This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.5! |
Sessions (sessions
The sessions
endpoint provides information about the application’s HTTP sessions that are managed by Spring Session.
Retrieving Sessions
To retrieve the sessions, make a GET
request to /actuator/sessions
, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/sessions?username=alice' -i -X GET
The preceding examples retrieves all of the sessions for the user whose username is alice
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 789
"sessions" : [ {
"id" : "29c0567a-4f4c-48ac-b7d3-0860d6b4a66b",
"attributeNames" : [ ],
"creationTime" : "2025-04-24T21:57:32.946003236Z",
"lastAccessedTime" : "2025-04-25T09:56:47.946010880Z",
"maxInactiveInterval" : 1800,
"expired" : false
"id" : "fca5f90b-4fee-44d5-991f-d56c1acec90a",
"creationTime" : "2025-04-25T07:57:32.955024760Z",
"lastAccessedTime" : "2025-04-25T09:57:20.955025472Z",
"expired" : false
"id" : "4db5efcc-99cb-4d05-a52c-b49acfbb7ea9",
"creationTime" : "2025-04-25T04:57:32.955018759Z",
"lastAccessedTime" : "2025-04-25T09:56:55.955021524Z",
"expired" : false
Query Parameters
The endpoint uses query parameters to limit the sessions that it returns. The following table shows the single required query parameter:
Parameter | Description |
Name of the user. |
Response Structure
The response contains details of the matching sessions. The following table describes the structure of the response:
Path | Type | Description |
Sessions for the given username. |
ID of the session. |
Names of the attributes stored in the session. |
Timestamp of when the session was created. |
Timestamp of when the session was last accessed. |
Maximum permitted period of inactivity, in seconds, before the session will expire. |
Whether the session has expired. |
Retrieving a Single Session
To retrieve a single session, make a GET
request to /actuator/sessions/{id}
$ curl 'http://localhost:8080/actuator/sessions/4db5efcc-99cb-4d05-a52c-b49acfbb7ea9' -i -X GET
The preceding example retrieves the session with the id
of 4db5efcc-99cb-4d05-a52c-b49acfbb7ea9
HTTP/1.1 200 OK
Content-Length: 208
{"id":"4db5efcc-99cb-4d05-a52c-b49acfbb7ea9","attributeNames":[],"creationTime":"2025-04-25T04:57:32.955018759Z","lastAccessedTime":"2025-04-25T09:56:55.955021524Z","maxInactiveInterval":1800,"expired":false}
Response Structure
The response contains details of the requested session. The following table describes the structure of the response:
Deleting a Session
To delete a session, make a DELETE
$ curl 'http://localhost:8080/actuator/sessions/4db5efcc-99cb-4d05-a52c-b49acfbb7ea9' -i -X DELETE
The preceding example deletes the session with the id
