806Z",
"startupStep" : {
"name" : "spring.beans.instantiate",
"id" : 3,
"tags" : [ {
"key" : "beanName",
"value" : "homeController"
"parentId" : 2
"endTime" : "2025-04-25T09:57:34.880465598Z",
"duration" : "PT0.000018695S",
"startTime" : "2025-04-25T09:57:34.880446903Z",
"startupStep" : {
"name" : "spring.boot.application.starting",
"id" : 2,
"tags" : [ {
"key" : "mainApplicationClass",
"value" : "com.example.startup.StartupApplication"
Draining the Application Startup Steps
To drain and return the steps recorded so far during the application startup phase, make a POST
$ curl 'http://localhost:8080/actuator/startup' -i -X POST
HTTP/1.1 200 OK
Content-Length: 893
"timeline" : {
"events" : [ {
"endTime" : "2025-04-25T09:57:34.814020351Z",
"duration" : "PT0.000239295S",
"startTime" : "2025-04-25T09:57:34.813781056Z",
"startupStep" : {
"id" : 1,
"tags" : [ {
"key" : "beanName",
"parentId" : 0
"endTime" : "2025-04-25T09:57:34.814049555Z",
"duration" : "PT0.011361084S",
"startTime" : "2025-04-25T09:57:34.802688471Z",
"startupStep" : {
"id" : 0,
"tags" : [ {
Response Structure
The response contains details of the application startup steps. The following table describes the structure of the response:
Path | Type | Description |
Spring Boot version for this application. |
Start time of the application. |
An array of steps collected during application startup so far. |
The timestamp of the start of this event. |
The timestamp of the end of this event. |
The precise duration of this event. |
The name of the StartupStep. |
The id of this StartupStep. |
The parent id for this StartupStep. |
An array of key/value pairs with additional step info. |
The key of the StartupStep Tag. |
The value of the StartupStep Tag. |
