Validation
The method validation feature supported by Bean Validation 1.1 is automatically enabled as long as a JSR-303 implementation (such as Hibernate validator) is on the classpath. This lets bean methods be annotated with jakarta.validation constraints on their parameters and/or on their return value. Target classes with such annotated methods need to be annotated with the @Validated annotation at the type level for their methods to be searched for inline constraint annotations.spring-doc.cn
For instance, the following service triggers the validation of the first argument, making sure its size is between 8 and 10:spring-doc.cn
import jakarta.validation.constraints.Size;
import org.springframework.stereotype.Service;
import org.springframework.validation.annotation.Validated;
@Service
@Validated
public class MyBean {
	public Archive findByCodeAndAuthor(@Size(min = 8, max = 10) String code, Author author) {
		return ...
@Service
@Validated
class MyBean {
	fun findByCodeAndAuthor(code: @Size(min = 8, max = 10) String?, author: Author?): Archive? {
		return null
The application’s MessageSource is used when resolving {parameters} in constraint messages. This allows you to use your application’s messages.properties files for Bean Validation messages. Once the parameters have been resolved, message interpolation is completed using Bean Validation’s default interpolator.spring-doc.cn
To customize the Configuration used to build the ValidatorFactory, define a ValidationConfigurationCustomizer bean. When multiple customizer beans are defined, they are called in order based on their @Order annotation or Ordered implementation.spring-doc.cn
